Z throwing P0507 (high idle) even after idle relearn
Old Mar 20, 2008 | 02:59 PM
lve2xlr8's Avatar
lve2xlr8
Default Z throwing P0507 (high idle) even after idle relearn
Ever since I've had my Vortech supercharger my car will throw a code for high idle, I'll then delete the code and it comes back usually within a day or 2... I have done the idle relearn and all the ECU diagnostics countless times and it relentlessly comes back, I removed the throttle body, cleaned it, replaced the gasket... Still having problems, anyone have advice?
Thanks
Old Mar 20, 2008 | 06:09 PM
rcdash's Avatar
rcdash
how high is the idle?
Old Mar 20, 2008 | 09:12 PM
drumminguy81's Avatar
drumminguy81
i am having the same problem. mine is idleing at 900 or so after warm and about 1200-1500 when first started..
Old Mar 21, 2008 | 02:33 AM
KempieZ's Avatar
KempieZ
My idle goes up and down all the time. From 1000rpm to 2500rpm and back. It will be fixed when break in period is over but we dont know how yet.
Old Mar 21, 2008 | 02:42 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
might be idle air volume problem.
Old Mar 21, 2008 | 03:09 PM
lve2xlr8's Avatar
lve2xlr8
After I do the relearn it idles normal at about 750rpm but after a few miles of driving it floats at 1500 for a while then drops down to 1200, throws the code, and stays like that till I do it over again. So frustrating...
Old Mar 21, 2008 | 05:24 PM
thawk408's Avatar
thawk408
Mine does the same thing. It use not to, but recently started. Are you tuned on a utec?
Old Mar 23, 2008 | 02:30 AM
lve2xlr8's Avatar
lve2xlr8
No, on the SS box.... Also, I have the l-spec flash from technosquare... It didn't do it at the beginning but it does it now, and it seems to be getting worse... Bad throttle body maybe?
Old Mar 23, 2008 | 11:00 AM
denverinfiniti's Avatar
denverinfiniti
Sounds like a bad throttle body. I've had a few remans right out of the box do that at work. Replaced it again and the problem is gone.
Old Mar 23, 2008 | 12:03 PM
vqturbotec's Avatar
vqturbotec
Have you checked for vaccum leaks
Old Mar 23, 2008 | 01:17 PM
thawk408's Avatar
thawk408
Go to a local auto repair place and have them put a smoke machine on the motor. It will show any leaks.
Old Mar 23, 2008 | 03:24 PM
lve2xlr8's Avatar
lve2xlr8
there re no visual vacuum leaks... I just remembered that a few months ago it was raining really hard and my car went into limp mode everytime I floored it, I had to do the ecu diagnostics, then it went back to normal... I'm thinking I might need a new throttle body, anyone have an extra or know where I can buy one for a reasonable price?
Old Mar 23, 2008 | 03:28 PM
thawk408's Avatar
thawk408
Ok.....visual doesnt mean ****. There can still be a leak even if you can not see it or hear it.
Old Mar 23, 2008 | 03:34 PM
vqturbotec's Avatar
vqturbotec
Old Apr 2, 2008 | 11:42 AM
jtgli's Avatar
jtgli
I am having the same problem with my 06 vortech on a Utec. It starts up at 2100 and then when warm will idle aroudn 900-1000 without the ac on. however when I am coming to a stop and push in the clutch the rpms drop to 750-800 and then spike up real quick to 1500 and hold there for about 5-10 seconds before settling down at 900 again. Its so frustrating. I throw the same code as well P0507. I had a buddy at nissan dealership try to see what was wrong and he thinks its the throttle body, however he said it could also be a vacum leak somewhere but I dont know where! So now I gotta go through and look everywhere. It didnt used to always do this either. Only for the past month or so.
Old Apr 2, 2008 | 07:44 PM
jtgli's Avatar
jtgli
anyone?
Old Apr 2, 2008 | 09:40 PM
weslutes's Avatar
weslutes
I sprayed small amounts of carb cleaner on multiple areas of the motor until I found my vacuum leak.
Old Apr 3, 2008 | 06:34 AM
jtgli's Avatar
jtgli
But how could I have a vacum leak if Im making a perfect 11psi of boost?
Old Apr 3, 2008 | 08:05 AM
Spooldyou's Avatar
Spooldyou
Vaccum leaks are usually suspect to a high idle, Espcially when adding a turbo to the mix. Are you guys using tbolt clamps throughout your setup?
Old Apr 3, 2008 | 08:10 AM
gabez33's Avatar
gabez33
NO.........all you have to do is disconnect your battery over night, about 8hrs, reconnect and report back. Reseting the ECU, relearn idle air , throttle position, does nothing for this. You have to treat it like a reboot.
