what ems do you prefer
Old Jul 29, 2008 | 08:47 AM
  #121
1ZweetZ's Avatar
1ZweetZ
Originally Posted by rcdash
I agree with you on wanting an OEM like tune - safe and smooth. Forget about tweaking and tuning by the end user - I think very few actually will even if they are given that control. However, it's possible for you to be unaware of issues with the tune until its too late if you have no way of double checking yourself (data logging if nothing else). The tuner may have just forgotten a setting or switch... **** happens, unfortunately. The more opportunity for QC, the better. Suppose you feel a little hesitation, but it's intermittent. Do you go back and ask that your tuner checks it out? Is it urgent? How will you know? This was my main beef with the FCON and I got a bunch of Innovate data logging equipment on the side as I didn't know about the Haltech at the time (well, it wasn't released). (I still run the Innovate auxbox and SSI-4 equipment but rarely look at in favor of Haltech's ability to log CAN data so easily).
One thing I have learned over the years with aftermarket ecu's is that if it ran fine for a while, then started acting up...what makes that any different than when the car was stock and ran fine and later had problems. I wouldn't take my stock car back to the dealer and ask to have it retuned, I would ask to have it checked out. They would then diagnose the problem. Point is, the tunes don't change, if the car starts to run poorly, something is telling the computer lies (I.E. faulty sensor, bad injector...whatever).With a stock car...I don't think it would be possible to hurt anything unless your oblivious to abnormal things like heavy knocking or severe lack of power. I opted for all the sensors on the ProEFI...wideband, fuel pressure feedback, exhaust backpressure, and a can gage (soon to be configured). They setup all the safegaurds in the ProEFI, so if fuel pressure drops and the car goes lean for example... it will turn on a revlimiter to save the engine. The failsafes on this computer are UNBELIEVABLE! The only way I could see someone being able to damage their engine is to say...shift from 4th to 3rd (attempting to hit 5th) and overrevving the engine mechanically, which there is no way to prevent that with electronics. I feel perfectly content not being able to watch anything but air/fuel. There isn't alot of setup for the dealer to do on the ProEFI other than fuel and timing adjustments anyway, it has all been set up by ProEFI from the start.
Old Jul 29, 2008 | 09:18 AM
  #122
rcdash's Avatar
rcdash
Hey sounds like you have thought things through. I really like the fuel pressure feedback loop. Very nice. I want to add this on as well in the near future. I worry about the fuel pump going out or running low on fuel due to G forces during turns with a low tank.
Old Jul 29, 2008 | 09:24 AM
  #123
1ZweetZ's Avatar
1ZweetZ
My thoughts exactly! I have seen several guys running the twin pumps, and having just one fail.....very bad! I'm trying to be as prepared as I can be for the turbo move. I watched them take a Z with an adjustable regulator and a fuel pressure sensor wind the pressure up and down in it's full range and the air fuel only moved when the pressure was so high it hit the minimum on time for the injector and couldn't physically lower the injector pulse width any further....something like 700microseconds.....REALLY cool stuff!
Old Jul 29, 2008 | 06:58 PM
  #124
mrg1981's Avatar
mrg1981
Originally Posted by JuniorTT
Just to make it clear... The PRO-EFI can not currently remove the rev limiter or speed limiter from 05+ cars... Those cars use the DBW to shut down the motor. Since the Pro-EFI is a piggy back and has no control on DBW it can not in fact raise the limiter. Having control over the coils,injectors etc will not make a difference... The cars that you have seen rev over stock were all more then likely 03-04 cars, or had factory limiter re flashed if it was a 05 +
Actually, this is not correct. Pro-EFI increased the rev limiter on a silver '06 G35 auto and is increasing the rev limit on mine to 8000 RPM! I will report once mine is increased next week and let you know how it went.
Old Jul 29, 2008 | 07:01 PM
  #125
SlideFox's Avatar
SlideFox
I was witness to this conversation!!
Old Jul 30, 2008 | 04:21 AM
  #126
rrmedicx's Avatar
rrmedicx
Please just confirm that this is being done with the 48 box and not the 128.
Thanks.
Old Jul 30, 2008 | 04:54 AM
  #127
doug's Avatar
doug
are 06 Auto's revup motors?
Old Jul 30, 2008 | 05:02 AM
  #128
Glex25's Avatar
Glex25
Nope
Old Jul 30, 2008 | 05:50 AM
  #129
rcdash's Avatar
rcdash
But revup or not, I believe the throttle controlled rev limiter applies to the 05 and up cars... (non fuel cut)
Old Jul 30, 2008 | 06:02 AM
  #130
SlideFox's Avatar
SlideFox
I believe Intense has an '06 350Z 6MT in there shop now with a Powerlab Turbo Kit and Pro-EFI, but I can't remember if they said they were adjusting the rev limiter on that one or not.
Old Jul 30, 2008 | 07:10 AM
  #131
doug's Avatar
doug
oh i thought it had to do with the rev up or non rev up.. but i you're right because i believe the 04.5 350z have this problem too.. and they are non-revup.. i remember romey's car had this issue
Old Jul 30, 2008 | 07:27 AM
  #132
rcdash's Avatar
rcdash
Hmmm, I have an 04.5 G35 coupe and it has the hard fuel cut rev limiter (no issue for any standalone fuel controller). Now I'm uncertain which vehicles have the soft limiter...
Old Jul 30, 2008 | 10:20 AM
  #133
DanielW's Avatar
DanielW
hey I have a quick question about the utec and figured i could put it in here rather than starting a new thread. I'm selling it and the guy is asking me if the tune was locked. You can't lock a tune on the utec right?
Old Jul 30, 2008 | 10:24 AM
  #134
GTM's Avatar
GTM
Vendor - Former Vendor
Yes, you can.
What kind of EMS are you going with now? Just bite the bullet and get a MoTeC
Old Jul 30, 2008 | 10:26 AM
  #135
DanielW's Avatar
DanielW
haha no I'm actually parting out my car and selling her
Old Jul 30, 2008 | 10:54 AM
  #136
athenG's Avatar
athenG
Originally Posted by George@GTM
Yes, you can.
+1 I doubt PF do lock their Utec tune though..
Old Jul 30, 2008 | 11:36 AM
  #137
rcdash's Avatar
rcdash
You can start from scratch even if it is locked though if you want to unlock it (I presume this is going on another car with a different setup).
Old Jul 30, 2008 | 01:24 PM
  #138
IIQuickSilverII's Avatar
IIQuickSilverII
...wtf happend?
Old Jul 30, 2008 | 03:37 PM
  #139
DanielW's Avatar
DanielW
Woman
Old Jul 30, 2008 | 03:48 PM
  #140
zulator03's Avatar
zulator03
damm didn't think this would last that long thanks again
