Having problems with cooling system
Old Jun 29, 2008 | 02:15 PM
rr_z33's Avatar
rr_z33
Default Having problems with cooling system
Okay so this is what happened. My car has been running pretty hot lately. its not only when i boost it but also when i just run the car under normal operating conditions for a while. so yesterday i decided to purge my coolant system. i followed the proper procedures but i noticed that nothing was coming out of the bleeder valve. i went to feel if it was just air coming out but i couldnt really feel anything coming out. i let if run for a while i sat in the car while i was doing this. then i just see coolant shoot up out of the overflow tank. turn the car off immediately. get up front the overflow tank is completely filled. im assuming that this is just a hell of a lot of air in the coolant system but was looking for second opinions.
Old Jun 29, 2008 | 03:18 PM
i8acobra's Avatar
i8acobra
Sounds like a bad radiator cap. Your system isn't holding pressure.
Old Jun 29, 2008 | 04:30 PM
RED RIDER's Avatar
RED RIDER
REMOVE the thermostat, bleed system with a radiator funnel and then be done with it...
Old Jun 29, 2008 | 06:15 PM
turismo's Avatar
turismo
+1
Old Jun 29, 2008 | 09:11 PM
rr_z33's Avatar
rr_z33
thats actually what my tuner down here was saying.
Old Jun 29, 2008 | 09:13 PM
surfcity40's Avatar
surfcity40
It sounds to me like a bad thermostat, and since you're gonna replace it anyway, I'd replace it with one that has a "slightly" higher threshold.
Old Jun 29, 2008 | 09:17 PM
rr_z33's Avatar
rr_z33
the thermostat was actually just recently replaced.
Old Jun 29, 2008 | 09:41 PM
Mr_pharmD's Avatar
Mr_pharmD
I know ill get flammed but this is how I did when I changed to a koyo radiator. I filled the radiator with coolant/water and then open the air bubble valve to let the air bubbles out until there was no more visible bubble (might have to do this for about 10-15mins). Then I would leave it slightly open and drive around the block at different rpms and just let the coolant spill out from the open air bubble valve. Once u get back home pop the hood and close the air bubble valve completely and basically u should be air bubble free. U will have to fill up some water in your coolant tank but that is normal.
Old Jun 30, 2008 | 06:19 AM
06Track's Avatar
06Track
Also, be SURE you heater is on and set to the highest setting to make
sure coolant is flowing thru heater core.
Uriyo_
Sep 8, 2021 08:46 AM
