Turbo Water Lines?
Old Jul 26, 2008 | 08:07 AM
350 Rookie's Avatar
350 Rookie
Default Turbo Water Lines?
So i talked to the rebuilders of my turbo and they said, the reason my turbo was done was because oil got cooked up in there due to no water lines running and cooling it down. I didnt have water lines hooked up and they said i had a water cooled turbo mid section. I'm talkin about the TN turbo btw.
Now does anyone have instructions on how to connect the water lines and where the lines go. I think i saw one guy with an adapter in his upper hose but not sure what it was for.
Pics would help greatly. Thanx alot in advance.
Old Jul 26, 2008 | 08:21 AM
frankie945's Avatar
frankie945
just took some picks for you. The lines that come with the kit connect to the back of the engine on the fire wall but they are hard to get to so I have shorter lines running to the front First pic you can see it the second pic it is under the intake charge pipe real easy to install and I think it keeps it cooler because it is closer to the turbo.
[IMG][/IMG]
[IMG][/IMG]
Old Jul 26, 2008 | 08:35 AM
350 Rookie's Avatar
350 Rookie
Originally Posted by frankie945
Damn dude, you are the best. thanx
in this pic where the top water line is connected to that black hose. That hose is the same one that runs from the upper radiator hose to the thermostat housing right?
and also, i gotta buy a kit for this? how mcuh does it cost? Im gonna google it.
Old Jul 26, 2008 | 08:45 AM
frankie945's Avatar
frankie945
I believe so it the hose right in front of your motor you can't mis it and the other one is in front on the right side it curves around you can only see about 6'' of it couldn't really get a got shot of it because of that charge pipe. Hope I could help.
Old Jul 26, 2008 | 08:54 AM
350 Rookie's Avatar
350 Rookie
alright thanx. one more question. that top line is the feed line right? and then the one that goes down is return? its almost obvious but just makin sure.
Old Jul 26, 2008 | 08:59 AM
frankie945's Avatar
frankie945
You are correct...
Old Jul 26, 2008 | 10:49 AM
350 Rookie's Avatar
350 Rookie
alright thanx. last question, i promise. lol. where did you get your fittings and lines.
Old Jul 26, 2008 | 11:01 AM
taurran's Avatar
taurran
The turbo should be fine without the water lines, but I've found that having sometihng like a turbo blanket on it tends to make the seals have a shorter life span.
I ran my water lines to the coolant lines behind the engine on either side. This is where companies like APS that sell water cooled kits do it, and it just looks cleaner. If you look in the shop builds section for the "testing the waters" thread, it should give you an idea of where I T'd them in.
Turbonetics sells water line kits that come with the proper stainless steel braided lines with banjo fittings and T's. Contact a turbonetics dealer and they should be able to order you a set.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
