Figured out reason for knock. PICS
Old Apr 16, 2008 | 02:17 PM
350 Rookie's Avatar
350 Rookie
Default Figured out reason for knock. PICS
alright so today i finally ripped up the bottom end. Let me tell you how suprised i was at what i found. The minor damage, i just need 1 new oil jet and an timing chain cover oil seal. The bad news, I got 6 bent rods. not 1, not 2, not even 5 but six.
anyways. here are pics.
This is the 3rd cylinder that i tested for compression and came up with 120. See how bent it is, this is the worst one.
Here are the rest of the rods. They are all bent but not that noticable in the pics
heres everything in peices
LASTLY, does anyone know if these hats have to be put in, in specific order or can they be put on any valve.
Thanx.
Old Apr 16, 2008 | 02:20 PM
SpoilsofWar's Avatar
SpoilsofWar
Thanx.
Stock rods fail. As bad as those look, you should have seen the bent rod I had in a spare hydrolocked engine I bought a while back. It must have been a 45 degree angle. And like happened to you, it had sheared an oil squirter off because of the bend.
And those cam buckets are specific to the valve they were on. If they came off and got mixed up, they will have to be measured for thickness and rematched.
The question is what were you doing to cause 6 rods to bend?
Old Apr 16, 2008 | 02:42 PM
350 Rookie's Avatar
350 Rookie
well my car is turboed. i mean i was expecting this to happen and i was saving up for a build but it just happened too soon. lol
alright, about the hats, do i measure diameter or measure the hat's wall's thickness. Diameter would make more sense. and what would be the difference in measurement in the hats and the hole in the head. thanx
Old Apr 16, 2008 | 02:50 PM
westpak's Avatar
westpak
SFZCC
you have to measure the height of the valve stem to match the bucket, best thing to do is get the Nissan manual
Old Apr 16, 2008 | 02:52 PM
Nexx's Avatar
Nexx
VQ35DE motor = teh butta.
Old Apr 16, 2008 | 03:58 PM
JonnyC's Avatar
JonnyC
What kit do you have? I haven't seen your other posts so I apologize. It's just good to know what torque numbers caused rods to bend like this
Old Apr 16, 2008 | 04:04 PM
pmohr's Avatar
pmohr
Did you mix them up when taking them off? If so, it's going to be a fun process getting all of the valves adjusted correctly again.
Old Apr 16, 2008 | 04:22 PM
QuadCam's Avatar
QuadCam
regarding the "lifters", there is a number on the inside of then. that is a metric measurement. also, the service manual lists the size of the lifters. there are about 26 different ones available. the different is in the thickness of the distance between the top of the lifter and the part that suts on the valve tip.
you'll need a 0-1" micrometer to accuraltey measure them.
Old Apr 16, 2008 | 05:16 PM
350 Rookie's Avatar
350 Rookie
i didnt take anything off the heads. I took the cams out and then i turned to motor around to take a look at something and they just slid out.
Old Apr 16, 2008 | 05:26 PM
westpak's Avatar
westpak
SFZCC
they are just held in by the cams so they will slide out
350 Rookie's Avatar
350 Rookie
im looking at the service manual right now but i cant find ****. lol
Old Apr 16, 2008 | 05:53 PM
thawk408's Avatar
thawk408
Check in Engine mechanical...then camshafts.
Old Apr 16, 2008 | 05:55 PM
westpak's Avatar
westpak
SFZCC
Section EM (Engine Mechanical) Page EM-72 Valve Clearance from the 2003 350Z Manual
Old Apr 16, 2008 | 05:58 PM
350 Rookie's Avatar
350 Rookie
ok i found it. Unfortunatly i dont have a micrometer so i gotta go pick one up tomorow.
Old Apr 16, 2008 | 06:00 PM
thawk408's Avatar
thawk408
I havnt looked at the manual in awhile, but each of those caps has a letter on them. If i remember correctly, there was a letter diagram that told you where to put the caps.
Old Apr 16, 2008 | 06:12 PM
350 Rookie's Avatar
350 Rookie
actually, now takin a look at the manual, it tells you the valve lifters id number and thickness. It doesnt tell you where it goes. How would i find this out.
Old Apr 16, 2008 | 06:14 PM
350 Rookie's Avatar
350 Rookie
em 72 is not it.
Old Apr 16, 2008 | 06:16 PM
westpak's Avatar
westpak
SFZCC
the page depends on the year Z manual you have.
read the section, basically you put them in and install the cams, then measure the clearance, then you take the cams out and measure the lifters then you add or subtract how far you are from the proper clearance and get the new lifter thickness needed for the proper clearance.
maybe you should have a shop do it
Old Apr 16, 2008 | 06:26 PM
350 Rookie's Avatar
350 Rookie
man, i didnt come this far to have a shop do it. haha.
it cant be that hard, im just a little confused on how to figure out their spots.
Old Apr 16, 2008 | 06:32 PM
failsafe306's Avatar
failsafe306
When you get the lifters figured out, don't forget that the cam brackets have to go back in the right places, too
