Forged Z - 475WHP at 7.5PSI on 91 Octane
Old Jul 4, 2008 | 01:04 AM
mrg1981's Avatar
mrg1981
Default Forged Z - 475WHP at 7.5PSI on 91 Octane
Alright, I finally have my Z tuned for low boost. Intense had it on the dyno today at EDIT: .7 Bar (about 10-11 PSI) running 91 octane while it was 115 degrees out with an auto tranny.
***SORRY FOR THE CONFUSION, WHEN I PICKED THE CAR UP, THE TUNER WASN'T THERE AND I WAS TOLD THAT THE CAR WAS TUNED FOR ONLY 7.5 PSI AND I WAS GIVEN THE DYNO AT 475WHP. THE FACT IS THAT IT WAS TUNED FOR .7 BAR AND MADE 475WHP; STILL QUITE AN ACCOMPLISHMENT, AND IT MAKES MORE SENSE! I CAN'T EDIT THE TITLE, SO MAYBE A MOD CAN HELP OUT ***
Results:
475.71 WHP
420.49 Ft-lbs
Next week:
High boost tune (probably up to 20 PSI or so!)
Stance Coilovers
900WHP rear axles
Final delivery of vehicle! Woot!
[/img]
Old Jul 4, 2008 | 04:31 AM
captj3's Avatar
captj3
Nice numbers. What is the stange bump on the dyno at 80 mph?
Old Jul 4, 2008 | 04:36 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Very nice numbers.
Old Jul 4, 2008 | 04:41 AM
350zna's Avatar
350zna
nice stuff
Old Jul 4, 2008 | 04:58 AM
MDeezy's Avatar
MDeezy
good numbers.
wonder if the A/F went a bit lean at that point...
Old Jul 4, 2008 | 06:03 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Loss of traction? maybe clutch slipped a little?
Old Jul 4, 2008 | 06:07 AM
Doba's Avatar
Doba
great number !! 20psi tune ??? helloo internals done? this is a greddy TT?
Old Jul 4, 2008 | 06:10 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
my dyno does that in the same spot with the automatics....
Old Jul 4, 2008 | 06:21 AM
jtgli's Avatar
jtgli
What kind of exhaust and downpipes are you running?
Old Jul 4, 2008 | 07:26 AM
turismo's Avatar
turismo
Sick numbers
Old Jul 4, 2008 | 07:37 AM
Kal_El's Avatar
Kal_El
Wow, great power and clean install.
Old Jul 4, 2008 | 07:43 AM
XKR's Avatar
XKR
Suuuwwweeeeeeetttt I like it.
Old Jul 4, 2008 | 08:26 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I was guessing auto too.
Old Jul 4, 2008 | 09:01 AM
wannabuy350z's Avatar
wannabuy350z
is it a rev-up motor?
Old Jul 4, 2008 | 09:17 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
automatic so no
nice and clean install..
Old Jul 4, 2008 | 09:22 AM
06dieselZ's Avatar
06dieselZ
I thought the norm was around 410 hp at 7.5 psi?
wtf
Old Jul 4, 2008 | 10:57 AM
Hexxum001's Avatar
Hexxum001
I wish Cali wasn't so strict.
I can haz twinz too?
Old Jul 4, 2008 | 11:09 AM
mrg1981's Avatar
mrg1981
Thanks for all the comments.
This is the torque converter. It is an upgraded TQ in the SGP Full Racing 5AT.
I have a fully upgraded longblock from SGP. I will post my specs in the next post.
No, it is not. 06 Autos are not rev up motors. With that said, the entire engine has been redone at this point.
wtf
I was pleasantly surprised. I have a lot of work done which may contribute to it.
Old Jul 4, 2008 | 11:12 AM
mrg1981's Avatar
mrg1981
This is a bit lengthy and took me a long time to write up. To help clarify, here are the full specs on my car:
Forged Z
2006 Nissan 350Z Roadster
Daytona Blue Touring Model
Engine:
SGP Racing Upgraded Longblock #1:
Carrillo Forged Rods
ARP Rod Bolts
ARP L19 Head Studs
CP Forged 8.5:1 Pistons (.02 over)
JWT Upgraded Cams
JWT HD Valve Springs
HKS Metal Head Gaskets
Revup Oil Pump
Cam Seals
5 Angle Valve Job
Valve Stem heights Set
Cold Clearance Set
Ported Exhaust and Intake Runners
Heads Oil Passages Cleaned and Redecked
Block oil passages cleaned and Redecked
Block bored and honed using a torque plate
Crank balanced
Crank journals polished
Main and Rod bearings w/ceramic coating
Performance:
SGP Racing 5-Speed Auto Tranny:
Pro Torque Converters, Upgraded clutches, Upgraded Valve Body, Upgraded Springs
SGP AT Cooler
SGP Full Fuel Return System
Greddy Twin Turbos
Greddy Front-Mount Intercooler
750CC RC Injectors
Walbro 255 Fuel Pump
ARC V2 Catch Can
Tial Blow off Valve
NGK Iridium 1-Step Colder Spark Plugs
AAM Spec 3 inch MaxFlow True Dual Exhaust (Titanium)
AAM Spec 3 Inch MaxFlow Dual Downpipes
Engine Management:
PRO-EFI 48 PIN ECU
Boost Solenoid
Wideband Sensor
PSI Sensor
Map Sensor
Fuel Pressure Sensor
AFR Sensor
Defi-Link Meter BF Boost Gauge
Defi-Link Meter BF EGT Gauge
Defi-Link Control Unit II
Pro-EFI Can Gauge
Handling:
Stance GR+ Coilovers
Driveshaft Shop 900WHP Rear Axels
20” Staggered Concept Neepers
Toyo T1R Tires
Engine Bay:
Greddy Grex Front Strut Tower Bar
Greddy Radiator Cap
Greddy Oil Cap
Intense Motorsports Polished Intake Manifold
Intense Motorsports Polished Intake Piping
Stillen Carbon Fiber Engine Cover
2 1/16” Koyo Radiator
Samco Hoses, Blue
Stereo and Interior:
Custom Painted Interior
Pioneer Avic Z1 with IPod hook up and Bass switch
Custom Fiberglass Enclosure with 2 MTX TA8500 10" Subs
2 Pioneer Rev Rear Speakers
MTX Mid and High Component Speakers
Custom Amp display with Z logo and Blue Neon Lights
MTX TA7801 4-Channel 1200 Watt Super Amplifier
TA5601 Mono Block 600 Watt Amplifier
Earthquake Capacitor, and Street Wires Fuse Box
Reverse/Backup Camera
Old Jul 4, 2008 | 12:45 PM
El Verdugo's Avatar
El Verdugo
Very clean install and the power it made is off the chain. Good job!
