Where to find an aps oil pump?
Old Oct 28, 2008 | 02:31 PM
Bigkrnxboi's Avatar
Bigkrnxboi
Default Where to find an aps oil pump?
A couple days ago i found that oil was dripping from my oil pump.
Ive tried looking everywhere to buy an APS oil pump other than from APS in Australia or from a shop and i cant find it anywhere. Does anyone know where i can get one? Im dripping oil as i type this! Thank you!
Old Oct 28, 2008 | 04:01 PM
meatbag's Avatar
meatbag
Its the Weldon fluid pump. you can find it on the internet for around ~$400 i think.
Old Oct 28, 2008 | 04:02 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
^yarp google is your friend check by part number
Old Oct 28, 2008 | 06:24 PM
tig488's Avatar
tig488
A9000 iirc
Old Oct 28, 2008 | 06:33 PM
Driven1's Avatar
Driven1
Professional
The above information is correct, but some haven't had very good luck with them
Mine took a crap as well I ended up going with a Turbowerks Exa pump. It's overkill for my application but it will have other uses down the road with my intentions for the car.
Here's the standard electric pump.
http://www.turbowerx.com/Scavenge_Pu...enge_Pump.html
Here's the Exa pump I'll be using.
http://www.turbowerx.com/Scavenge_Pu.../Exa-Pump.html
Old Oct 28, 2008 | 06:36 PM
BoostedProbe's Avatar
BoostedProbe
Originally Posted by Driven1
That's the pump I plan on using for my "remote turbo" setup. I have read good reviews on it as well.
Old Oct 28, 2008 | 06:46 PM
tig488's Avatar
tig488
MOCAL makes a nice sump also and its cheaper but im sure you will have to redo some hoses.
Old Oct 28, 2008 | 06:53 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
We are one of the largest distributors for the Exa pump, it's a GREAT product, we use it with all of our Z/G twin turbo kits including our 1000+hp 350z
I have 2 in stock right now. let me know if you are interested.
http://www.spracingonline.com/store/...enge_Pump/3618
Chris
Old Oct 28, 2008 | 07:02 PM
Driven1's Avatar
Driven1
Professional
Chris
DAMN! I didn't even think about it! I wish I would have known, your price is WAY cheaper and I would have much rather purchased from you guys at SP. I just got mine last week direct from them.
Haven't installed it yet... should be this week, is it loud? Just curious.
Old Oct 28, 2008 | 07:06 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
No worries at all, wish we could have helped you out.
The pump is very quiet, the rubber bushings help greatly, but best bet is to mount it to something like the transmission to avoid any noise in the cabin. Even on the chassis it wasn't noticable. Btw, best of luck on your project too.
Chris
Old Oct 28, 2008 | 07:10 PM
BoostedProbe
I thought that I read somewhere about a belt driven sump pump. I can't remember, but that would be the best way to go. I would like to have my pump work with the oil pressure supplied to the turbo. I am woking on an electrical/electronic setup so that when my oil pressure goes up so does the motor speed that runs the scavenge pump. That is, unless I find a belt driven suitable setup.
Old Oct 28, 2008 | 07:12 PM
thawk408's Avatar
thawk408
From what Ive heard, Westech makes an awesome pump too.
Old Oct 28, 2008 | 07:15 PM
Driven1's Avatar
Driven1
Professional
Whats your basis for the belt driven being a better solution? Just curious. I haven't heard of this.
Old Oct 28, 2008 | 07:26 PM
BoostedProbe
Well, with a belt driven pump you have the advantage of variable speed. As the engines RPMs go up so does the fuel pressure, at the same time the belt diven pump RPM's also increase. I think it would also be more reliable.
With an electric pump, it's either on or off. STS uses a hobbes 1psi pressure switch to kick the pump in to "high gear" but that doesn't make sense. Boost and oil pressure are not related. You can be on the highway cruising and the oil pressure would be up there in the 60 psi range. The hobbes pressure swtich would not activate the pump at this point because the engine is drawing vacuum. I know that these small DC motors are durable but it's something I would like to eliminate if possible.
It is possible to have a two speed cuircuit that is activated with a regular oil pressure switch and a relay. So when the engine oil pressure goes up to say 50psi the pressure switch would trigger a secondary relay that would supply more power to the motor, and therefore switching it to high speed.
Something like this would be ideal:
http://www.daileyengineering.com/2STAGEHARLEY.jpg
It is a dry sump pump, and I could easly make a bracket and have it run off of the accessory belts.
Installed:
http://www.theseacpages.co.uk/webimages/oilpump.jpg
Old Oct 29, 2008 | 09:19 AM
Bigkrnxboi's Avatar
Bigkrnxboi
ahh wow thank you guys so much. you guys seem a lot more informed than the g35 community
is it worth the investment to get an exa or stay with the weldon?
Old Oct 29, 2008 | 09:23 AM
Bigkrnxboi's Avatar
Bigkrnxboi
also is there any fabrication needed to use the EXA oil pump?
if so how much would shops charge me :/
Old Oct 29, 2008 | 03:06 PM
Driven1's Avatar
Driven1
Professional
i went with the exa b/c of whats it's tested to and I don't necessarily "cruise" in my car and enjoy tracking it as well. The fabrication is minimal to the APS supplied bracket and we're actually going to strap it similar to the way the weldon was done. Other than that you need some fittings.
Old Nov 5, 2008 | 10:20 AM
Bigkrnxboi's Avatar
Bigkrnxboi
thanks guys for the input, gonna call the shop to get it fixed right away! i think im prolly gonna go with the turbowerx exa pump.
Old Nov 5, 2008 | 06:25 PM
Driven1's Avatar
Driven1
Professional
Just got mine installed and it's a damn nice unit. I love it so far.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
