Random pictures from powerlabs turbo install
Old Apr 20, 2008 | 08:02 PM
  #121
Jay'Z's Avatar
Jay'Z
Originally Posted by diwun67
The kit comes with 550cc injectors, I just don't know what kind...
Ok, I was asking cause of the utec starts.. Looks like your going to have to blip the throttle since you have 550cc.. ..
Old Apr 20, 2008 | 08:10 PM
  #122
diwun67's Avatar
diwun67
I have 650's and I don't really need to at start-up
Old Apr 20, 2008 | 08:28 PM
  #123
jeffie7's Avatar
jeffie7
The kit list 550s but it comes with 600cc Once tuned it should run like a stock car.
Old Apr 21, 2008 | 06:34 AM
  #124
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by jeffie7
Dave, there's only 4 holes in the DP. 3 are for O2s, and 1 will be Wideband, (other o2 goes into the factory manifold on the passenger side) are you able to weld in another for the EGT? or will I have to take it somewhere?
Most EGT bungs are a thread in style. You will need to drill and tap a hole in the piping. You got the Defi's right?
Old Apr 21, 2008 | 12:05 PM
  #125
06MagneticZ's Avatar
06MagneticZ
any updates?
Old Apr 21, 2008 | 12:32 PM
  #126
G3po's Avatar
G3po
Once thats done, it should be ready to fire up.[/QUOTE]
Great pics.
So were does the coolant overflow tank now go?
Old Apr 21, 2008 | 12:50 PM
  #127
350Z400rwhp's Avatar
350Z400rwhp
I'll monitor it, if it becomes and issue I'll put one on, as of right now I don't plan to.
Awesome Thread! Thanks for the great pics and sharing all the info. I just wanted to add my 2 cents. I would recommend being proactive and doing that turbo blanket just because the way you might find out it is an issue is by an a/c line rupturing. You should also take this time to wrap your down pipe since it's even bigger then a Turbonetics (not sure if you have any extra room though) and in the same spot. Also firesleeve the a/c lines. I'm no expert but it sucks doing things twice. Anyway good luck and I can't wait to see your numbers!
Old Apr 21, 2008 | 12:55 PM
  #128
Ghost 350z's Avatar
Ghost 350z
Can you clean too :hugs:
Old Apr 21, 2008 | 02:51 PM
  #129
taurran's Avatar
taurran
Yeah. A turbo blanket won't hurt at all. He's right about wrapping and everything up front being easiest. I'm sure it'll be fine without all that though.
Old Apr 21, 2008 | 03:13 PM
  #130
superchargedg's Avatar
superchargedg
Damn Noobs
Jeff i would still heat wrap any wires or looms around or near the turbo or exhaust.This is just to prevent any problems down the road.....i know you are anxious to fire her up but double check and heat wrap anything near those hot parts.Do not use wire ties near heat as they will melt sooner then later go and get mechanics wire and wire them tight.
Old Apr 21, 2008 | 03:42 PM
  #131
jeffie7's Avatar
jeffie7
I can't think of anything off the top of my head to heat wrap that's around the turbo. however under the car where I used zip ties, the stock wiring was closer to the stock cats and had black zip ties, now its farther away from the piping and has zip ties, hopefully its ok.
I'm not sure if I'm going to mess with it tonight, in one of those, feels like sitting on my *** moods.
I'm going to try and do a hard reset on the utec then reinstall all the software and then try to upload a map again, if not more tech support for me tomorrow =(
Old Apr 22, 2008 | 07:20 AM
  #132
DanielW's Avatar
DanielW
^^no you can't do that. We are eagerly awaiting results. You owe us!!! haha J/K
Old Apr 22, 2008 | 08:06 AM
  #133
gothchick's Avatar
gothchick
Very impressive DIY! Congrats and good luck. :-)
Old Apr 22, 2008 | 11:12 AM
  #134
krnzzang84's Avatar
krnzzang84
so jelouse,,, congrate! my time will come!
Old Apr 22, 2008 | 05:24 PM
  #135
jeffie7's Avatar
jeffie7
spent about 2 hours on it tonight. Most of that time was trying to figure out how the hell to run my EGT/Wideband. sigh...
anywho, car fired up first turn of the key and ran fine, Itwas just a bit...ok well a good bit, rich, it dips slightly at startup but then runs fine. No leaks that I know of *knock on wood*
Still having an issue with the rad cap, its super tight and still rubs slightly. =(
also need to figure out where to mount that overflow tank, waiting for some more pictures from intense.
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/aIA5rlq2Qpk"> </param> <embed src="http://www.youtube.com/v/aIA5rlq2Qpk" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/Z93ogUKmouU"> </param> <embed src="http://www.youtube.com/v/Z93ogUKmouU" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Old Apr 22, 2008 | 05:29 PM
  #136
Ghost 350z's Avatar
Ghost 350z
niooooce!!!!!!!!!!!!!!!11
Old Apr 22, 2008 | 06:09 PM
  #137
G3po's Avatar
G3po
Default WB and EGT
Looks like a good place ot add a WB O2 bung abnd EGT port would be in tha up-pipe. EGT would read la little low.
Old Apr 22, 2008 | 06:52 PM
  #138
IIQuickSilverII's Avatar
IIQuickSilverII
OOH SHlT!!!!!!.....beast is alive
Old Apr 22, 2008 | 09:16 PM
  #139
SlideFox's Avatar
SlideFox
Niiiiiiiiiiiiiice!!!!!
Old Apr 22, 2008 | 11:15 PM
  #140
srt4-no more's Avatar
srt4-no more
Ballin jeffie.... simply ballin!
