I have a question about FI on a manual and a auto
Old Feb 17, 2008 | 09:11 PM
marques1's Avatar
marques1
Default I have a question about FI on a manual and a auto
Ok guys hopefully i would not get flamed to bad. Im not trying to start a auto vs manual war either but this got me thinking. If you were on a rolling start not a dig because i know that the manual would have an advantage on launching unless the auto had a torque converter and a stall.
Okay so you racing from a roll with 2 350z with forced induction one manual and the other auto. we will say for kicks that Both cars put down 400 rwhp and almost the same torque down on the same dyno.
Which car would have an advantage or will they be even because they put down the same amount of hp to the wheels. I would think the auto because it has no lag inbetween gears please discuss im interested, thanks!
Old Feb 17, 2008 | 09:36 PM
JAM3Z's Avatar
JAM3Z
Phenom
Why don't you ask Alberto, lol
Old Feb 17, 2008 | 09:39 PM
sentry65's Avatar
sentry65
the burninator
driver's race
also depends on what speed you start at and what speed you end at
and the amount of traction available to each car
Old Feb 17, 2008 | 09:57 PM
mrg1981's Avatar
mrg1981
Yeah, the roll in speed would matter a ton. For instance, and I know these numbers won't make sense, but let's say you launch at 30 MPH. This could be the high RPM range for 1st gear on the Auto and the low RPM range in 2nd gear on the manual. Perhaps if you launched at another speed it would be flipped. Since the gearing is different, the launch speed will put the cars in different rpm ranges and possibly different gears. Also, even if same gears, one might need to shift right away and the other won't shift for a while.
In theory, an auto that is built properly will shift faster than any human can. on the other hand, a stock auto tranny in the Z is good, but not terrific. If it is a stock auto tranny, I'd give the edge to a good driver in a manual. If it is a built or modified auto tranny done correctly, then I'd give the edge to a good driver in an auto.
Old Feb 17, 2008 | 10:40 PM
marques1's Avatar
marques1
ok i see what about if the both cars were equipped with the same gears with 2 good drivers and traction was available to both of them equally.
Old Feb 17, 2008 | 11:02 PM
mrg1981's Avatar
mrg1981
Once again, the theory is that the auto can shift faster and when built/tuned properly keep your rpm range right where you want it the entire time.
This is nearly impossible to test in reality, but I think everyone can agree that in theory that auto can shift faster and maintain peak hp ranges longer than any driver could achieve in a manual.
Without a built transmission (assuming completely stock AT), however, the manual should be faster under the given conditions. A good driver with a manual can improve the shifting quite a bit over an amateur. The auto driver can only do so much, since the time and the RPMs are controlled by the computer primarily. The shifting is good, but not great stock. Also, having owned both a manual Z and an auto Z, I can tell you the race would be VERY close.
Old Feb 18, 2008 | 03:45 AM
rcdash's Avatar
rcdash
ZdayZ...
Old Feb 18, 2008 | 04:29 AM
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by rcdash
ZdayZ...
I agree. as asinine as this debate is, you can say a lot of things "in theory", but at the end of the day, in practice, I think that a 6sp will win out over the 5at most times.
Old May 27, 2008 | 09:24 AM
rcdash's Avatar
rcdash
bump! ...and now what do you say Jamez?
Old May 27, 2008 | 02:37 PM
superchargedg's Avatar
superchargedg
Damn Noobs
A big thumbs up for us auto guys.....great job man.
Old May 27, 2008 | 03:46 PM
rcdash's Avatar
rcdash
I couldn't resist as I came across this old thread while researching my new TC. I don't think I actually raced Jamez.
I gotta take this setup out to the 1/4 mile and get some #s before the swap. I have a feeling even though I'll put more to the ground, I'll increase my ET.
Old May 27, 2008 | 03:51 PM
JAM3Z's Avatar
JAM3Z
Phenom
I've had a chance to race a few different cars by now. I'm a believer, auto's don't fu*k about!
Old May 27, 2008 | 03:54 PM
doug's Avatar
doug
i refuse to lose to auto's
Old May 27, 2008 | 04:24 PM
coachk's Avatar
coachk
I refuse to lose to MT's
Old May 27, 2008 | 04:27 PM
doug's Avatar
doug
I refuse to run less than 470 whp on the street
Old May 27, 2008 | 04:28 PM
haeshik's Avatar
haeshik
+1
Old May 27, 2008 | 04:31 PM
jonnylaw's Avatar
jonnylaw
this thread is stupid. OP all u did was start another M/T vs. A/T thread.
Old May 27, 2008 | 04:34 PM
coachk's Avatar
coachk
you got me good on that one.. But just remember its how you put the power to the ground that counts
Old May 27, 2008 | 04:56 PM
doug's Avatar
doug
the thread was from last feb... that issue was dead and gone.. this is just smack talk now
Old May 27, 2008 | 04:57 PM
doug's Avatar
doug
coach.. i hook like crazy.. call it my super dooper clutch skills and rear end control.. i'm just hot like that
