XKR Super G... Going for Mach 1
Old Nov 10, 2009 | 07:07 AM
  #2041
XKR's Avatar
XKR
Originally Posted by CrazyVQ35tt
XKR This might be a stupid question, but have you looked into changing the pressure plate I have the ATS triple carbon clutch and it comes in three different versions 1350kg 1600kg and 1700kg. They also offer different compound disk for different drive ability.
I was told that there was nothing I could do to get the Carbonetics to hold....FP is installing the OS3 this week....matter of fact it may have already been installed
Thanks for the input though...
Old Nov 10, 2009 | 07:13 AM
  #2042
thom000001's Avatar
thom000001
Just go direct drive mike.....single gear, no trans, 1.5:1 gear diff!!!!!!!!!!!
Tom
Old Nov 10, 2009 | 07:47 AM
  #2043
str8dum1's Avatar
str8dum1
so are you flying back there for new numbers?
I guess realistically the car needs to go thru a whole nother break-in procedure for that clutch, so big # pulls are still a ways off....
Old Nov 10, 2009 | 08:01 AM
  #2044
XKR's Avatar
XKR
Tom
You install it and tell me how it works out
Yup....I will fly out there again.....It wont take long for break in.
Old Nov 10, 2009 | 08:06 AM
  #2045
350zna's Avatar
350zna
I hope this project turns out for the better for you XKR, between your clutch frying and Alberto blowing up its been sad times in the F/I forum
Old Nov 10, 2009 | 08:13 AM
  #2046
XKR's Avatar
XKR
Thanks for the kind words.
Old Nov 10, 2009 | 09:04 AM
  #2047
binder's Avatar
binder
Tom
that's how the sprint cars my buddie races is setup. They run cbr600 motors and they weld the clutch baskets solid. Bump start and blip the throttle to shift.....so sick.
Old Nov 11, 2009 | 06:42 AM
  #2048
XKR's Avatar
XKR
Just a little OT until I get intel on my OS3 install......
When I was at FP a few weeks ago....I drove up and asked were was Sharif. They said he was in the back testing....this is what I found
Now the question is....WHAT WAS HE TESTING Notice the Duct tape....electrical wiring....RACE FUEL .... Alex....the guy with the timer in his hand started to smile when I walked up....but was obviously very nervous....I am just saying
Old Nov 11, 2009 | 06:50 AM
  #2049
str8dum1's Avatar
str8dum1
their barrel pump was prolyl broken and they were trying to siphon the gas into the tank using a different pump
LOL
Mike, do you have solid motor mounts on your car? I figure since my motor is in my living room, now would be the time to swap.
Old Nov 11, 2009 | 06:58 AM
  #2050
XKR's Avatar
XKR
LOL
Thats what both of them tried to tell me.....but you dont need a timer, duct tape and some other questionable things to siphon gas.................................................. .....J/K
No....I was given a ride in a car from a member on here that had them.....I could feel everything the motor was doing......not a mod I was willing to get.
Old Nov 11, 2009 | 07:30 AM
  #2051
Motormouth's Avatar
Motormouth
that looks to me like he is trying to find the right mixture of additive to pass tech inspection for a spec fuel class, maybe? is that a spectrometer in the other guy's hand?
Old Nov 11, 2009 | 08:46 AM
  #2052
thawk408's Avatar
thawk408
FAWK! I did them for better clearance on the new build. I figured I would feel some vibration, but how bad is it?
Old Nov 11, 2009 | 09:11 AM
  #2053
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I wouldn't be surprised if opinions on solid motor mounts vary almost as much as opinions about what clutch is "steetable".
Old Nov 11, 2009 | 09:35 AM
  #2054
str8dum1's Avatar
str8dum1
ya, there is a huge range of opinions. Pretty much have to get them and try them yourself.
Thats what I am going to have to do.
Be careful on that clearance. If you lower your motor, your sump will be on the ground. I'm going to use fender washers to shim back to stock height bc I dont want to lower my engine any.
Old Nov 11, 2009 | 01:26 PM
  #2055
Sylvan Lake V35's Avatar
Sylvan Lake V35
I am sick of hearing what your "gonna do" time for you realize its never going to happen and throw in the towel.....you should just sell me that long block sitting in your garage. Just joking Rich, Seriously when are you installing XKR version 1.0?
Old Nov 11, 2009 | 02:26 PM
  #2056
thawk408's Avatar
thawk408
I got IP ones, and I believe they are stock height.
Old Nov 11, 2009 | 05:10 PM
  #2057
str8dum1's Avatar
str8dum1
the biggest question is, what exactly is stock height? Are they measureing the compressed or uncompressed. When we are talking in the 1/4" range, do the stock mounts even compress that much?
Either way, I went with the Revshift ones. They were $100 shipped and the guy said they are only like 1/8" shorter. Easy enough to shim to height with washers.
And Gord, at least I am not starting my own 'dreaming' build thread quite yet
Old Nov 11, 2009 | 06:13 PM
  #2058
Sylvan Lake V35
Or even worse your own build failure thread i have seen a couple of those around here. Just bustin your chops i know you are taking your time and doing things right.
I would like to ride in a car with solid mounts it was something i looked at alone with solid diff mounts. i am a ***** though I don't want a harsh ride. 800whp with a stock like ride for me please
Old Nov 11, 2009 | 06:38 PM
  #2059
thawk408's Avatar
thawk408
Everything as far as I could see fit the same, height wise, with the stock vs the IP.
Old Nov 11, 2009 | 08:38 PM
  #2060
go-fast's Avatar
go-fast
fuel pump volume....do i win a prize?
edit: when the f is this car gonna be done?i'm starting to think your a tease.
