Turbonetics 5psi spring?
Old Oct 1, 2008 | 09:10 PM
Asian Invasian's Avatar
Asian Invasian
Default Turbonetics 5psi spring?
After much debate and months of thinking I believe I am going to be going with the turbonetics kit. I am not a new member I have been here a while so I have read so many of the turbonetics threads.
My Z is my DD so I dont want to run too much boost and don't want to run into reliability issues. I am wondering if there is a 5psi spring that I can run with the kit so it won't boost past that.
My Z has a stock block with 52k miles.. I really hope it can handle boost.. but like I said I don't really want to run much more than 5psi on my stock block because of how paranoid I am... and I drive my car pretty hard..
That being said, anyone have some input for me before I pull the trigger soon? I will be running the turbonetics reflash.
Anyone have any problems with boosting their car after 50k miles?
Is there a 5psi spring I can run with my turbonetics?
I am also thinking about buying a beater for like 1k because I know there will always be downtime and some kind of issues (hopefully nothing big).
Any insight will be great.
Old Oct 1, 2008 | 09:28 PM
wannabuy350z's Avatar
wannabuy350z
you can always get a boost controller
Old Oct 1, 2008 | 09:29 PM
Asian Invasian
wouldnt that be less safe than a spring though? I am not sure if they even make a 5psi spring, so I guess if they don't this is an alternative.
Old Oct 1, 2008 | 09:37 PM
str8dum1's Avatar
str8dum1
just do a compression and leakdown. give ya health of the motor right away. Just run the stock wastegate spring. Thats what the turbonetic flash is setup for. It wont be more than ~350 hp anyhow. way safe.
Old Oct 1, 2008 | 09:39 PM
Asian Invasian
Can you name some reputable shops that can do a compression and leakdown test for me? Estimates on how much that will cost?
Old Oct 1, 2008 | 09:51 PM
jeffie7's Avatar
jeffie7
Boost controller wont do jack when it comes to lowering boost.
There's a lot of people with 50K + mile Zs running boost, I wouldn't think much of it.
install the kit, if you're running anything aftermarket like exhaust, y pipe and so on, get a utec and get the car tuned! even if you're running a stock setup with the stock remapped ecu, I'd still dyno it and check out your A/F just to make sure its on the safe side.
Old Oct 1, 2008 | 09:56 PM
SpoilsofWar's Avatar
SpoilsofWar
There is a 5psi spring for the evolution wastegate, but I have no idea if its included with the actual 350z kit. If you buy a evolution w/g separately I know it comes with 3 springs; 5, 7 and 9spi.
Old Oct 1, 2008 | 09:57 PM
Asian Invasian
Thats exactly what I was going to do. I am taking off my Bassani and running stock becuase thats what the flash is meant for. Ill make sure to bring it to a dyno after the flash to get the A/F numbers.
Now for the compression test to make sure I am good... anyone know of any nationwide known shops that do it for a good price?
Old Oct 1, 2008 | 09:59 PM
Asian Invasian
Good to know, so I will be able to run it. Thank you!
Old Oct 1, 2008 | 10:19 PM
wannabuy350z
yup Evolution WG and SFR is a dealer that can get you that spring. super easy to change out.
Old Oct 1, 2008 | 10:22 PM
Asian Invasian
any insight on a compression test? I dont have the right tools to do it myself.
Old Oct 2, 2008 | 12:13 AM
wannabuy350z
its actually not hard, you have get a kit from pep boys work around our retarded manifold
Old Oct 2, 2008 | 04:04 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I boosted my car around 70k miles, no problems on 10k miles. first tranny too
Old Oct 2, 2008 | 07:51 AM
Asian Invasian
How much boost are you running and what are you putting down?
Old Oct 2, 2008 | 08:06 AM
JDMFairlady21's Avatar
JDMFairlady21
hey man, i've been boosted for a lil over 10k mi.. no problems whatsoever. good power n reliability so far for me.
keep in mind tho... a 5psi really comes out as 7.5-8psi ...
Old Oct 2, 2008 | 08:16 AM
Asian Invasian
what
Old Oct 2, 2008 | 04:27 PM
terps's Avatar
terps
definitely doable. I got the aps kit with external tial wastegates and got a 4lbs spring and hks evc6(overkill) and I got a 4,6,9 lbs setting. with bc off it runs 4lbs perfectly, thinks its a .3bar spring. don't know how running lower boost will affect the reflash however, u might run rich as hell and have jacked up timing, I got no idea how the reflash reacts(if it does) to different boost levels.
Old Feb 5, 2009 | 06:08 PM
Asian Invasian
bump this thread for more insight... I have the money.. now im just scared..
Old Feb 5, 2009 | 06:40 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Wow, this thread been while.
Still thinking about to go with TN kit??
Old Feb 5, 2009 | 06:50 PM
Asian Invasian
Yea I have the cash but im scared to boost my DD..
