FI oil pressure?
Old Jun 30, 2008 | 05:19 AM
keznevin's Avatar
keznevin
Default FI oil pressure?
Just wondering what the average oil pressure is for a turbo 350z. Will it drop with all the new oil lines?
Old Jun 30, 2008 | 06:14 AM
06Track's Avatar
06Track
I have a built motor and APS TT and at idle (900 rpm) I have 35 lbs hot and
when running hard 70 lbs + hot. I have an ARC oil cooler that sits on top of the
bumper and run 15 - 50 Pennzoil Platinum. Temps here are in the 90s and
those figures are for this outside temp.
Old Jun 30, 2008 | 12:09 PM
Jay'Z's Avatar
Jay'Z
30@idle.. 60-120@wot.. 10w40 mobil 1..
Old Jun 30, 2008 | 12:13 PM
SpoilsofWar's Avatar
SpoilsofWar
Built engine with race bearings, about 25psi idle (hot), 60-75psi at WOT, Anywhere from 60-90 on cold start up depending on ambient temp.
edit: forgot to mention I have been using 10w-40 castrol GTX for break in
Old Jun 30, 2008 | 12:14 PM
rcdash's Avatar
rcdash
120
I see 20-30 low load, 60-70 high load Motul 15W-50
Old Jun 30, 2008 | 12:18 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by rcdash
120
Yep, i could be off.. but my memory does serve me correctly most of the time..
Old Jun 30, 2008 | 01:40 PM
keznevin's Avatar
keznevin
Thanks Guys This Helps Alot.
Old Jun 30, 2008 | 03:18 PM
JonnyC's Avatar
JonnyC
Eek - I think mine's around 60 at idle, warm, using GC 0w-30, stock motor. Maybe I'll have to check again to be sure...
Old Jun 30, 2008 | 03:55 PM
SpoilsofWar
Stock motors are bound to see higher oil pressures then most of our built motors due to tighter clearances. However, 60psi at hot idle would still be higher then I would consider normal.
Old Jun 30, 2008 | 06:55 PM
SC 350Z's Avatar
SC 350Z
at the least 20psi at low rpm's and the highest maybe 90 when i was FI'D
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
