Boost reference for wastegate - turbo or manifold?
Old Oct 7, 2008 | 02:22 PM
JonnyC's Avatar
JonnyC
Default Boost reference for wastegate - turbo or manifold?
I'm installing the STS kit and am trying to decide whether to hook up the boost reference line for the wastegate to the reference port on the compressor, or to the intake manifold.
The install manual states to hook it up to the manifold (but they already do other things wrong so I can't trust them), and the STS guys (athenG et. al.) said to hook it up to the manifold - so I'm sure things will be fine that way.
However, Julian had said in a post that if you hook up the reference line post throttle-body you can run the risk of tearing the WG diaphragm from going in and out (that's what she said ) of boost - since the vacuum will be harshly sucking the thing closed. Is that true?
The downside to running it off the compressor housing is that boost will read higher there than in the manifold (due to piping, FMIC, etc.) - resulting in the WG opening earlier, and that there might be a delay in closing the wastegate since the boost won't bleed off as much there as it would near the BOV?? Is that right?
I searched, but as usual couldn't find much of anything.
Old Oct 7, 2008 | 06:52 PM
deanfootlong's Avatar
deanfootlong
get your boost source at the plenum.
Old Oct 7, 2008 | 07:24 PM
athenG's Avatar
athenG
I dont think this is an STS thing and pretty sure most ST or TT uses the manifold for boost reference... By the way Julian himself used the manifold for both me and goosegoose install.
Old Oct 7, 2008 | 07:37 PM
JonnyC's Avatar
JonnyC
Aarrgh! Why did he have to confuse me
Well, this thread can be deleted now, haha. Thanks again athen.
Old Oct 7, 2008 | 07:40 PM
rcdash's Avatar
rcdash
I'm pretty sure that's a bad idea for the reason you mentioned. My boost reference source for the wastegate is in the compressor outlet pipe (JWT kit).
Here is a quote from the Garrett website (link here):
Internal Wastegates are built into the turbine housing and consist of a “flapper” valve, crank arm, rod end, and pneumatic actuator. It is important to connect this actuator only to boost pressure; i.e. it is not designed to handle vacuum and as such should not be referenced to an intake manifold.
Old Oct 7, 2008 | 07:59 PM
SpoilsofWar's Avatar
SpoilsofWar
That quote is referring to a internal wastegate as opposed to an external...
Does the STS kit use an internal wastegate?
Old Oct 7, 2008 | 08:04 PM
rcdash's Avatar
rcdash
I thought I recall reading something from Tial about vacuum damaging their wastegates also, but I'm not really sure... (I have internal so someone else gets to research that )
Old Oct 7, 2008 | 08:10 PM
SpoilsofWar
Considering the extreme temperature environment external wastegate diaphragms have to work in, they are extremely durable things. I doubt the vacuum an engine produces is much to worry about.
My w/g I think references both. I would have to check, but top port sees compressor pressure and bottom port sees plenum pressure via the boost controller solenoid. Or vice versa. I don't know, all I do know is my **** works.
Old Oct 7, 2008 | 09:50 PM
JonnyC's Avatar
JonnyC
Yeah, it's an external WG. Since I haven't seen anyone post up about problems with theirs being setup that way, I'm sure I'll be just fine running it off of the manifold. It would have been nice to not have run tubing all of the way back there though
EDIT: Hmm...Tial's install directions specifically show it getting a boost source pre throttle body.
Old Oct 7, 2008 | 10:22 PM
JonnyC's Avatar
JonnyC
Actually, just doing some random searching on the interwebs it seems as though pre-throttle body is the way to go. However, when the turbo is putting out 7 psi, the motor might only be seeing 6 psi. Post-TB reference will be less reactive (might get some spike), and pre-TB reference will be more reactive (most likely won't hit your target boost).
Well, after some searching, it seems as though people have had no problems with a post-TB setup - their wastegate has lasted many miles. The best setup is probably to run it off of the intake tube just before the throttle body (like the instructions show), which would work well with the STS since it's already tapped there. For now though, I might as well give referencing it off the compressor housing a shot.
Old Oct 8, 2008 | 05:29 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Your pressure in the plenum will always be a bit less than at the compressor due to pressure drop in the intercooler, piping, across the TB etc. Therefore (if you are running just off of the wastegate spring) your car will actually be making a bit more HP if you reference it at the plenum.
Both will work though....... especially if you have a boost controller. I personally use the port on the compressor.
Old Oct 8, 2008 | 06:03 AM
athenG's Avatar
athenG
Let me know how you make out... I might do the same. The only time I get some spike is when I'm doing some hard shifting but it only last for a couple of hundred RPM. It is not a big deal coz it very short live but if this help solve that then I might try it. Also I'm not sure if you'll have the same problem but I have a .5 bar WS spring and when using just the spring I only see 6psi. Not sure if its the BCS doing it but I can set Utec Boost Map to all 0 and couldn't go past 6psi with my .5 bar WS spring My worry is that if I use the Turbo as the reference then I might just see 4psi
Old Oct 8, 2008 | 08:21 AM
JonnyC's Avatar
JonnyC
Will do. I was thinking the same thing last night: maybe the problem you guys were/are having with the TXS BCS not reacting fast enough causing a spike has something to do with this. I guess we'll see.
I plan on just running off the WG spring just to get started (everything to 0 in the boost map). But like you said, coming from the compressor I probably won't be hitting much boost. The bright side is that I won't have to run a vacuum hose the length of the car
EDIT: And thanks SP for chiming in to add some credibility to this question.
Old Oct 8, 2008 | 08:39 AM
athenG's Avatar
athenG
lol.. this will also give you an idea how much pressure you loser from the piping and FMIC... What spring do you have? Please dont be the 4.5psi spring..lol
Old Oct 8, 2008 | 09:42 AM
JonnyC's Avatar
JonnyC
Haha, I don't even know. I'll check it when I get home. 3 psi here we come!
Old Oct 8, 2008 | 11:17 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I would be interested to see what kind of pressure drop you see. Since you are referencing before all of the pressure drops through the piping, it will change based on rpm and flow rate. Maybe the change in flow rate won't effect anything but please post the logs when you do it!!!
I am going home on leave this weekend, I can get you a starter map if you haven't already gotten one.
Old Oct 8, 2008 | 11:48 AM
JonnyC's Avatar
JonnyC
I was able to get a hold of one - thanks though. Another one couldn't hurt I guess
I bought the JeffSoftware LogAnalyzer as well, so I should be able to post up some sweet as screenshots *sarcasm*. I'm HOPING to get this thing going by the weekend, but you never know what could go horribly wrong.
Old Oct 8, 2008 | 12:06 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Haha this obviously isn't your first rodeo so I wouldn't expect anything to go wrong.
Your build is inspiring me to work on my car
codek
Sep 28, 2015 03:03 AM
