Another reason to avoid TN
Old Aug 7, 2008 | 07:20 PM
  #41
diwun67's Avatar
diwun67
I've had 2 uppipes break in the same spot. Finally I just welded a spare one shut with no bracket and gusseted the wastegate pipe. I don't expect any more problems there
Old Aug 7, 2008 | 07:24 PM
  #42
350 Rookie's Avatar
350 Rookie
1. Your avator is hilarious.
2. So you dont have that bracket there? I was thinkin about doing that but wasnt sure if it was the best idea. If it cracks again, im deff removing that ****.
Old Aug 7, 2008 | 07:37 PM
  #43
diwun67's Avatar
diwun67
1. Thanks
2. I was pretty sure that bracket didn't support any weight, so I just deleted it and had it welded shut and then ground down smooth inside Do make sure you retain the bracket below the uppipe/turbo inlet flange that bolts to the compressor though, that one supports alot of weight.
Old Aug 8, 2008 | 04:56 AM
  #44
taurran's Avatar
taurran
I did that on my car too when I had the kit. I had zero issues with it cracking, but it was a pain in the *** when installing the turbo so I got rid of it.
I forget if I suggested it to Diwun or not.
Old Aug 9, 2008 | 11:52 AM
  #45
350 Rookie's Avatar
350 Rookie
Btw, here are pics of it welded. Excuse the rookieness cuz i just started welding
one thing im wondering is why turbonetics only welds one side of things. If they did it like this, it woulda been much stronger. You can compare the 2 in this pic
Old Aug 10, 2008 | 09:18 AM
  #46
SnyperZ's Avatar
SnyperZ
while your at it why dont you add a weld to that other bracket?
Old Aug 10, 2008 | 09:32 AM
  #47
350 Rookie's Avatar
350 Rookie
Im not using that bracket. Only the closed bracket is attached.
Pleask
Dec 21, 2021 03:17 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
