JWT TT Kit, few questions prior to install.
Old Apr 10, 2008 | 06:15 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Default JWT TT Kit, few questions prior to install.
Just purchased JWT TT kit from another member on here.
It is essentially a tuner kit being shipped by Tim at SFR.
I previously had a turbonetics kit, but due to financial issues and switching jobs had to sell. I decided to just run low boost on a tt kit and have a great powerband. So most of my guestimates are based on my research on that kit. I will update this post with more pics of my install and eventually tune and final #s. I just got wise and jumped on the tt bandwagon.
I will be most likely using my UTEC "already installed" and the walbro 255 I bought off of luie.
The wastegates are set at 9psi which is perfect for me as that will be the max boost I would be comfortable running on a stock block rev-up.
What size injectors should i purchase?
https://my350z.com/forum/fi-faq-s/331868-basic-injector-information.html
... Thanks Jet for the write-up just found it. good info. Looks like Deatch 600s should be plenty, and still scalable.
I do not want to run too large and have scaling issues with the utec, but I also dont want to run out of injector duty or fuel at all.
I have an AEM UEGO & Boost, also a techtom that does intake temp and water temp. Any other gauge recommendations?
Is there really anything to be gained by doing a plenum spacer on a rev-up and FI?
Support Mods:
JWT clutch & flywheel
nismo exhaust
titek test pipes
Bored TB
Thanks,
Don
Old Apr 10, 2008 | 07:23 PM
rcdash's Avatar
rcdash
Gauges look good. No spacer needed with revup (to even out airflow).
Looks like you are set for a stock block set up. Always double check wtih your tuner/installer though... On a stock block at 9.3 psi 700bb tuner kit with no cats, you'll be pushing the limit of what you want to run on a stock block. Plenty of room to grow though.
B Esquire
Sep 24, 2015 07:52 AM
Ace2347
Sep 22, 2015 03:12 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
juang20
Intake
Sep 7, 2015 05:37 PM
