2006 Touring 5AT DynoJET
Old May 11, 2008 | 09:12 AM
maXmood's Avatar
maXmood
Under Boost!
Default 2006 Touring 5AT DynoJET
bone stock, done on DynoJet, and only 1 run..
the car is full of dust and the periodic service is due, but i still didn't take it for service..
Model: 2006
Trim: Touring
Transmission: 5AT
Milage: 12k
how good is my run? what is the average for 2006 stock 5AT runs? what do you suggest i do next?
the mechanic told me i'm running lean. what does it mean? how good/bad is it? what can i do about it?
i have a Stillen CAI waiting to be on.
comments plz..
thnx
<!-- / message --><!-- attachments -->
Old May 11, 2008 | 10:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
This is the FI forum, wrong section
Numbers are low for an auto, and yes your are leaner than ideal.
Old May 11, 2008 | 11:00 AM
c3 rolling's Avatar
c3 rolling
thats loowwwwwww
Old May 11, 2008 | 01:14 PM
maXmood's Avatar
maXmood
Under Boost!
alright.. 42 views, and 2 posts only?
i'm actually looking for more than comments. can i have some input please?
wrong section? i couldn't find any appropriate section for the dyno.. sorry if it is.
Old May 11, 2008 | 02:42 PM
ekelly36's Avatar
ekelly36
bone stock Z should dyno around 228 to 230 Whp.... you need to do a full tune up and you should notice a difference.... your graph looks bad man.... all those spikes and drops... it should be alot more linear... Depending on how many miles you have.... I would run a seafoam treatment to clean out the injectors and your combustion chamber.... replace your plugs with some Denso Irridiums or something equivalent and put the cold air intake on.... just my thoughts.....
Old May 11, 2008 | 02:52 PM
Nexx's Avatar
Nexx
expect to lose a little with the cai.
Old May 11, 2008 | 04:45 PM
350Z400rwhp's Avatar
350Z400rwhp
+1 Just do a K&N filter replacement.
Old May 11, 2008 | 05:05 PM
wannabuy350z's Avatar
wannabuy350z
just to turbo...
Old May 11, 2008 | 05:19 PM
stein's Avatar
stein
Your numbers should be a bit higher for sure. I haven't dyno'd mine since I've only got a pop charger and Nismo exhaust, don't have the mod, maybe because she's an auto...? Anyways, clean up you air filter, change your plugs, and get an exhaust to help it breath better. Other than that maybe a spacer.
Old May 11, 2008 | 10:24 PM
pimpsahab's Avatar
pimpsahab
My 06 Auto put down 256whp with I/H/E and a UTEC tune..so im guessing 23X whp stock
Old May 11, 2008 | 10:45 PM
maXmood's Avatar
maXmood
Under Boost!
thnx for the input.. actually the graph were better, but he pressed on Smoothing "altho it's zero" but the graphs changed to the currently attached.. (btw, i don't know what smoothing does, but i noticed the graphs changed when he pressed on it).
i wasn't shocked at first, cuz i knew that it's not ready for a run, but later i was reading here and there and i noticed that stock Zs get around 225-235 whp. soooo, for sure i'm taking it for service to get things cleaned, and i'll drop in the CAI..
i'm still unaware of "running lean"... what does it mean? how good/bad is it? what can i do about it?
Old May 12, 2008 | 09:34 AM
wannabuy350z
running lean, simply means the air+fuel mixture is not ideal for an NA engine. like you have bad injectors. not enough fuel is getting delivered.
Old May 12, 2008 | 09:54 AM
Alberto's Avatar
Alberto
Cranky FI Owner
CAI = lose power over stock
Its been proven with dynos and 1/4 times, when will people realize this ughhh
Old May 12, 2008 | 09:58 AM
Ilov350ZEE's Avatar
Ilov350ZEE
/\ i didnt know that, what about JWT PC?
Old May 12, 2008 | 10:02 AM
Asian Invasian's Avatar
Asian Invasian
Wow thats corrected? I thought mine was bad at 242.
Old May 12, 2008 | 11:00 AM
maXmood's Avatar
maXmood
Under Boost!
i'm actually planning to go FI.. and i'll update this thread once i add more mods to the car.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
Jambo016
Sep 16, 2016 01:08 PM
