Will 325mm wide tires fit on stock body Z?
Old Feb 26, 2008 | 08:22 AM
roncfpz's Avatar
roncfpz
Question Will 325mm wide tires fit on stock body Z?
Mods, I'm posting this in FI section as well since this group most likely has either done it or has attempted it.
Here is the other thread in the Tire Section.
https://my350z.com/forum/wheels-and-tires/339082-has-anyone-fit-a-325mm-wide-tire-on-stock-body-z.html
Thanks,
Ron
Old Feb 26, 2008 | 08:30 AM
taurran's Avatar
taurran
It may be possible depending on which tires were used (actual tread width), the wheel offsets/spacers, ride height, wheel diameter, and your camber adjustments. I'd definitely recommend getting a fender rolling tool and rolling it out so it's completely flat against the outside fender wall.
Personally, I wouldn't think the extra 20mm would be worth the hassle considering you'd most likely have to run more camber to fit it.
Old Feb 26, 2008 | 08:33 AM
taurran's Avatar
taurran
Oh, and if money isn't an option I'd consider finding some R compounds. You'll tear through them faster but you'll definitely get better traction without all of the fitment issues. There's a thread going on about it in the tire/wheel section.
Old Feb 26, 2008 | 08:35 AM
XKR's Avatar
XKR
It will not fit...I have tried ! You will have to do body work to go wider than 305-315. I am using 305 and even my rims are at its limit....they are a coin distance from the shocks.
Old Feb 26, 2008 | 08:37 AM
roncfpz's Avatar
roncfpz
On the Z or the G? I'm not sure if the fitments are the same on both cars.
Old Feb 26, 2008 | 08:38 AM
XKR's Avatar
XKR
Sorry...I am talking about a 'G'
Old Feb 26, 2008 | 08:39 AM
roncfpz's Avatar
roncfpz
Thanks Craig. I'm currently running 305mm dropped 1" and -1.5 camber. It seems like there might be enough to get another 10mm on each side without tweaking the camber.
Old Feb 26, 2008 | 08:42 AM
roncfpz's Avatar
roncfpz
Thanks! Good suggestion.
Audible Mayhem's Avatar
Audible Mayhem
My350z
i have rolled fenders but my 315s clear easily. i know 325 would fit on my car...
Old Feb 26, 2008 | 09:19 AM
phunk's Avatar
phunk
CJ Motorsports
make/model of 315s and wheel size/offset?
Old Feb 26, 2008 | 09:27 AM
IIQuickSilverII's Avatar
IIQuickSilverII
do toyo R888
Old Feb 26, 2008 | 10:11 AM
Audible Mayhem
My350z
i have bronze LMGT4s 9.5 in back with 315 BFG drag radials on them...
Old Feb 26, 2008 | 10:20 AM
IIQuickSilverII
hows the wear on them....
Old Feb 26, 2008 | 10:38 AM
roncfpz's Avatar
roncfpz
Thanks J.
Old Feb 26, 2008 | 10:45 AM
Zquicksilver's Avatar
Zquicksilver
I think its possible. With a cut/shaved fender and the plastic guard removed from the upper portion of the shock tower, you may be able to fit a 325mm/ 12.8” section width tire back there But you will need everything adjusted perfectly and you may not want to push your car to hard on the track or into tight curves. Given those potentially risky situations, I don't feel it would be worth it in looks alone. I personally would find some sticky 305's or 315's.
As you can see in post #31, I conservatively measured the plastic housing to the un-cut fender lip and came up with 12".
https://my350z.com/forum/showthread....%26quot%3B+rim
With a 325 back there, you've diminished any space for wheel flex in the verticle axis. One reason I’m not pushing it beyond 305’s... I like the twisties
GL,
Zquicksilver
Old Feb 26, 2008 | 11:12 AM
roncfpz's Avatar
roncfpz
^ Thanks! It's looking doubtful. I wish this car had a bigger butt.
Old Feb 26, 2008 | 11:20 AM
Zexy's Avatar
Zexy
Wrong. I have a 315 on my rear on my CCW wheel and drive aggresively. No rubbing. I can definately fit a 325 as well on my rolled fenders.. It all depends on your offset/wheel width. Ron has his fender cut? Which i'm sure theres even more clearance.
Old Feb 26, 2008 | 11:27 AM
roncfpz's Avatar
roncfpz
Hmmmm, maybe I'll give it a try. The wheels are 11" wide and +32 offset.
Old Feb 26, 2008 | 11:59 AM
phunk's Avatar
phunk
CJ Motorsports
jeremy... what is your camber at? i wonder how well those tires would fit if you leveled off the camber and rode on the whole tire?
you would also loose clearance if the wheel was wider and allowed the tires to unwrap on the edges a little.
Old Feb 26, 2008 | 01:14 PM
JETPILOT's Avatar
JETPILOT
Are you looking for better traction? If you are wider is not the answer. Get a set o f the new Toyo R888's. I have them an they are quite an amazing difference from summer compound tires.
JET
