Larger Fuel Injectors
Old Jul 1, 2008 | 04:31 PM
turtle1678's Avatar
turtle1678
Default Larger Fuel Injectors
Hey guys I have a question I have a 03 with a vortech and I have a basic AAM fuel return and walbro. I bought DeatschWerks 600cc injectors and was wondering when I install them will the car run. I have the SS box now but will be installing a Utec in a couple weeks. what needs to be done so that the car runs normal for the time being? Do I need to go to nissan and have them scale them???
Old Jul 1, 2008 | 04:47 PM
SpoilsofWar's Avatar
SpoilsofWar
You can just install them, the car will run pig rich and may idle a bit rough, but it will run. Then when you get the UTEC in scale them with the 0 load column.
Old Jul 1, 2008 | 06:41 PM
SlideFox's Avatar
SlideFox
What spoils said. You'll run rich, but she'll run. Just keep her out of boost!
Old Jul 2, 2008 | 01:31 AM
cheatthe1's Avatar
cheatthe1
if things are working now, why not wait until doing the Utec install and do the injectors then?
Old Jul 2, 2008 | 10:10 AM
frankie945's Avatar
frankie945
It will barely run way to rich to drive. When. I installed my 600cc deatchworks it ran like Sh*t, you'll see if you try to start it, non drivable. PM me after you get your utec I still have my 600cc procharger fuel map it will limp you to get a tune. I wouldn't use my timing map because I run water/meth. Also every car is different.
Old Jul 2, 2008 | 10:34 AM
str8dum1's Avatar
str8dum1
just put -11 in the o% load column. no magic there. you'd never have timing values different than ecu in the 0% load column.
Old Jul 2, 2008 | 11:17 AM
Jay'Z's Avatar
Jay'Z
What u recommend for 750cc -18 in the 0%?
Old Jul 2, 2008 | 11:29 AM
frankie945's Avatar
frankie945
I start with -14 in the 0% column with 600 deatchwerks
Old Jul 2, 2008 | 05:53 PM
turtle1678's Avatar
turtle1678
So guys I have to go 27 miles on the expressway, do you think that i should leave my ss box hooked up and install my fuel return with my OEM injectors, and wait till I get to the shop and have them change my injectors and do the tune?? I dont know what to do I have to change my pulley too to the 2.87, and by the way is what I have enough to run a 2.87 as safely as possible 600cc, aam return and rails, walbro, kinetix, full exhaust testpipes, utec
Old Jul 2, 2008 | 06:37 PM
frankie945's Avatar
frankie945
Just install everything and put it on a trailer thats what I had to do. And I'm only 5 miles from my shop.
Old Jul 2, 2008 | 06:42 PM
JCstart's Avatar
JCstart
600cc... wow !... way overkill...
Old Jul 3, 2008 | 06:14 AM
turtle1678's Avatar
turtle1678
hey rather safe than sorry they recommend about 550 for a 2.87
Old Jul 3, 2008 | 07:56 AM
SpoilsofWar
I would not consider 600cc to be overkill by any means. Remember, you need more injector for a supercharger setup then you do for a comperable turbo setup.
Old Jul 3, 2008 | 08:36 AM
turtle1678's Avatar
turtle1678
is there anything else that I will need other than what I have to run without any problems??
Old Jul 3, 2008 | 09:51 AM
frankie945's Avatar
frankie945
you have larger injectors ,walbro pump,fuel return and utec sounds good just get some 1 step cold plugs. I prefer cooper but that is my opinion. Install it all and have it trailered.Trust me have it trailered there's no reason to spend alot of $ and time and then fuc* it up trying to drive to the shop. You will be glad you did. Besides When I'm hauling my Z behind my H2 it seems like everyone thinks it's a race car and your heading to the track. I get more questions about it on a trailer.Rather then driving the Z around town
Old Jul 3, 2008 | 10:24 AM
turtle1678's Avatar
turtle1678
Just wondering how long does a tune usually take to do hour wise?? I was looking at the shop rates for install and its not that bad for the AAM return, But I was wondering if it can all be done in one bus day
Old Jul 3, 2008 | 10:54 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Larger injectors, return fuel system install, and a tune can be done in one full business day.
Old Jul 3, 2008 | 11:05 AM
Blackbird CPV35's Avatar
Blackbird CPV35
600cc is not overkill at all if you have a 2.87 pulley
Old Jul 3, 2008 | 11:20 AM
frankie945's Avatar
frankie945
Superchargers need more fuel than turbos. I ran 600cc deatchwerks and when I logged with utec I was at the 70% column At red line. With my current set up with a single turbo making it only in the 50% column at 7 psi.So Superchargers = more Fuel... I maxed out my stock inj at 5200 rpms with the procharger. And the shop is going to bust your head on $ when it comes to the install. It is easier than it sounds just do it yourself and take your time. I can change Injectors in about 1 hour just make sure you bleed off the fuel pressure by pulling the fuel pump fuse or you will get a face full of fuel.
Old Jul 3, 2008 | 03:14 PM
turtle1678's Avatar
turtle1678
The shop quoted me $825 for fuel return install and tune
