thinking about putting greddy twins on VQ35HR
From my understanding the manifold bolt pattern is the same. I'm not sure how clearances will work down there, but they should bolt up.
Obviously you will need a custom intercooler with dual outlets, and custom intercooler/intake piping.
Greddy is coming out with an actual kit for the HR sometime this year so you might just want to wait for that.
Originally Posted by turismo
ibtl. The HR is the weakest motor of all 350z versions. Dont do it, itll be a disaster.
Originally Posted by Audible Mayhem
we are tuning our HKS twin turbo HR on tuesday...
we will let you know how strong it is...
I'm curious what kind of numbers you see at 8 psi, wondering how efficient the head will flow.
I think the real answer is, in theory most of the core components should work (bolt patterns etc). But in practice, the HR is layed out a little differnt (coolant hoses etc etc) and may prove to be difficult. I think that with the the fact that GReddy is taking so long to release the HR kit, means that there are little more then small hurdles to overcome...
If you are looking for a definitive answer, you must be the guiney pig and try it out yourself. No one else has.
Originally Posted by Peak350
Using the fcon pro I assume.
its performance factory
think bigger
in the hr with turbo set up do you have loose any parts to make room for the tt kit? in the greddy expo they showed an hr with aout a strut bar to make room for the pipes.
Originally Posted by ryanschram
I'm still new in the forums and z's, but from what CIN says, the hr is stronger than the de.
