Greddy TT install, questions...
Old Mar 23, 2008 | 03:57 PM
350 Rookie's Avatar
350 Rookie
I tried installing a uppipe on my SINGLE turbo TN kit and let me tell you how much of a ***** it was. It took me nearly 12 hours just for the swap.
And you know what, i just blew my motor so this ****ing turbo kit has to come off and go on once again. I HATE NISSAN!!!!!
oh the positive side, Ill see you guys in 2 months with 500whp with my TN kit.
Old Mar 23, 2008 | 04:00 PM
350 Rookie's Avatar
350 Rookie
oh, and one thing. i just realized you said twin turbo. Good luck puttin that on a stock motor. I blew my motor with a single turbo at 8 psi.
go build or go home.
Old Mar 23, 2008 | 04:01 PM
pmohr's Avatar
pmohr
Originally Posted by Duke52
I just completed putting the Greddy kit in my car. I did it on a lift but with the motor in the car. If I had to do it all over again I'd definetly pull the motor, actually I'd probably sell half the things I own and pay some one to do it! LOL
I've turbocharged a Maxima, a small block chevy, and done just about every thing you can imagine to a ton of DSM's including a complete all-wheel-drive swap into a fwd but this was far more of a hassle.
It can be done; in fact people do it everyday, but don't put a deadline on it because it'll make you miserable if you do. If you run into any issues let me know; I took a ton of pictures that may answer some questions.
Good luck!
e
You on the org?
OP: Just drop the motor, doesn't take but an hour and it makes installing the kit a lot easier.
Old Mar 23, 2008 | 04:13 PM
doug's Avatar
doug
Originally Posted by pmohr@Altered
You on the org?
i am.. don't you care about me?
Old Mar 23, 2008 | 04:14 PM
doug's Avatar
doug
Good luck!
e
you must be stalking me, because i had a turbocharged maxima too
Old Mar 23, 2008 | 04:15 PM
350 Rookie's Avatar
350 Rookie
You on the org?
ya and make sure you use colored tape to mark everything. im about to drop my motor for a rebuild and one look at the wire harness and all the hoses, i almost went into a seizure. im actually feeling lazy after seeing that ****. hahaha.
Old Mar 23, 2008 | 04:18 PM
pmohr's Avatar
pmohr
Heh, seems like there are a lot of A32/A33-Z33 converts around here. Some J30s too, but who cares about them My car is currently being a POS, but now I have the right shop to do a VQ35 swap at...
Take the 5 minutes to pull the harness from the body, disconnect a few ground cables and the alternator harness...good to go. Harness comes down with it.
Old Mar 23, 2008 | 06:29 PM
350 Rookie's Avatar
350 Rookie
ya i really wish it was all 5 Minutes. lol i rather color code everything so i can hook it up w/o a problem.
Old Mar 23, 2008 | 06:35 PM
pmohr's Avatar
pmohr
That's the thing with pulling the engine control harness from the body rather than from every individual hookup on the engine itself; it's ridiculously easy. ECU and two other connectors, pop the grommet out underneath the battery cover, and it all slides right out.
More than 5 minutes, true...closer to 10 to remove the battery cover crap, the lower dash panel on the passenger side (makes it easier), and all of the ground wires. Still far easier than pulling the entire harness off of the engine, and makes for less of a chance of somehow breaking/destroying some of those hard to reach connectors in the engine bay.
Old Mar 23, 2008 | 06:54 PM
JETPILOT's Avatar
JETPILOT
500whp isn't an option on the TN kit..... sorry! Your going to have to trade the TN kit in for another setup like the rest of us did.
JET
Old Mar 23, 2008 | 07:09 PM
350 Rookie's Avatar
350 Rookie
are you serious? this motor has to be ripped apart. from the timing chain to the little bolt behind the flywheel. Im not taking out a motor and puttin another one in. Im taking out a motor to build it and then its going back in.
Old Mar 23, 2008 | 07:11 PM
350 Rookie's Avatar
350 Rookie
JET
Whys that? turbo is rated for around that much power, bigger wastegateand couple of other things, i should be there. If there are honda civics hittin that with single turbo, i can hit that no problem. lol
Old Mar 23, 2008 | 07:17 PM
JETPILOT's Avatar
JETPILOT
The downpipe is only 2.5". It doesn't flow well enough. My car stopped making power @ 5200 RPM with only 470whp. As you increase the boost the peak power drops in RPM unti lit's pretty much eseless. The point the Tn kit starts getting ugly is about 410whp. After that your looking at powerband issues. There are a few of us that tried to get close to 500whp and in the end all of us traded up to the Greddy TT. Now it's all sunshine!
JET
Old Mar 23, 2008 | 07:30 PM
doug's Avatar
doug
https://my350z.com/forum/shop-builds/318281-gt-motorsports-turbonetics-st-500-rwhp-no-problem.html
350 Rookie's Avatar
350 Rookie
JET
oh ok. makes sense. Well ill keep the TN for now cuz after this build, ill be broke as joke. Sell the kit, get a couple of grand saved up and ill be with you guys. All i want is 500 and my life is complete. I dont want anymore or any less.
Old Mar 23, 2008 | 08:41 PM
thawk408's Avatar
thawk408
It hit it, but not on a DD like jet was using. Still 500 wheel tho.
Old Mar 24, 2008 | 07:34 PM
JETPILOT's Avatar
JETPILOT
Wow... that's pretty impressive. I wish I had my dyno to post up from Sharif's tune. It didn't look anything like that. Sharif's tuning put my max power at 470whp @ 5200RPM and power fell off rapidly after. This car has cams though, but it shouldn't make that much of a difference.
Sharif seems to put alot of effort into some tunes he does and less into others. I was less than happy with his last 2 tunes he did for me. The Turbonetics and the Greddy.
JET
sales@czp
Sep 23, 2019 03:30 PM
