Walbro 255 Fuel Pump - Install
Old Nov 9, 2008 | 04:25 PM
dskang100's Avatar
dskang100
Default Walbro 255 Fuel Pump - Install
I've been trying to complete the PL turbo install myself and I'm stumped. I did some forward research and found a guide from CJM that says I have to modify the pump using drills/files.
To other Walbro owner's... did you have to do this modification to your pumps?
I will be getting a Return Fuel System installed after I get the kit running.
Old Nov 9, 2008 | 04:35 PM
RandomHer0's Avatar
RandomHer0
Yes I did follow those instructions and they work.
Old Nov 9, 2008 | 05:23 PM
Car vs. Driver's Avatar
Car vs. Driver
That's how I did mine, it was fairly simple - just take your time
Old Nov 9, 2008 | 06:40 PM
str8dum1's Avatar
str8dum1
u need to get a RFS before u run...
it changes the tuning!!!!
Old Nov 9, 2008 | 07:35 PM
phunk's Avatar
phunk
CJ Motorsports
you certainly dont HAVE to perform the modifications, but it mentions on the how-to what the side effects will be if you do not.
Old Nov 10, 2008 | 05:53 PM
JonnyC's Avatar
JonnyC
I followed the instructions. It's not all that bad, just make sure to buy the right size drill bits.
Old Nov 10, 2008 | 05:58 PM
dskang100's Avatar
dskang100
Yep found out that the mods are unnecessary but just recommended.
I am still going to do the jet mod but not regulator since I will be running a return fuel system.
Doesn't seem too bad really.
Just need some dremel drill bits, files, and some patience.
Old Nov 10, 2008 | 06:56 PM
jonnylaw's Avatar
jonnylaw
what are the side effects?
Old Nov 11, 2008 | 08:44 AM
dskang100's Avatar
dskang100
The side effect for not doing the jet mod is a higher fuel pressure.
Old Nov 11, 2008 | 08:50 AM
Car vs. Driver
Call your tuner, some prefer that you skip portions of that installation if you're going to run a fuel return system.
Old Nov 11, 2008 | 09:53 AM
dskang100's Avatar
dskang100
I called up Function Tuned and they told me that it's okay to just drive over with the stock fuel pump with 600 cc injector's as long as I don't go into boost.
So.. looks like i'm loading up a powerlab 600cc map then basically granny the car to FT for tuning and RFS install
