Knock Amp Owners Chime in (seeing something weird)
Old Nov 16, 2008 | 09:01 AM
chris'smax's Avatar
chris'smax
Default Knock Amp Owners Chime in (seeing something weird)
I am seeing knock while cruising at around 2k-3k rpm. I was driving back from Forged yesterday (cruising at 80mph) and i happen to look down at the knock amp and i was seeing the "WARNING" message light up on the screen. The only thing i can think of is maybe i got a bad batch of gas. Maybe the knock sensitivity is set too high? The afr values look fine and nothing weird is happening. Also Sharif reviewed the tune when the car was there and said all the timming values looked good (nothing out of the ordinary). I did some light boost runs and there was 0 knock. Is it possible to get damaging knock at these low rpm levels?
Note i have a built motor w/ aggressive JWT C8R cams and valve springs. Also i have solid motor mounts so there is alot of engine noise going on
Old Nov 16, 2008 | 09:13 AM
ttg35fort's Avatar
ttg35fort
Professional
Go through the knock amp setting procedure in the manual. It starts on pg. 23.
Old Nov 16, 2008 | 09:15 AM
chris'smax's Avatar
chris'smax
already did. All that tells you is how to set it up. Mine was already set up by forged.
Old Nov 16, 2008 | 09:22 AM
XKR's Avatar
XKR
Chris.....That happened to me once....Sometimes it would not read anything. Sharif told me to turn the key in the on position until the beeping sounds stops...then start the car...never happened after that.
Old Nov 16, 2008 | 09:46 AM
chris'smax's Avatar
chris'smax
so you also got random "knock events" also mike? Makes me wonder why the hell i got this thing if it is going to do **** like this
Old Nov 16, 2008 | 09:55 AM
XKR's Avatar
XKR
Just once....I use to jump in the car... turn the keep and go. Sometimes the Knock would not display anything and one it displayed knock.....But after I did it Sharif's way...it never happened again....Just like a computer...you sometimes have to reboot.
I would not rule out bad gas also.....Just try what Sharif told me to do and see what happens.....keep me updated.
How is the car running??
Old Nov 16, 2008 | 09:57 AM
chris'smax's Avatar
chris'smax
no doubt man! Thanks for the heads up!!
I was just hoping it wasn't another problem. I have had a saga of ordeals w/ this car lately. Finally i think i have everything corrected. I am going to take it for a drive today
Old Nov 16, 2008 | 08:06 PM
str8dum1's Avatar
str8dum1
curious but are people's tunes sensitive to 1 or 2 point changes in octane at cruising speeds? (ie 'bad' gas wouldnt be worse than 89 octane)
I sure hope NOT!!!!!!
Old Nov 16, 2008 | 08:25 PM
chris'smax's Avatar
chris'smax
Doubtful. I think it may be the sensitivity level that the knock amp is set to. It is showing knock events when cruising at 2k rpm at 40mph and sometimes when delcelerating to stop at a stop light. It happens at very preculiar times to say the least.
The gas i put in was Cheveron Supreme so it wasn't like i bought it from a mom and pop shop
Old Nov 16, 2008 | 08:35 PM
str8dum1's Avatar
str8dum1
thats what I was wondering about. makes me believe theres no way thats real knock then. solid gas, no load.
Old Nov 17, 2008 | 03:27 AM
XKR's Avatar
XKR
OK
Old Nov 17, 2008 | 06:10 AM
rcdash's Avatar
rcdash
true knock at low load doesn't seem likely... you can get knock at low rpms, but at what MAP level? if it's under vacuum, I doubt it's true - maybe just a computer glitch?
Old Nov 17, 2008 | 06:30 AM
chris'smax's Avatar
chris'smax
it has to be a glitch. Occurs at vaccum. I also caught it once when i did a boosted run and after i left off the throttle it showed a slight knock
It is still doing it, although at a much smaller rate. Every so often while crusing i will see a value of anywhere from 7-23 for knock. I am still not sure what these #'s indicate. To my knowledge it isn't necessarily a knock "count".
Old Nov 17, 2008 | 06:47 AM
cbr900son's Avatar
cbr900son
Might be from ur ebay exhaust
Old Nov 17, 2008 | 06:57 AM
chris'smax's Avatar
chris'smax
or from my fist in your face
BOOM!!!
Old Nov 17, 2008 | 07:56 AM
XKR's Avatar
XKR
BOOM!!!
Did you try turning the key to the on position and waiting for the beeping to stop before starting it ??
Old Nov 17, 2008 | 01:05 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hey Chris, call me again when you have some time. It's just matter of adjusting the knock sensitivity on the Knock Amp. It's not real knock. I have seen this happen, even at idle and just free reving the car. Some engines/cams/motor mounts are noiser than others, so the knock amp is probably picking some of that up.
Old Nov 17, 2008 | 02:26 PM
cbr900son's Avatar
cbr900son
BOOM!!!
bad hulk bad!
Old Nov 17, 2008 | 04:37 PM
hji1945's Avatar
hji1945
I think I have similar issue.. But I don't have the instruction.. Anybody knows where I can find them??
Old Nov 17, 2008 | 07:18 PM
jonnylaw's Avatar
jonnylaw
I'm looking for the instructions for the AFK. I never got one for mine
