**HALTECH Review-Stock Block 12 PSI w/ Meth**
Old Apr 19, 2008 | 08:15 PM
Peak350's Avatar
Peak350
I'm asking a dumb question and not searching, but I assume the haltech is wired in like a piggyback although its working alone in controlling the motor? Or is the valve timing still on the OEM?
Old Apr 19, 2008 | 09:56 PM
THE ROADSTER's Avatar
THE ROADSTER
Originally Posted by Tyler4
100% Meth. The kit fits my needs just fine for now but i added the big tank. I think it starts spraying at 6/7 psi. There is plenty info on meth set ups on the boards.
wow you run 100% meth, must be very corrosive. I run 50% meth/50%water and the metal lid on the resevor is all corroted.
Old Apr 19, 2008 | 10:35 PM
Nexx's Avatar
Nexx
thanks for the review! i have so much confidence in sharif. reading this makes even more happy i went with the haltech and makes me even more anxious to get my car back from forged.
Old Apr 20, 2008 | 04:26 AM
MR RIZK's Avatar
MR RIZK
Originally Posted by Jay'Z
Ok.. Nevamind then... 440cc is prob the contributor...
Running PE510's startup is no issue with the haltech for me.
Old Apr 20, 2008 | 04:32 AM
rcdash's Avatar
rcdash
Intake and revup exhaust valve timing is controllable by the Haltech. The Haltech (in the standard plug and play setup), leaves creature comfort and drive by wire controls (namely throttle) to the stock ECU (which therefore must remain in place).
Old Apr 20, 2008 | 06:26 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
The biggest difference is the smoothness. With the Haltech, driving the car is like driving a factory turbo'ed car. Half throttle lett off's are so smooth.This is where the difference is notice most. Overall, it makes the car soo much more enjoyable to drive, and that in itself makes it worth every penny.
Yep, thats what I loved when I went fromt eh UTEC to the Haltech. MUCH smoother, no problems at all.
On the other hand, 12 PSI on a stock block!!! But I read that you are prepared for an engine build, so it's allright, I guess.
Anyways, congrats on the Haltech and the great numbers.
Old Apr 20, 2008 | 07:04 AM
Peak350's Avatar
Peak350
Great to hear that, so basically everything but the throttle is controlled by the haltech, but all the can bus features, gauges etc. still work without a bunch of issues.
Old Apr 20, 2008 | 07:09 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Only issue that the Haltech has (that I have found) is that it will throw a P0011 and P0021 code after about 100 miles. These are intake valve codes that the ECU is throwing since it is not seeing the intake valve values it is expecting to see.
As I understand it, Haltech is working on this.
Old Apr 20, 2008 | 07:16 AM
XKR's Avatar
XKR
But he is using 100% Meth....so he is basically running race fuel equivalent...so he should be fine.
rcdash's Avatar
rcdash
They are still working on doing more over the stock CAN bus. An alternative for the CEL issue is to do an Osiris reflash. Would be nice if the Haltech could intercept any CEL the ECU wants to throw and kill it though.
Old Apr 20, 2008 | 07:17 AM
rcdash's Avatar
rcdash
Well he won't detonate so the METH will definitely help, but those stock rods are probably seeing close to 500 wtq on a dynojet.
Old Apr 20, 2008 | 07:23 AM
XKR's Avatar
XKR
I hope he keeps that in mind
Old Apr 20, 2008 | 08:01 AM
westpak's Avatar
westpak
SFZCC
with 440's the car almost has not issues starting with the stock computer get 1000's and then come back
Old Apr 20, 2008 | 08:02 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yeah, not really willing to pay $700 for the Osiris reflash to just get rid of a CEL that comes on every 100 miles or so. Hopefully Haltech will solve this. Preferably, it would be configurable within the interface to tell it to ignore certain CEL's.
Old Apr 20, 2008 | 01:44 PM
Tyler4's Avatar
Tyler4
Ha! Yea, i know i am "playing with fire" with the amount of power i'm running. But as long as it makes it through the summer, i will be fine because i'm building in the fall. If it doesnt, then i guess i will be building early.
Old Apr 20, 2008 | 05:31 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Exactly. There are very very few stock blocks that we tune past 10psi, but when customers are ready to build their engines, at THEIR request....we'll kick it up a notch.
It's been fun working with your Tyler...enjoy!
Old Apr 20, 2008 | 05:32 PM
Sharif@Forged
Forged Performance
That's 100% correct.
Old Apr 20, 2008 | 05:53 PM
  #38
Tyler4's Avatar
Tyler4
Same here man. BTW- I downloaded the driver and everything is running good.
Now, lets just cross our fingers the rods hold up for the summer
Old Apr 21, 2008 | 06:37 AM
  #39
TTRANK's Avatar
TTRANK
When I had 440's my UTEC starts were just like stock. Now that I have 750's it's way different.
Old Apr 21, 2008 | 06:56 AM
  #40
Sharif@Forged
Forged Performance
wow..I can only imagine. Usually, the 440's start up pretty cleanly. The 550's and up can be hit or miss. Some start perfectly, others struggle a little bit.
