Impact beam or no over my intercooler?
Old Oct 6, 2008 | 04:37 PM
specialized5223's Avatar
specialized5223
Default Impact beam or no over my intercooler?
Just curious. Wondering if you guys kept yours or got rid of it. It looks like it would impede airflow over about 45% of the intercooler.
Thanks
Old Oct 6, 2008 | 04:53 PM
go-fast's Avatar
go-fast
Thanks
it's a matter of preference....do you have kids?wife?will someone miss you?are you lucky?answer these questions and you will have your own personalized answer.
Old Oct 6, 2008 | 05:28 PM
RandomHer0's Avatar
RandomHer0
I have the Greddy FMIC, no choice in the matter.
Old Oct 6, 2008 | 05:54 PM
specialized5223
So the greddy is too thick i take it?
I was just wondering if you guys thought it did in fact have a noticeable effect on airflow or if it was so negligible that I should keep it on.
I also considered that the part of the intercooler it covered would be covered by the bumper anyway so I'm pretty sure I'll keep it on. Just looking for some logic-based third party input
Old Oct 6, 2008 | 06:29 PM
str8dum1's Avatar
str8dum1
the greddy is not too thick. the intake pipes go in front of the bumper brace mount. you could run a custom 2 in 1 out IC on the greddy and keep the brace. Greddy is the only kit that requires brace removal. APS TT has different routing to keep the brace.
the good aftermarket bumpers dont cover any of the intercooler either.
Old Oct 6, 2008 | 06:30 PM
350 Rookie's Avatar
350 Rookie
I kept mine. Saftey and towability are your main concerns.
Old Oct 6, 2008 | 07:31 PM
fstrnldr's Avatar
fstrnldr
while i doubt that brace will do much in the average car accident (most 350z's are going to slide right below whatever other vehicle it hits anyway), if you don't have a way to tie the ends of the frame rail together, then i would keep it on. i can see that making a good amount of change in the chassis rigidity. of course i've never tried to measure it w/ and w/out.
Old Oct 7, 2008 | 04:56 AM
KPierson's Avatar
KPierson
I notched mine. Still a little bit of support but it allows airflow. I planned on welding a bar over the top of the IC but never got around to it.
Old Oct 7, 2008 | 05:20 AM
go-fast's Avatar
go-fast
i know my first post was smart assed,but on a serious note...your cars safety should increase exponentially to your performance mods.the faster you go the more likely you will end up needing every safety feature you have.making power and finding trouble seem to go hand in hand(especially on street tires).
Old Oct 7, 2008 | 06:28 AM
specialized5223
Thank you everyone. Since I'm on my second stock bumnper t probably is wise to keep the beamn for safety. I also never considered the structural rgidity of the frame. Good call on that one!
And yes I agree safety should be a top factor but I do doubt how much the impact beam would do for me in an accident considering how low my car is and that is usually more often sideways than facing forwards.
Old Oct 7, 2008 | 07:12 AM
Fluid1's Avatar
Fluid1
Don't have mine
Old Oct 7, 2008 | 08:49 AM
XKR's Avatar
XKR
I have the Greddy IC....Forged Performance built a custom front brace to replace the stock one. I did not want to lose the structural rigidity up front.
This DOES NOT work like the stock brace to absorb impact....it is only to maintain rigidity.
http://www.cardomain.com/member_page...jpg?013113-265
http://www.cardomain.com/member_page...jpg?441513-265
Old Oct 7, 2008 | 09:45 AM
jining's Avatar
jining
kept mine, i have my oil cooler and p/s cooler attached to it
Old Oct 7, 2008 | 10:05 AM
Old School's Avatar
Old School
Shift_Boost
mines in the garage...
Old Oct 7, 2008 | 12:22 PM
terrycs's Avatar
terrycs
Not using mine (it wouldn't fit anyway).
The impact beam is a thin walled aluminum box beam which I believe is only good for up to 5-10 mph? If mounted correctly, a thick parallel plate FMIC probably is stronger than the stock impact beam when it comes down to a serious accident.
Anything more than 5-10 mph, any FMIC is trashed anyway with or without the stock beam.
As for towing ... don't they tie the car down by the tire(s) these days?
But if the beam doesn't impede performance and can still be used ... why not just install it?
Old Oct 7, 2008 | 01:05 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Mine is cut in half, Not worried about it.
Old Oct 7, 2008 | 02:04 PM
specialized5223
I could see it being an effective brace for structural rigidity but if that's not the case, and it doesn't provide any "real" impact protection, then I'd just leave it off for the sake of saving a few pounds up front.
416blueZ
Jun 11, 2024 10:56 AM
aboodi
Oct 28, 2015 02:07 PM
416blueZ
Sep 24, 2015 02:11 PM
Calinismo350z
Sep 14, 2015 04:04 PM
