my shop build
Old Jul 14, 2008 | 12:38 PM
zulator03's Avatar
zulator03
Default my shop build
hey whats up i got my build that MRC motosports hopefully when i get the money there gonna build my car. here is the mods i hope that i will be pushing at least 450 to 550 hp
APS turbo
Greddy tic dual exhaust
Eagle rods
weico Pistons
Boost gauge
Oil temp guage
AFR gauge
AAM Fuel Return System
600cc fuel injectors
Heads Match Ported/Polished
JWT C2 Cams
Cosworth Plenum
HKS A/F Knock Amplifier
HKS EVC Boost Controller
greddy tic dual exhaust
please add on or tell me what to take out
Old Jul 14, 2008 | 12:41 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
take out......this thread GL
Old Jul 14, 2008 | 12:42 PM
zulator03's Avatar
zulator03
why
Old Jul 14, 2008 | 12:48 PM
2004Black350z
Exhaust Whore
APS turbo...........WTF TT or ST
Greddy tic dual exhaust.......Why not a APS 3" TD exhaust to make it flow better since ur useing aps turbos?
Eagle rods
weico Pistons
Boost gauge
Oil temp guage....thought this was a stock option?
AFR gauge
600cc fuel injectors.....Why 600c? what brand?
JWT C2 Cams......Why Cams?
Cosworth Plenum......Why a cosworth?
greddy tic dual exhaust.....didnt u already list this?
There ya go
Old Jul 14, 2008 | 12:49 PM
zulator03's Avatar
zulator03
There ya go
ok i see srry let me add more info ur right
Old Jul 14, 2008 | 12:51 PM
2004Black350z
Exhaust Whore
i mean it looks ok but if u wanna search my threads and look at my build theres plenty of great info in mine and my sticky thread of regretful parts. My build is on hold due to the FCKIN economy(rant) sorry
https://my350z.com/forum/forced-induction/352813-what-do-you-think-of-my-build.html
Old Jul 14, 2008 | 12:56 PM
zulator03's Avatar
zulator03
This is the updated version
APS twin turbo
greddy tt evo exhaust
Carbonetics triple disc clutch
EMS-fcon
Deathscherks 600cc injectors
Boost controller - undecided
Turbo timer - undecided
AAM 3" TD with AAM 3" Downpipes
Eagle rods 8:8:1
weico Pistons
automaster Boost gauge
automaster Oil pressure guage
automaster AFR gauge
JWT C2 Cams- idk why
Old Jul 14, 2008 | 01:05 PM
06Track's Avatar
06Track
One thought.. Harmonic balancer to help harmful vibrations to motor
and valve train. Fluid damper or ATI damper.
Quoted from Jegs:
You can't feel them or hear them, but harmonic vibrations are at work inside EVERY internal combustion engine. That's not good. Similar to glass-shattering forces created by a high pitched note, harmonic vibrations cause metal fatigue and can cause significant power loss because crankshaft harmonics are transmitted to the camshaft and valvetrain. Control this power-robbing force with a Fluidampr harmonic damper that uses race proven vibration damping technology. A high viscosity silicone fluid surrounds a nylon-coated inertia ring inside a laser welded housing.
Old Jul 14, 2008 | 01:07 PM
2004Black350z
Exhaust Whore
Quoted from Jegs:
Old Jul 14, 2008 | 01:15 PM
Crom's Avatar
Crom
The stock flywheel has a harmonic balancer....
zulator03's Avatar
zulator03
any 1 else wanna chime in
Old Jul 14, 2008 | 01:46 PM
Zivman's Avatar
Zivman
APS twin turbo - Good
greddy tt evo exhaust - so you are running this or the AAM exhaust?
Carbonetics triple disc clutch - judging by your injectors you would probably be fine with the twin
EMS-fcon - Good
Deathscherks 600cc injectors - Good
Boost controller - undecided HKS EVC V or VI is recommended
Turbo timer - undecided - don't get one, waste of money
AAM 3" TD with AAM 3" Downpipes - so which exhaust are you running? I would get the APS 3.5" to 3" downpipes and run one of the following exhaust:
APS 3"
APS 2.5"
Greddy EVO TT
Eagle rods 8:8:1 - just so you know your rods don't determine compression ratio - eagles are good
weico Pistons - fine, but I would get extreme duty pistons out of wiseco or arias
automaster Boost gauge - do you mean autometer?
automaster Oil pressure guage do you mean autometer?
automaster AFR gauge do you mean autometer? If so, I don't think they make a decent AFR gauge, and on top of that, an AFR gauge is redundant if you are running the HKS AF knock amp
AAM Fuel Return System - I would run the cjm over the AAM
Heads Match Ported/Polished - waste of money, but fine
JWT C2 Cams- idk why - I would recommend BC stage 2 or 3 over the JWT
HKS A/F Knock Amplifier - Good, just for your information, this will eliminate your need for a separate AFR gauge
Base on your list, it sounds like a little more research is in order.....
Old Jul 14, 2008 | 01:49 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Walbro 255
HKS Head Gaskets
One step colder plugs
A tune
AEM Wideband
Possilby:
Koyo rad
Nismo Thermostat
Samco hoses
+1 on more research
Old Jul 14, 2008 | 02:14 PM
zulator03's Avatar
zulator03
sry i was doing two things at once here hopefully the final list
EMS-fcon - Good
Boost controller - HKS EVC V or VI
Eagle rods
weico Pistons extreme duty pistons out of wiseco or arias
autometer Boost gauge
autometer Oil pressure guage
CJM Fuel Return System
BC stage 2 or 3 cams
THANK YOU zivman
Old Jul 14, 2008 | 02:15 PM
zulator03's Avatar
zulator03
Originally Posted by QuicksilverZ33
Walbro 255
HKS Head Gaskets
A tune
AEM Wideband
Possilby:
Koyo rad
Nismo Thermostat
Samco hoses
+1 on more research
i am going with the turbo kit with intercooler and One step colder plugs and it coming with the fuel pump also
so that is not really the issue but thanks
Old Jul 14, 2008 | 02:18 PM
zulator03's Avatar
zulator03
keep it coming i need all the information i can get
Old Jul 14, 2008 | 02:22 PM
Zivman's Avatar
Zivman
EMS-fcon - Good
Eagle rods
THANK YOU zivman
There is more that needs to be researched:
head studs - ARP L19 or possibly the HR TTY bolts
Main studs - I would assume they are using ARP
Head gaskets - probably HKS or cosworth stopper style, but maybe oem
oil pump - I would get the revup oil pump
additional cooling; might not be a bad time to drop in a koyo radiator. Don't waste your money on a nismo stat. It won't do anything to keep your temps down.
Old Jul 14, 2008 | 02:32 PM
2004Black350z
Exhaust Whore
Is that so? Well why don't u search!! Not tryin to be a dik but if u wouldv searched before u made this thread u couldv looked less stupid. Btw how old r u?
Old Jul 14, 2008 | 02:37 PM
Lightbulb
I would make this step #1. But that's just me.
Old Jul 14, 2008 | 02:42 PM
IIQuickSilverII's Avatar
IIQuickSilverII
-PL Kit with gt37r or the aps tt, single turbo will be cheaper greddy tt evo exhaust
-Carbonetics triple disc clutch
-EMS-fcon Vpro, if you going with hks make sure you get standalone not the iS
-Deathscherks 600cc injectors <-get bigger, 750 or 800cc
-Boost controller - undecided <- use hks
-Turbo timer - undecided <-dont get it, worthless
-AAM 3" TD with AAM 3" Downpipes
-Eagle rods 8:8:1 <- i like the BC rods better, but Eagles are good
-wiseco Pistons
-automaster Boost gauge
-automaster Oil pressure guage
-automaster AFR gauge
-AAM Fuel Return System
-Heads Match Ported/Polished not necesary for your goals at all, maybe a light polish
-JWT C2 Cams- idk why <- those are good but i like BC stg2, great idle and they make good power
-HKS A/F Knock Amplifier
my take.
werd, price is first
