Bottle neck?
Old May 14, 2008 | 04:24 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Originally Posted by iamdigital
so do i. when i pull up to people (vettes) they just look like WTF? combine that with open dumps and it's insane noise **** for the ears. doesn't touch the Ferrari note but it's sexy
LOL nice yeah I stayed away from the open dumps, little much for my liking. Might do it later down the road and get the electronic cutouts to open/close
Old May 14, 2008 | 05:06 AM
coachk's Avatar
coachk
Originally Posted by str8dum1
did you just use a tail pipe expander to do that??
Yes...it took all of 5 minutes to do.
Old May 14, 2008 | 05:09 AM
coachk's Avatar
coachk
Originally Posted by Zivman
When you swapped out for the greddy, how much boost increase did you see? I doubt you made 35 hp at the same boost levels?
It was when I had the Unichip and the boost level was at 9.5 psi. Same boost levels before and after the swap. I believe the majority of the whp increase was because of the bigger test pipes.
Old May 14, 2008 | 06:48 AM
Zivman's Avatar
Zivman
That doesn't really make sense. If the exhaust flowed that much better, you would see an increase in boost pressure. The unichip just works on a gain adjustment, don't think you can dial in at '9.5 psi'. What did your AFRs look like? With a free'er flowing exhaust, your AFRs would lean out a bit without a retune
Old May 14, 2008 | 09:59 AM
coachk's Avatar
coachk
I guess what you're saying makes sense but I'm sure the 9.5psi was the same before and after the exhaust/test pipes change so it may have been a more aggressive tune which enabled the higher whp. It was a couple years ago so I really don't remember the specifics but I do remember the whp numbers that I stated to be correct
Old May 14, 2008 | 11:04 AM
Zivman's Avatar
Zivman
Retune would explain it...
Old May 14, 2008 | 03:09 PM
coachk's Avatar
coachk
By having more flow from the bigger testpipes/exhaust, would that give a tuner more room for a more aggressive tune (i.e. A/F 12+) because of the increased flow
Old May 14, 2008 | 04:39 PM
Zivman's Avatar
Zivman
I don't pretend to know tunning. My guess would be you could possibly run a bit more timing and due to AFRs leaning out with a free'er flowing exhaust, you could add more fuel back in (more air and fuel = more power)
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
hfm
Apr 14, 2003 02:30 PM
grayfox
Mar 27, 2003 12:10 PM
