weather vs. boost psi
Old Jul 11, 2008 | 06:10 PM
nomyth46's Avatar
nomyth46
Default weather vs. boost psi
hey guys,
i searched the topic but really couldn't find the answer i was looking for .................i was running my car pretty hard today and i noticed that in high boost (14psi) that it was only getting up to about 12psi, in low boost it was right on at 8psi..............i popped the hood and didn't notice any vac.leaks or anything...............i did notice however that under high boost my A/F's were at 9.8 it was tuned at 11.4.........could the weather conditions have something to do with the change?...............it was 81 outside w/humidity at like 90%................any opinions or insight would be much appreciated
Old Jul 11, 2008 | 09:34 PM
wannabuy350z's Avatar
wannabuy350z
In hotter wather you want it to be richer to avoid knock. the tuner must have added that in a different map in your ECU.
Old Jul 11, 2008 | 09:53 PM
JETPILOT's Avatar
JETPILOT
Originally Posted by nomyth46
hey guys,
What is controlling your boost? Your ECU (open or closed loop)? Mechanical boost controller?
Old Jul 12, 2008 | 04:38 AM
nomyth46's Avatar
nomyth46
my ECU is a Utec but i'm not sure what you mean by open or closed loop
no, its a greddy profec B spec II
the rich part doesn't bother me as much as the boost psi lowering by 2psi
Old Jul 12, 2008 | 04:39 AM
nomyth46's Avatar
nomyth46
its a Utec but i dunno what open or closed loop means...................i didn't mean to add that to your quote....sorry
Old Jul 12, 2008 | 05:24 AM
SlideFox's Avatar
SlideFox
Details on your setup...
Old Jul 12, 2008 | 06:14 AM
wannabuy350z
I see up too 2 PSI dropping in heat. its normal, best was is think of alternatives too keep temps down.
Old Jul 12, 2008 | 06:41 AM
QuadCam's Avatar
QuadCam
most boost controller are set by solenoid duty cycle. In the hotter weather, the same duty cycle is not going to achieve the same boost pressure as in colder weather.
What JEt Pilot was talking about "open or closed loop" is if you are using the "boost tuning" feature of the UTEC. The closed loop boost tuning provides feedback to compensate for different atmospheric/temperature conditions. Not many people use it though.....only a couple that I know of.
Old Jul 12, 2008 | 07:23 PM
nomyth46's Avatar
nomyth46
built greddy tt, utec, 750cc injectors, aam fuel return, and svr technologies open dumps
Old Jul 12, 2008 | 07:25 PM
nomyth46's Avatar
nomyth46
hey question has anybody ever ran a duel 3" straight pipes.............if so is it crazy loud or something you can live with cuz i'm thinking about trying it
apex locator
Jul 23, 2021 02:27 AM
codek
Sep 28, 2015 03:03 AM
