Im doing a Custom Twin Turbo setup, need input
Old Dec 17, 2008 | 07:49 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by doug
I wish people would make these posts after they finish.. not before..
too many fcking dreamers on this board.. i wish i could fcking build a teleporting machine that would make me teleport from my living room to my desk at work.. but mark my words.. i won't make a post about it till i am finished
No Offence to you OP.. but quite frankly i am sick of these types of threads.. don't talk about it.. be about it
Exactly, you're not going to find the information you need or the right advice for your situation on this forum.
I say find someone who has built a custom TT kit for a 350Z and ask them what obstacles they ran into and if it was cost effective in the end.
Old Dec 17, 2008 | 08:03 PM
go-fast's Avatar
go-fast
Originally Posted by wannabuy350z
do it on your stock exhaust STS style.
(disclaimer:assuming you have the experience to not blow up your car...or burn it to the ground)
this would be an interesting use of two smallish turbo's,a twin rear mount setup has not been done yet an a z and would be a worthy project.as far as a conventional setup,it would be foolish to re-invent the wheel,especially with complete used kits floating around.
Old Dec 17, 2008 | 09:05 PM
mygunit's Avatar
mygunit
Hey Doug, no offense, but its kind of hard to get input on a project AFTER you have it done, get it? Its kind of like researching how to put together a turbo, after youve done it, which makes little sense. Good luck with that teleportation device, let us know how it goes.
Old Dec 17, 2008 | 09:13 PM
mygunit's Avatar
mygunit
Boosted probe, you have inspired me, let me know how it goes.
Old Dec 17, 2008 | 11:28 PM
QuicksilverZ33's Avatar
QuicksilverZ33
What type of wastegate configuration do you have in mind?
Old Dec 17, 2008 | 11:42 PM
wannabuy350z's Avatar
wannabuy350z
^most likely internal WG's. I say get test pipes. hack the hell out of it and make a smooth 90* bend and route back to exhaust. and have the compressor shoot towards the front of the car.
I was bored!
Old Dec 18, 2008 | 05:10 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
If you can weld and have fab skills, you can certainly make your own turbo kit!! The only real difficult part about it is the ridiculously tight space constraints under the car and getting the piping forward. When I built ours the motor went out and in probably 6 times to check clearance and fitment. Remember that if you are going to use those turbos and build your own headers, you will probably be mounting the turbos low so you will need to build an oil scavenge system for it.
Good Luck!!
Larry
SP
Old Dec 18, 2008 | 06:01 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Packaging packaging packaging. You can definitely do it, but it is tight under there. This isn't like making a quick manifold for a DSM where you have easy access and space to work with.
wannabuy350z: first, your photoshop skills are amazing. second, have you looked under a 350z lately, there is little space :/
Old Dec 18, 2008 | 06:22 AM
QuadCam's Avatar
QuadCam
Good Luck!!
Larry
SP
Didn't you guys have a TT setup with the turbos located high in the front of the car a few years back? maybe thta was a different shop..... your current car has low mounted turbos (life the SFR kits), right?
Old Dec 18, 2008 | 06:50 AM
SoundPerformance
Sound Performance
That was intense that did that.... but you lose PS and a/c.
Old Dec 18, 2008 | 07:09 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
They were able to retain the AC and switched to electrical power steering.
Old Dec 18, 2008 | 09:25 AM
wannabuy350z
why thank you Hal
Old Dec 18, 2008 | 09:58 AM
Jay'Z's Avatar
Jay'Z
why thank you Hal
on your PS skills/ headers especially!!!
OP start the build already!!
Old Apr 27, 2022 | 01:52 PM
sgtjacko505's Avatar
sgtjacko505
I can't yet drive for a couple more years but I really want a 2003 350z that I'm going to save up my money to get. I was wondering if it is safe to buy the TD04 turbo off a Saab 9-5 from my local junkyard and make a custom set up for this car. Once again I do not have a car yet therefore I do not have any problems or milage yet. But I was wondering if it is safe or worth it and if anyone else has done it?
Old Apr 27, 2022 | 01:53 PM
sgtjacko505
I don't even how much this would cost so it is all pretty much just a hypothetical at this point.
Old Apr 28, 2022 | 06:28 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
no.
By the time you buy the car it will be over 20 years old, likely high mileage. Youll have to dump thousands of dollars into it.
Old Apr 28, 2022 | 07:28 AM
bealljk's Avatar
bealljk
Welcome to the forum SGT -
not worth it … the turbos might be inexpensive but you will spend $1000s of dollars finding headers, downpipes, wastegates, cold side, BOV, etc. Roughly speaking, a basic turbo kit will run $4k to $6k minimum - so factor that in.
You should plan on buying the car first and just enjoy safely driving the car.
what do you want to do with the car? Daily driver? Drift? Track? Drag?
Old Apr 28, 2022 | 04:00 PM
  #38
travlee's Avatar
travlee
Master
Youngblod wanting to turbo a car he doesn't even have......might have a new Dugan contender
Old May 6, 2022 | 04:14 PM
  #39
Escobar's Avatar
Escobar
revived a thread 16 years old give him some credit!
Old Jun 23, 2022 | 02:36 PM
  #40
sgtjacko505
thank you I think ill just keep doing research and saving mymoney!
2004350z16
Aug 3, 2012 07:30 PM
mygunit
Dec 17, 2008 01:55 PM
agallardo
Aug 18, 2008 09:04 AM
dave3529
Oct 3, 2006 02:01 AM
itsjoshufocker
Mar 28, 2005 02:20 AM
