PCV has Hole In It
Old Jul 2, 2008 | 04:57 AM
QuadCam's Avatar
QuadCam
doesn't greddy include an OEM nissan check valve in their kit?
Old Jul 2, 2008 | 05:35 AM
westpak's Avatar
westpak
SFZCC
they provide a valve for the brake booster line
Old Jul 2, 2008 | 07:14 AM
rcdash's Avatar
rcdash
Doesn't the brake booster line contain a check valve in the OEM configuration? Why does Greddy add another?
And I had read that APS now uses an electronic solenoid of some kind rather than a mechanical check valve... not sure why they felt that was necessary as most simple check valves are rated to 150 psi.
Old Jul 2, 2008 | 07:37 AM
QuadCam's Avatar
QuadCam
I don't know either. The stock brake vacuum line has a check valve in it. I didn't use the supplied check valve with my gredy kit. it is probably rolling around my garage floor somewhere.
Old Jul 2, 2008 | 08:38 AM
Hoooper's Avatar
Hoooper
i know how that goes. sometimes i feel like if i sold all the unused parts in my garage i could buy myself a whole nother car
Old Jul 2, 2008 | 10:38 AM
Zivman's Avatar
Zivman
You just jumped the guard rail and plowed into the ditch. The solenoid/check valve you are referring to in the post above is related to their single turbo and the oil feed to the turbo.
The check valve you were referring to orginally is used to keep boost from leaking into the crank case
****Long story short, the oem PCV valves generally leak when you exceed 9 psi of pressure... at least this is what I was told. You can get the APS check valve from an authroized dealer, like MRC or Z1. I got mine through GRD over a year ago. This isn't a new topic and has been discussed before
Old Jul 2, 2008 | 11:20 AM
rcdash's Avatar
rcdash
Ah well, that clarification is helpful! Interesting that they require use a solenoid for oil supply...
Old Jul 2, 2008 | 12:54 PM
SC 350Z's Avatar
SC 350Z
rcdash so what you are saying is from your catch can on the pass side run a T then a cheack valve on both ends of the T take one to your intake pre turbo or supercharger(procharger) and the other to your plenum?
Old Jul 2, 2008 | 01:26 PM
Zivman's Avatar
Zivman
They have to use some sort of solenoid because of how low the turbo sits. If they did not, the oil would continue to gravity feed to the turbo even when the motor is not running
Old Jul 2, 2008 | 01:31 PM
Glex25's Avatar
Glex25
Do you have a link to that on the APS site i was looking all over for it
Old Jul 2, 2008 | 01:49 PM
Zivman's Avatar
Zivman
APS part number 000-990-300 VALVE - ONE WAY - PCV
LINK... Refer to item number "17"
Old Jul 2, 2008 | 02:42 PM
SpoilsofWar's Avatar
SpoilsofWar
Any reason you couldn't just use one of the OEM Nissan brake booster check valves off a Z32? That one is a clamp is design similar to the APS, as opposed to the one that is internal to the hose on our cars. Don't know how much the APS piece runs, but the nissan valve is ~$20 from courtesy parts. I'm willing to bet thats cheaper then the APS, and would probably get to you faster.
Old Jul 2, 2008 | 07:44 PM
rcdash's Avatar
rcdash
Yep just double check the valves are in the right direction, AWAY from the catch can (I actually blew air with my mouth through the lines before hooking it up to the T).
I also highly recommend just a breather on the driver's side vent. That is your safety net in case there is build up in the crankcase for whatever reason (like you use low grade hose and it collapses - use SAE30R9 fuel injection hose if you can get it, though I used SAE30R7 and it seems sturdy enough and it's 1/4 the cost per ft.).
Old Dec 13, 2008 | 01:44 AM
Havok_RLS2's Avatar
Havok_RLS2
Check valves LOOK!
http://www.airpowersystems.com/guide...-tts07/bom.htm
$20 from courtesy parts =
http://www.courtesyparts.com/kb_sear...utton=Go&cat=1
1. [47478] VALVE ASSY-CHECK - Product SKU: 47478-Z32001
2. [27461M] VALVE-CHECK - Product SKU: 28628-Z32001
OR:
http://www.partsgeek.com/gbparts/199...ek+Google+Base
Old Dec 13, 2008 | 08:52 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
****!! I never knew this!! Was this valve added later on by APS? No wonder my upper and lower plenum is collecting blow by oil.
Jetpilot, rcdash and everyone else, great discussion!! Jetpilot, I can't wait to see your complete setup! Keep us posted whether your setup completely eliminates crankcase pressure and blow by gas...
apex locator
Jul 23, 2021 02:27 AM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
kyin
Oct 15, 2015 05:54 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
