Problem with AutoMeter Nexus Gauges...
Old Feb 27, 2008 | 12:16 PM
Abishop's Avatar
Abishop
Question Problem with AutoMeter Nexus Gauges...
Hey guys,
I have a problem that i know someone can help me with on here.
Problem: I have the AutoMeter Nexus Gauges hooked up in this order: Fuel pressure on top, Boost/Vac in the middle and AFR last on my gauge pod. This is then connected to my Nexus control modual. The problem i am having is as i drive the Z my Boost/Vac gauge will sometimes freeze and everynow and then the fuel pressure will freeze too. I know its the gauges because my AFR and car boost normal. When i turn the car off the gauges that have froze stay lit and the controller flashes a code. The code in the manual says there is a loose connection. This couldn't be possible as every time i start the car the gauges work fine untill they freeze up.
Anyone have any insight on this? Anyone have this problem or known someone with this problem?
PS: I wrote AutoMeter the same thing, and will keep this updated as it might help someone in the future.
Thanks in advance!
Old Feb 27, 2008 | 01:02 PM
Nforce1's Avatar
Nforce1
Maybe vibrations from the car give the loose connection after a little bit a driving?
Old Feb 27, 2008 | 01:35 PM
Abishop's Avatar
Abishop
^ i was thinking about that. But for example, it only does it like every other time i drive the car. Also, i am lowered on Eibachs so that its the softest ride ever.
Old Feb 27, 2008 | 08:40 PM
Abishop's Avatar
Abishop
bump
Old Feb 28, 2008 | 07:24 PM
Abishop's Avatar
Abishop
bump X2
Old Feb 29, 2008 | 07:07 AM
eez's Avatar
eez
i had some strange issues with my nexus system; freezing up, not powering up, etc. I sent it all back to autometer to replace/repair and they replaced all the gages and sent back the original controller. I have not had any problems since.
Old Feb 29, 2008 | 02:12 PM
Abishop's Avatar
Abishop
^ how did you go about this eez?
Old Mar 3, 2008 | 01:17 PM
eez's Avatar
eez
call autometer
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
