Looking for Oil Catch Can for my Vortech.....oil in ic pipes
Old May 22, 2008 | 07:20 PM
350Z400rwhp's Avatar
350Z400rwhp
You can always hook up 4 hoses to 1 catch can, thanks for that diagram, I might add a couple of extra hoses to get it from the driver's side also.
Old May 22, 2008 | 07:45 PM
Barzten1's Avatar
Barzten1
I had the Helix catch can mounted behind my SSV with the Vortech and in between the radiator and motor with the Greddy kit. Taking off that charge pipe with a Koyo radiator is even worse
Old May 22, 2008 | 07:51 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what im saying about the 4 hoses is that it may effectively short circuit the motor out the flow path. Dont know the exact words to use, im not a ME or fluid dynamics person. Get the idea though?
The pcv may be allowed to suck air directly from the intake and no longer through the crankcase. Thats not how the original system worked.
under light throttle:
Air comes in the intake, travels through the hose that connects the intake to the lg valve cover. From the left hand valve cover it looks like it goes through the crank case to rh valve cover. It then exits the rh valve cover into the PCV which lets the air flow into the upper plenum. The valve covers are also connected by a hose as well.
under heavy throttle:
oil comes out the intake hose from the lh cover into the intake. Everything else is the same essentially.
Old May 22, 2008 | 07:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
that front charge pipe is already a PITA. Found out you have to shuffle it around to put an ac belt on............FTL!
Old May 22, 2008 | 10:05 PM
gothchick's Avatar
gothchick
home depot special. been running this for about a year now... very effective. :-)
Attached Thumbnails Looking for Oil Catch Can for my Vortech.....oil in ic pipes-dsc02359.jpg   Looking for Oil Catch Can for my Vortech.....oil in ic pipes-dsc02361.jpg
Old May 23, 2008 | 04:49 AM
05Z33's Avatar
05Z33
Same here. It works great, and I love the steal braided hoses you got.
Old May 24, 2008 | 12:27 AM
Midnight Ryderz's Avatar
Midnight Ryderz
dude im telling you i had the same problem and it blew my MAF and all take the filter off and see it theres oil there if there is send it back to vortech im serious becasue you can really **** yoru car up. And no you wouldn'tr be blowing smoke becaue its not enough into the intake manifold but im tellign you send the blower out
Old May 27, 2008 | 07:31 AM
jpc350z's Avatar
jpc350z
If you are seeing oil on the sway bar then it is likely coming from the blower shaft seal gone bad. I had this happen also..Need to get it to Vortech for seal replacement..
Old May 27, 2008 | 07:34 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I honestly dont think its my seal. After 6k miles youd assume some blowby to happen. The amount of oil wasnt that much. once i get the catch tanks installed, if i see more oil ill contact vortech. Im not too worried....got 4yrs left on my warranty with them.
Old May 27, 2008 | 10:03 PM
Midnight Ryderz
i woudl pull the filter off and see if theres oil there is there is get it to vortech TRUST ME
Old May 28, 2008 | 06:08 PM
express705's Avatar
express705
wrong about the greddy.
im selling it if anyones intrested.. i got a different one.
Old May 28, 2008 | 06:09 PM
express705's Avatar
express705
hah yea i JUST put my vortech in the box to be sent in for new seals.
hopefully itll be quick.. 1 week without my car is going to kill me.
Old May 29, 2008 | 05:55 AM
jpc350z's Avatar
jpc350z
What were the symptons?
Old May 29, 2008 | 07:55 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
not to be a hater, but thats not properly installed in my opinion. What are you going to do when you accumulate oil into the catch can a take a hard left turn and all the oil sloshes back to the in and out lines?
also, it wont solve the blow by issue into your intake. See my pic and description above about what happens under boost.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
