Greddy Oil Seals Leaking????
Old Sep 19, 2008 | 03:06 PM
  #41
Snow-G's Avatar
Snow-G
Iono man, but it still catches oil and I dont get any smoke. + He is my tuner/engine builder so I'll take his word for it.
As I understand it the valve is closed under open throttle and open at idle. So if the return is connected to the plenum... that is why you are getting oil and pressurizing the crankcase.
Old Sep 19, 2008 | 04:39 PM
  #42
rcdash's Avatar
rcdash
That will still work since the crankcase pressure can never rise above atmosphere. You just cannot assure the direction of flow. Blow by gases under boost still get vented, but in this case, the driver's side vent can release oil directly into the engine bay (unless you have another catch can for that). The only point of having suction at one end is to create directional flow so that clean air comes in and the oil vapor goes out to the catch can.
Old Sep 21, 2008 | 04:34 AM
  #43
Snow-G's Avatar
Snow-G
^^Right! No oil in the bay here...just check the can like usual.
Old Sep 21, 2008 | 05:30 AM
  #44
NETSHARK's Avatar
NETSHARK
I Got a GReddy Catch Can and i`ve drilled it for an additional line, so now new line is connected to the Intake, the other two lines one is connected to the Driver side and the other one is to the PCV valve on the pass side and i`ve capped the Lower Plenum, is this a bad idea ? my setup is similar to the ARC Catch Can so am i on the OK side ?
Old Sep 21, 2008 | 06:00 AM
  #45
NETSHARK's Avatar
NETSHARK
Just saw your Vacuum Routing Diagram Raj, i like the way you`re thinking very Nice/Neat Design !! but am gonna modify yours to suit my GReddy Catch Can with 3 holes lol
Old Sep 21, 2008 | 10:20 AM
  #46
JET MECH's Avatar
JET MECH
i elaborated on this topic awhile back but you guys also know that negitive pressure/vacume on the crankcase is needed for positive piston ring seal. all who are running either the pcv side or the drivers side to the atmophere have induceed a "open loop" in there pcv system. some drag racers actually install electric or engine driven vacume pumps for the reason of keeping constant vacume on the crankcase. dyno results have shown increased power and less oil contamination/consumption due to better piston ring seal. the 03-04 svt cobra mustangs with the 32v s/c engine actually come factory with a electric driven vacume pump for this very reason. hotrod magizine did a article on crankcase scavenging and the positive effects of constant vacume on a crankcase. on one of there test engines they ended up picking up 5 hp due to applying constant crankcase vacume. i myself have played around with many crankcase vent setups "many of which some of you are running now". but the setup i am now running seems to work best of all the variants i have tried before.on the right side of the engine where the pcv valve was i am running a crank plug which delets the pcv valve "open fitting". from there i am running the line to a elitee engineering catch can then from there i have a line running to inlet side of the s/c just aft of my air cleaner tapped into my velocity stack, from the drvers side i have installed another catch can setup in the same manner " dual catch cans closed system" the s/c inlet provides a source of constant negitive pressure for the crankcase whether in idle, cruise or boost configuration. i have noticed less oil contamination between oil changes and less oil consumption as well with this setup due in part to better piston ring seal. also with this setup i do not have to worry about running additional check valves or having a pcv valve possibly sticking open under boost and pressurizing the crank case due to the line being plummbed back into the lower plennum. just my
Old Sep 21, 2008 | 12:36 PM
  #47
weslutes's Avatar
weslutes
So you plugged your lower plenum, routed both crank case vents to an oil catch can, then to an area between the MAF & air filter?
Old Sep 21, 2008 | 01:10 PM
  #48
NETSHARK's Avatar
NETSHARK
JET MECH, ur idea is same as ARC Catch Can but ur using 2 cans, i`ve drilled an additional hole into the GReddy Catch Can and routed it into the Intake and the other two lines go to PCV,Driver Valve Cover. and of course capped the Lower Plenum. i guess this setup works close to OEM Specs
Raj,
i`ve looked more into your Diagram its good, but you`ve missed one thing, you addressed the Intake line with a Check Valve to prevent the lower plenum from sucking Un-Metered Air, but what about the Air coming from the Small Breather Air Filter on the Driver Valve cover then going into the Line between the Two Valve covers, finally Exiting the PCV valve and going to the lower plenum, this is still UnMetered Air, your setup is good but you should caping off the lower plenum totally, this way you will still draw fresh air from the Driver side cover exiting from the PCV and u`ll catch the containments on the Catch Can and the Turbo`s will still suck Vacuum from the out line of the Catch Can helping the small breather air filter to suck more fresh air
Old Sep 21, 2008 | 01:22 PM
  #49
JET MECH's Avatar
JET MECH
blocked off lower plenum fitting, installed a catch for each side "dual catch cans", then plumbed each line exiting the catch cans to the inlet side of the supercharger. i have periodicaly checked my intercoller and plumbing for residual oil and none has been found ,this setup is working superbly!! all other setups i have configured has netted some type of oil in the ic,ic piping or the plenum. now there there is no oil to be found in these componets as well as my oil stays cleaner longer with nearly no oil consumption between oil changes. i am going to try and post some pics, i think that will explain things better.
Old Sep 21, 2008 | 04:36 PM
  #50
JonnyC's Avatar
JonnyC
I'm trying to figure out what to do about this for the STS kit. There's no source of vacuum under boost unless I would run a line all of the way back to the turbo inlet. Maybe I should start looking for a vacuum pump like you were talking about JET?
Old Sep 21, 2008 | 04:48 PM
  #51
rcdash's Avatar
rcdash
Netshark, you are right, since the driver's side vent on my setup is an open breather, I am drawing in unmetered air. That's ok for me since I'm not using the MAF; MAP only setup here. I should have made a point to mention that - sorry about that - tunnel vision.
Jet Mech, the problem with turbos is that just behind the filter, there is very little vacuum at idle (because the throttle body is nearly closed). I like the concept of vacuum all the time on both sides and I tried to implement this with another port in the catch can, but that's when I had a little disaster. It wasn't in the design, but I had the hose going to the plenum kink after it got hot (wasn't using R7 or R9 fuel injection hose) and crankcase pressure had no place to go at idle. I was just sitting there watching my car idle and saw the pressure gauge I had rigged (yes I actually had one in the engine bay for catch can pressure) drop to 0. I was like WTF - where did my vacuum go? I didn't know what was going on. Less than 10 seconds later my car turned into the space shuttle at idle. Bad, bad, bad... So I decided to redesign so that the driver's side breather was my "safety release" in case anything went wrong anywhere else. The bottom line is if you experience more blow by than the evac system can handle, you will pressurize the crankcase. Any closed/sealed system faces this risk. By having the driver side breather, I can pretty much guarantee the crankcase will never pressurize. If you want to be sure you are not drawing in unmetered air, connect the driver's side to the intake, post-MAF. The only downside is that you may end up blowing oil into the intake system though that usually shouldn't happen. In fact my driver's side breather (and surrounding engine bay) has remained relatively clean and oil free - so I presume I have not overloaded the evac system thus far.
With twin turbos, we can draw vacuum from the exhaust pipes with a properly designed nipple, but no other source is constant that I can think of... So you have to use 2 sources. Plenum at idle and intake after air filter during boost.
Old Sep 21, 2008 | 04:51 PM
  #52
rcdash's Avatar
rcdash
Air inlet should still be a vacuum source under boost - not familiar with the kit's design (other than being remote mount) so not sure how hard it is to tap between the air filter and the compressor inlet.
Old Sep 21, 2008 | 05:15 PM
  #53
JonnyC's Avatar
JonnyC
Yeah - I'd just have to run a rather large hose all of the way back there. Might do it though.
Old Sep 21, 2008 | 07:36 PM
  #54
rcdash's Avatar
rcdash
Are you boosted? Regardless, just using the intake provides very little vacuum while idling. Crankcase pressure can release though into your intake. It'll work, but you are just not applying much vacuum and you're not ventilating the crankcase. I will say that it might work better than one might expect because of the way the PCV is designed (a PCV valve is more than a simple check valve - it flows MORE with moderate levels of vacuum and flows less at high vacuum, such as at idle). If you have no oil leaks, no oil consumption, and not having to drain your catch can too often, then it sounds like you're fine.
Old Sep 24, 2008 | 08:19 AM
  #55
SpoilsofWar's Avatar
SpoilsofWar
Originally Posted by IslandZavage
any pix available?
Here you go. Sorry for the delay, took me forever to find the damn camera cable.
PCV valve -> catch can -> check valve -> intake plenum
Drivers side valve cover -> breather filter
Old Sep 24, 2008 | 10:04 AM
  #56
rrmedicx's Avatar
rrmedicx
The check valve is a one way valve, restricting air flow in one direction or does it act like a simple filter? If it is a 1 way valve, which way are you allowing the air to flow?
Old Sep 24, 2008 | 01:51 PM
  #57
SpoilsofWar
Its a one way valve, air can only flow from the catch can towards the plenum. This prevents boost from getting to the PCV valve.
Old Sep 24, 2008 | 03:03 PM
  #58
doug's Avatar
doug
i missed it, but where did you get the check valve?
Old Sep 24, 2008 | 03:10 PM
  #59
SpoilsofWar
Ebay.
Its a 3/8" check valve, you want to look for something with a relatively low cracking (ie. opening) pressure so that the vacuum from the plenum will open it, but able to withstand whatever boost pressure you run plus a cushion so that it will be able to stop positive plenum pressure from getting to the PCV valve when you are boosting. Oil/fuel resistance of the diaphragm is also important as some of those substances are bound to get by the catch can.
I got this one from an ebay vendor who sells parts for those questionable hydrogen assist or whatever setups. Works great. It was ~ $.99.
Old Oct 5, 2008 | 02:54 PM
  #60
JonnyC's Avatar
JonnyC
Bringing this back up...
Spoils - do you not have any idle issues, such as a high-idle or other symptoms of a vacuum leak? With the breather on the driver's side crankcase, you would think the intake manifold would be able to suck in a decent amount of unmetered and unregulated air through the passenger side PCV.
I actually just went ahead and purchased some check valves like you have from here - http://www.usplastic.com/catalog/var...riant_id=64175
