engine rebuild, over 600hp. share ur experience/knowledge
Old Jan 6, 2009 | 12:19 PM
daniel427ss's Avatar
daniel427ss
Default engine rebuild, over 600hp. share ur experience/knowledge
hi
we will be rebuilding an engine with forged internals. ie: pistons.020over, rods n everything. getting it ready for more boost.
since the goal is 600+hp. things for sure need to be well done.
i have very little to no experience with these engines especifically. but the experience with remanufacturing engines is there.
this thread is to check or see if u can share some knowledge specificaly for this engine.... what are weak links in the engine, tips, or stuff needed to know when rebuilding (i dont want to see the rebuild like your normal stock hp engine)
for example: on the srt4, it has been known that it is not good enough to just torque down your rod bolts, u need to measure bolt stretch because of the strong crank throw.
anything similar or maybe something else on the vq? oh n its a 2006 revup engine
thanks
note edit: redid thread for proper subforum
Old Jan 6, 2009 | 12:45 PM
Cass007's Avatar
Cass007
https://my350z.com/forum/forced-indu...-progress.html
My build is for an 05 DE, but many of the same components will be used. There are many different levels of build depending on your value of money and if you want to do all of the components at once and have your ride down for a while or if you want to do the build in chunks.
Also, it is best to do a lot of research and ask specific questions rather than ask the same ones noobs repeat over and over. Just giving you a heads up .
Start by reading this:
https://my350z.com/forum/forced-indu...-worth-it.html
Old Jan 6, 2009 | 06:18 PM
QuadCam's Avatar
QuadCam
rod bolt stretch method is always the preferred method on any engine!!!!
Old Jan 6, 2009 | 06:23 PM
Nexx's Avatar
Nexx
engine build = very expensive
over 600hp = not sure im around 500ish, it seems fast
gg
Old Jan 6, 2009 | 08:18 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I've never built a car engine before, but motorcycle engines....a ton of. I ALWAYS measured bolt stretch!
Old Jan 7, 2009 | 05:55 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Good advice below, because you know, you are the first person to ever ask these things...
Old Jan 7, 2009 | 06:00 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
You don't want to build your car, when you could buy one that is already built right :
https://my350z.com/forum/south-east-...il-1-10-a.html
Old Jan 7, 2009 | 01:33 PM
daniel427ss
i read something about regreting using arp headstuds?
why is that? size?
Old Jan 7, 2009 | 02:09 PM
str8dum1's Avatar
str8dum1
people regret drilling out for 1/2" studs. you always wanna use the drop in ARP studs
Old Jan 8, 2009 | 11:47 AM
ttg35fort's Avatar
ttg35fort
Professional
+1
About a year ago, there was a post where somebody had his block drilled and tapped to go with 1/2" studs, and experienced all sorts of problems because the holes that were made were not perfectly lined up. I would not risk doing that considiering the ARP L19 Head Studs match the stock threads, and I not seen anybody post anything but positive comments about the L19s.
I also remember one post where somebody recommended using the stock head studs, but this does not appear to be the norm for built VQ motors pushing high hp.
Old Jan 8, 2009 | 11:51 AM
ttg35fort's Avatar
ttg35fort
Professional
+1
There are some very good engine builders who post in this forum. I used Import Parts Pro, but Forged Performance and GTM also make good motors. I'm sure others do as well, but these are the companies I am most familiar with. For the little bit of money you will save doing it yourself, it probably is not worth the risk unless you are an expert with all of the proper tools and experience.
Cass007's Avatar
Cass007
I believe its jkenefic - I think it was using HR stock bolts only. He's had great results as far as I know. I'm pretty sure the L19s are the most common right now.
Old Jan 8, 2009 | 02:05 PM
daniel427ss
see thats some type of posts i was looking from u guys. seems like a good community, im a noob here. (usually on srtforums)
this is not my engine, its my friends he allready has all the stuff, im just searching for lil things like the posts above. (((for example, i remember at first arp bolts had something wrong made for the srt n those werent good until they redid them, many ppl didnt know n they were still using them.)))
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
