My Build: The Good, The Bad & The Progress
Old Nov 26, 2008 | 12:04 AM
350z006's Avatar
350z006
^^...Crom and Mitra!...
Originally Posted by Crom
....Jebus...
Old Nov 26, 2008 | 05:02 AM
XKR's Avatar
XKR
WOW....thats bad..... I agree...time to drop some names or a partial refund.
Old Nov 26, 2008 | 05:29 AM
Cass007's Avatar
Cass007
Default The Teardown
The sellers forum ID is Concept350Z if you want to have some fun, search his threads started and see what happened when he tried to stiff Kevin (specialized5223) on his oil cooler, check his i-trader feedback as well . When I delt with the seller, he has a positive i-trader rating (I had none) and 185 posts. The number of sale threads started made everything look like a legit part out.
So after a few days Frank calls me and says he has some bad news, the motor looked like it was assembled in a body shop and there were signs of a sloppy build everywhere. The bolt holding the bent pulley was so over-torqued Frank had to heat it with a torch to remove it. The main issue was with the bearings, it appeared as though they were not clean when installed and showed significant signs of grooving, uneven wear and overheating. Frank was a champ and documented everything for me and kept me up to speed via e-mail pic and pics to my phone. This is what I got :
My Build: The Good, The Bad & The Progress-chris-s-350z-000.jpg
My Build: The Good, The Bad & The Progress-chris-s-350z-005.jpg
My Build: The Good, The Bad & The Progress-chris-s-350z-007.jpg
My Build: The Good, The Bad & The Progress-chris-s-350z-008.jpg
My Build: The Good, The Bad & The Progress-chris-s-350z-009.jpg
Old Nov 26, 2008 | 05:40 AM
XKR's Avatar
XKR
I will get the gang together and go hunting
You are doing a good thing....Others will learn from this and only buy big ticket items from someone that is really known on here or the build was done by a well known shop. I hate to see threads turn out this way.
Old Nov 26, 2008 | 05:45 AM
Cass007's Avatar
Cass007
A few more:
My Build: The Good, The Bad & The Progress-chris-s-350z-015.jpg My Build: The Good, The Bad & The Progress-chris-s-350z-018.jpg My Build: The Good, The Bad & The Progress-chris-s-350z-019.jpg My Build: The Good, The Bad & The Progress-chris-s-350z-020.jpg My Build: The Good, The Bad & The Progress-chris-s-350z-024.jpg
So basically the motor turned out to be a complete diaster. Frank continued to tear down to a bare block and came to find out that the cylinders were slightly out of round (luckily tight, not loose) and that the block had been scuffed along the crank most likely from a careless clamp down during the machining process. The oil sqirters were intact, but the locator pins were broken off during disassembly because they were over torqued during install. Frank recommended sending that motor to a shop to have the cylinders fully spec'd top to bottom to see if there was enough material for a clean up bore or if the block needed to be scrapped completely. The block would also need to be line honed as well to remove the clamp marks.
Old Nov 26, 2008 | 05:53 AM
AznSky's Avatar
AznSky
uhhh....so why aren't you pissed off and going ape sh*t? lol you seem so calm.......
Good luck with the build!
Old Nov 26, 2008 | 06:03 AM
SweetDreamZ's Avatar
SweetDreamZ
wow, rarely do i join on these threads...but I have to keep up on this one.
Sorry about your luck so far man...i'm hoping you at least got SOME of your money back from that scumbag...
Old Nov 26, 2008 | 06:26 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Man i am sorry for what you are having to go thru as this is total BS.
Old Nov 26, 2008 | 07:08 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Damn, I had no idea you were running into so many issues with this build. Good luck getting it all back together, and Frank is a good dude to have working with you on it.
Old Nov 26, 2008 | 07:29 AM
thom000001's Avatar
thom000001
I tried your same route years back on my Z31 turbo with the same outcome. Learned my lesson........3 years, and a battle in court and the builder had to buy my car (which they had parted out already anyway).
Good luck with the build. And remember Patience and research pay off in the end.
Tom
Old Nov 26, 2008 | 08:16 AM
Cass007's Avatar
Cass007
I seem to often be the exception to the rule in my life. I have accepted that many times my journey may seem more difficult than others when doing similar tasks, but I am blessed in other ways.
I feel your pain brother. I'm deciding on possible legal action now, but I needed to get the full info and invoices on the motor repairs first.
Thanks Mike - I look forward to meeting you at ZDAYZ or the airstrip event in the future. I'm still hoping that this ends well, but as many of us in F/I know, your happiness is usually directly related to how much money you can throw at a problem.
Old Nov 26, 2008 | 08:22 AM
buzzardmountain's Avatar
buzzardmountain
Subscribing......
Old Nov 26, 2008 | 09:35 AM
str8dum1's Avatar
str8dum1
well you still have over 2000$ to play with as thats what a new motor woulda cost extra. even with the set backs you'll still be way ahead of the game, plus you have your stock motor you can sell for even more money.
and its winter, so no rush for a few months anyhow.
Old Nov 26, 2008 | 10:06 AM
wannabuy350z's Avatar
wannabuy350z
Its kind of good that your patient this way, I swear I would have been in Jail by now if some one f!cked me out that way.
if you change your mind, I'm ready!
Old Nov 26, 2008 | 12:04 PM
Cass007's Avatar
Cass007
Default The Re-Build
At Frank's suggestion we had the heads sent out to a specialty shop. They are currently in the care of Dave at Head Games Motorworks in Trenton, NJ. I spoke with Dave briefly and he said that there has been head work done, but not by anyone with any talent. I opted for a complete teardown of the heads as well and went with a 5-angle valve job and a radius on the exhaust something (too technical). Dave also said he found the valves were not seated correctly, but all will be well when he is done and the heads should easily hold 20+lbs of boost. Head repairs - $1200-1400 depending on how many new buckets need to be purchased.
http://www.headgamesmotorworks.net/ Dave 609-882-3211
Since the motor was in pieces anyway, I decided something needed to be done about the horrific color that it had been painted. Karl (ibkarlito) had very politely confirmed my suspicions that it was indeed "very ugly" when we met at Frank's. The front and rear timing chain covers, valve covers, intake (the piece under the lower plenum), upper plenum and a few other goodies were taken up to a powder coater in Mechanicsburg, PA. Lots of pics and a huge plug for him later .
Old Nov 26, 2008 | 12:29 PM
Cass007's Avatar
Cass007
On a slightly lighter note, here is what happens when your wife checks the paypal account for something she ordered and sees your $5250 motor purchase that you failed to mention. You end up with these to teach you a lesson
My Build: The Good, The Bad & The Progress-dsc03888.jpg My Build: The Good, The Bad & The Progress-dsc03887.jpg
Needless to say, another lesson has been learned the hard way.
Old Nov 26, 2008 | 12:34 PM
SlideFox's Avatar
SlideFox
Attachment 216904 Attachment 216905
You got by the boss!!!
Old Nov 26, 2008 | 12:42 PM
  #38
Blck350z's Avatar
Blck350z
Wow . When i was down getting my car tuned at dave's me and Jon asked to be present when he's tuning it etc... this thing should def. be a beast !!!! can't wait to get a ride in it !!! ( if thats aight ) Good luck man.
Old Nov 26, 2008 | 12:50 PM
  #39
Cass007's Avatar
Cass007
Originally Posted by jtgli
In for the long haul as well. Im glad I could have inspired this so much ; ) haha. Deff want to ride in the beast once its done and see if I can get back into the ropes with you then.
Just remember....this is all your fault.
No problems man, I can't wait to see your setup as well. I have visions of F/I Z's terrorizing central PA.
Old Nov 26, 2008 | 01:51 PM
  #40
terps's Avatar
terps
that really grinds my gears
