Driving 440cc injectors w/out a tune
Old Aug 14, 2008 | 05:14 PM
350z006's Avatar
350z006
Default Driving 440cc injectors w/out a tune
1) Has anyone ever tried driving w/ 440cc injectors without a tune? I'm installing a vortech and I was going to drive it to a tuner, but will it run too rich for me to get a decent drive out of it with those injectors?...It'll be a 60 mile drive...
2) Can I use the stock OEM injector connectors with the RC 440cc's, or do i have to buy the pigtails?
3)And while we're at it, I'm installing a used kit, and I noticed some of the old oil coming out of the oil drain hose of the blower...is there any way to flush out/clean the blower? Is there anything else I should do to the kit to clean it out or whatever before I install it?
Old Aug 14, 2008 | 06:06 PM
str8dum1's Avatar
str8dum1
1. i have driven with 600cc injectors on the stock ecu when my UTEC burned up. just makes starting a lil more difficult and you'll run way rich if you get on the gas too hard. light pedal action and you'll be fine with those smallish 440s
2. you need pigtails and clips
3. fresh oil rinse would be sufficient
Old Aug 15, 2008 | 03:04 PM
superchargedg's Avatar
superchargedg
Damn Noobs
+1 on the above.
Old Aug 15, 2008 | 03:24 PM
SnyperZ's Avatar
SnyperZ
Originally Posted by superchargedg
+1 on the above.
lol that was a really useful post
Old Aug 15, 2008 | 03:36 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I wouldn't do it on my motor.
You will run excessively rich and possibly wash the cylinder walls with fuel and scar them, causing possible loss of compression, and/or burning oil.
But it will "run" I guess.
Old Aug 15, 2008 | 06:06 PM
boostedmaxima's Avatar
boostedmaxima
If you have a AFPR you can turn down the base pressure until you get the other fuel management in order, but running it boosted and running rich 60 miles will be better than running lean. I would just turn down the pressure if there are starting issues.
Obadabot
Jun 18, 2023 11:31 PM
