JWT 700 Kit Results
Old Mar 25, 2008 | 12:40 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default JWT 700 Kit Results
Just got home now, 02:00 Tuesday morning. On 6.5psi we made 487whp & 414wtq (398whp & 338wtq uncorrected). Boost comes quick and at 2500rpms I'm at 300wtq, raises to 400+ by 3500 and maintains it till 6300 (395wtq) and drops to 337 by 7300. Horsepower is nice and flat. At 2500 whp is 138whp and just continues to 487whp to 6750. Overall I'm very happy with the car. Pulls in every gear and is a blast to drive. Can't wait to get some more drive time. I'll post up pics and full mod list tomorrow.
Performace/Power Mods:
- JWT 700BB Twin Turbo System w/ HKS SSQV BOV & Swain Tech BBE Coated FMIC
- Koyo Racing Radiator
- Cosworth Intake Manifold
- UR Underdrive Crank Pulley w/ Gates Belts
- DeatschWerks 600cc Injectors
- NGK Iridium IX 1-Step Colder Spark Plugs
- Stillen Oil Cooler w/ Thermostat
- Walbro 255lph Fuel Pump
- APS 2.5" Test Pipes
- Stillen TD Cat-back ZR Single Tips
- TurboXS UTEC
- TurboXS Tuner Wideband w/ Bosch O2 Sensor
- TurboXS DTEC Map Sensor
- Perrin Boost Solenoid
Transmission:
- JWT Clutch
- JWT Flywheel
- AP Stainless Steel Clutch Line
Old Mar 25, 2008 | 01:03 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
You made 487 rwhp on 6.5???!
Nice results, Rob!
Old Mar 25, 2008 | 01:05 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nice results, Rob!
Thanks. Second pull we made 444 and 380. LOL!!! Thank you Dave!!! You sold me on the JWT after seeing the result to made with your 530 kit. Let me tell you... 6th gear... every time.
Old Mar 25, 2008 | 01:12 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Actually its SAE corrected not uncorrected but very nice non the less Your car has instant torque!
Old Mar 25, 2008 | 01:21 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm stating that 398 & 338 are the uncorrected numbers. The dyno sheet provided are showing the SAE corrected numbers. Also will Darren be in tomorrow? I need to exchange/replace my DEFI control unit. Seems not to be sending power to my Defi gauges.
Old Mar 25, 2008 | 01:26 AM
JETPILOT's Avatar
JETPILOT
???? What was the temperature and altitude for the dyno?
JET
Old Mar 25, 2008 | 01:31 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
JET
Parker Colorado is around 5870 ft. elevation. Conditions for this pull; Temp 67.48*F, Humidity 6% and, SAE 1.22
Old Mar 25, 2008 | 01:37 AM
JETPILOT's Avatar
JETPILOT
OK... I see the big correction was for altitude and a little correction for temp... I was wondering what the huge spread was for. It's pretty warm there now. I thought it would be cold.
Nice!
JET
Old Mar 25, 2008 | 02:22 AM
GolfinZ's Avatar
GolfinZ
sounds like its a blast to drive! congrats
Old Mar 25, 2008 | 02:27 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Jet: Yeah elevation is a killer but even more on the N/A side.
GolfinZ: Yes it is however considering how late it was/is I drove 60 miles hwy w/ the cruise on. LOL I did do a couple pulls but nothing to crazy. 110ish at most.
Old Mar 25, 2008 | 02:52 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Nice!
JET
Yeah, the altitude is a ***** here.
As a comparison, mine was 365 uncorrected. Never bothered to see what the corrected number was. So, Rob has the BB700's, and the Cosworth plenum; everything else is more or less the same. Cosworth probably made the biggest difference, considering we were running approx the same boost levels (6.8 on mine, 6.5 on his) I've got the MD spacer and MREV 2, and mine is a revup, whereas his is not.
23 rwhp for the Cosworth is nice! Plus it's all shiny and carbon fibered!
Old Mar 25, 2008 | 03:21 AM
merlin04's Avatar
merlin04
NICE! Good power, good AFR. What timing at WOT are you running?
Old Mar 25, 2008 | 03:33 AM
Doba's Avatar
Doba
my god, thats some serious power at 6psi, what is that turbo capable of with higher psi? must be a fair sized turbo, yet it boosts quite quickly, very impressive
Old Mar 25, 2008 | 04:37 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Dave: Mind e-mailing me your best run file. (When you can.) Like to overlay ours together for a comparo.
merlin04: I honestly don't know since I did not tune my car.
Doba: JWT says these turbos, GT2860RS, are cable of 700whp with built motor and supporting mods. Hench it called the JWT 700BB kit.
Old Mar 25, 2008 | 05:28 AM
taurran's Avatar
taurran
Nice results, but I'm going to be realistic here and say that the 487 number is way overcorrected. I'd be surprised if the car made 400whp on 6.5psi at sea level with correction, or uncorrected for that matter.
398whp at 6.5psi is still impressive. 487whp is just ridiculous and a bit misleading for those that don't understand correction factors.
Old Mar 25, 2008 | 05:43 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Not a problem. You have an opinion and have the right to express it. This is what it is and I'm not getting into this dyno vs this dyno and SAE vs uncorrected.
Here is my stock baseline vs JWT/Cosworth:
Old Mar 25, 2008 | 05:48 AM
doug's Avatar
doug
12.02 Afr = Boom
Old Mar 25, 2008 | 06:04 AM
XKR's Avatar
XKR
Very impressive !! Enjoy
I think Taurran is talking about me..because I am confused. 487whp @6.5 psi is insane considering that I have the same JWT 700bb. Our supporting mod are way different (example F-con) but still thats some crazy numbers.
Old Mar 25, 2008 | 06:20 AM
rcdash's Avatar
rcdash
Congrats on the build!
Spring pressure for 700bb turbo internal wastegates is ~ 9 psi. Mine was 9.3. Altitude must be affecting the spring pressure - can you confirm? Make sure you get tuned for higher psi if you plan on driving to lower altitudes, because pretty sure you'll be in the 9-10 range at sea level.
Old Mar 25, 2008 | 06:27 AM
XKR's Avatar
XKR
The answer to your question would help me understand the difference.
