Wideband o2 and True Dual???
Old Aug 23, 2008 | 11:35 PM
ekelly36's Avatar
ekelly36
Default Wideband o2 and True Dual???
I have searched but I cant really find anywhere... I will be installing a wide band this week but I have a true Dual system coming.... where do I get the bung installed? I know on some cars 1 bank will run a little hotter than another is that the case with our cars? or will any side work? Where is everyone else installing their wideband o2 bungs?
Old Aug 23, 2008 | 11:36 PM
ekelly36's Avatar
ekelly36
well let me rephrase part of that... on some cars 1 side will run hotter than another.... I just need placement advice... Thanks.
Old Aug 24, 2008 | 12:15 AM
frankie945's Avatar
frankie945
Check out this pick on these for sale test pipes it will give you the idea.
What TD did you get?
https://my350z.com/forum/exhaust/378...est-pipes.html
Old Aug 24, 2008 | 07:18 AM
ekelly36's Avatar
ekelly36
I have the Kinetix High Flow cats... Dont I need my wideband o2 before the collector on the cat? and does it matter what side?
Old Aug 24, 2008 | 09:15 AM
civic4982's Avatar
civic4982
^ yes before the business portion of the cat.
Old Aug 24, 2008 | 10:38 AM
ekelly36's Avatar
ekelly36
so then it doesnt matter which side I install it?
cheatthe1's Avatar
cheatthe1
if done after the cat, the display will be leaner correct? basically more outside air mixes with the flow than should normally with the cat slowing the air down a smidge?
Old Aug 24, 2008 | 11:42 AM
350Z400rwhp's Avatar
350Z400rwhp
Before the cat and make sure to have the bung welded at a slight downward angle so that the moisture can drain out of the O2 sensor. Oh and put it on the driver side bank.
Old Aug 24, 2008 | 11:59 AM
ekelly36's Avatar
ekelly36
awesome ... thanks.... is there a reason for the Drivers side bank? or is that just generally where people put them?
Old Aug 24, 2008 | 12:04 PM
SweetDreamZ's Avatar
SweetDreamZ
i put one on each bank...and there was a 5% difference bank to bank.
Old Aug 24, 2008 | 02:06 PM
UpRev's Avatar
UpRev
Depends on what system you're using but most have provisions for two sensor modules.
Old Aug 24, 2008 | 05:05 PM
ekelly36's Avatar
ekelly36
I am running the Innovate......
Old Aug 25, 2008 | 12:40 PM
gothchick's Avatar
gothchick
+1
I'm dual wideband now, but when I was single wideband I put it on bank2 (driver's side) since it tends to run a little leaner than bank1.
Old Aug 25, 2008 | 05:52 PM
NETSHARK's Avatar
NETSHARK
How about running two Innovate LC-1 Wideband Controllers and monitor them with only 1 XD-16 Innovate gauge check out the Innovate forums they did it: http://www.innovatemotorsports.com/f...ead.php?t=9030
"You can select any of the channels for display, or you can choose to display the leanest, richest, or average of all the AFR channels" the only thing you will lose is the min/max value.
Old Aug 25, 2008 | 07:00 PM
ekelly36's Avatar
ekelly36
Good to know.... guess I will order another one..... i havnt looked but I am worried about if I have enough room on my HFC to put a bung before the collector..... on the kinetix HFC there isnt a lot of room.....
Calinismo350z
Sep 14, 2015 04:04 PM
synth19
Feb 4, 2006 12:56 AM
Brandon@Forged
Aug 21, 2005 05:56 PM
