XKR Super G... Going for Mach 1
Old Jun 11, 2010 | 05:13 AM
  #2581
XKR's Avatar
XKR
Originally Posted by ttg35fort
Other than the TC unit and new tires, any other changes?
I have to change the injectors to high impedance .... So I am going with ID 2000cc......That's it.....................I hope
Old Jun 11, 2010 | 05:19 AM
  #2582
ttg35fort's Avatar
ttg35fort
Professional
Mike, you should PM Romey to have him update the top 50 list. Looks like you are moving to the top of the Street Daily Drivers list, at least until St8dum1 gets on a DJ. You should have him also update your build description.
If I remember correctly, this time around you are running JWT C8 cams, which are the same ones that I have. What cams were your previously running?
Old Jun 11, 2010 | 06:07 AM
  #2583
XKR's Avatar
XKR
Lol.... I will let Rich keep first place...
I think I had C2 before...... Now I am running C8.
Old Jun 11, 2010 | 06:18 AM
  #2584
thom000001's Avatar
thom000001
If Larry@SP has his way...today there may be 2 more contenders for those spots too
Tom
Old Jun 11, 2010 | 06:26 AM
  #2585
ttg35fort's Avatar
ttg35fort
Professional
Rich is running the C2s, which are the cams that I was previously running. I hope moving to the C8's helps me, but I'm not totally sure at this point. I do think the C8s certainly helped your setup - with your large turbos your back pressure should be relatively low for a TT setup, and your torque curve looks fantastic.
With the smaller turbos and small A/R value on my steup, I am a little concerned that back pressure will become an issue. With the longer duration 272 cams, there is a greater likelyhood of reversion (exhaust gases moving back into the cylinders after TDC). I won't know for sure until we get on the dyno and see how everything works together. If my torque starts to drop off significantly in the higher rpm range, then I may change to larger A/R turbine housings. If it doesn't, then I'll know everything is working well together.
I think GTM is on to something by using a shorter duration on the exhaust cam lobes. This seems like it would help with a setup like mine using smaller turbos and A/R. I opted for the JWT cams because they have higher lift, but the GTM Stage 2 cams look interesting.
Old Jun 11, 2010 | 07:00 AM
  #2586
XKR's Avatar
XKR
After seeing what my setup produces..... I would say change the A/F turbine to a larger one..... You have the somewhat same motor I have also the same cams.... Faster spool up turbos would be hell to deal with without a TC....I guess I am just saying it would only be one labor charge if changed before install.
Old Jun 11, 2010 | 07:21 AM
  #2587
ttg35fort's Avatar
ttg35fort
Professional
Good point.
I am getting the TC unit. Right now I need to decide whether to ditch the HKS injectors and go with higher impedance injectors, or to try the AEM peak and hold injector driver module.
On that note, has anyone tried the AEM driver module? If so, please post your thoughts.
Old Jun 11, 2010 | 08:43 AM
  #2588
str8dum1's Avatar
str8dum1
at least on my setup, i;ve found that increasing the boost will carry the powerband to redline regardless of how 'small' my cams are.
Thom, I'm sure SP can turn out plenty of 900DD++ hp cars. Just take big turbos and lots of fuel.
But its not like I dont have a new setup coming as well
Old Jun 11, 2010 | 08:55 AM
  #2589
thom000001's Avatar
thom000001
Yea.....when 750rwhp is "OK" in their eyes lol. The guys over there don't even lift thier head from workin unless a car crack 4 figures lol.
Tom
Old Jun 11, 2010 | 09:06 AM
  #2590
str8dum1's Avatar
str8dum1
Does SP do domestic stuff as well? I wouldnt imagine there are that many V6 imports making 1000+ on their mustang dyno. 1000whp supras arent even really that common
Old Jun 11, 2010 | 09:08 AM
  #2591
ttg35fort's Avatar
ttg35fort
Professional
The C2s are very good cams. They worked very well for me. I may regret changing, we'll see.
Old Jun 11, 2010 | 09:12 AM
  #2592
thom000001's Avatar
thom000001
You'd be amazed how many cars they turn out actually....especially auto cars (for supra's through TH400's) and they still do 750rwhp+.
Yea they do domestics too....have some SICK stuff racing tonight up here at KOTS (King of the Streets)....
Most of the domestic guys are pretty secretive though
Tom
Old Jun 11, 2010 | 09:20 AM
  #2593
str8dum1's Avatar
str8dum1
YA i figure ~750 is pretty easy and affordable for most supra owners. The 1k mark is still a big jump with alot of compromises.
On a 6+L V8 though, not so tough. Would imagine the 1200+hp range would be their awe factor.
Old Jun 11, 2010 | 09:22 AM
  #2594
thom000001's Avatar
thom000001
If you can do 800+rwhp through a TH400, you got a machine!
Tom
Old Jun 11, 2010 | 09:40 AM
  #2595
str8dum1's Avatar
str8dum1
500 shot dual stage nitrous makes that pretty easy on a V8
Old Jun 11, 2010 | 09:48 AM
  #2596
thom000001's Avatar
thom000001
88mm turbos and bigger too
Old Jun 12, 2010 | 09:26 AM
  #2597
ttg35fort's Avatar
ttg35fort
Professional
Why 2000cc? That seems awfully large for your hp level, unless you are going E85. Are you moving to E85?
EDIT, I looked at Injector Dynamic's website. I didn't see an injector between 1000cc and 2000cc, so I guess the 2000cc is what you need if you want to use their injectors. Nonetheless, you should be in good shape if you want to generate an E85 map.
Old Jun 12, 2010 | 09:46 AM
  #2598
ttg35fort's Avatar
ttg35fort
Professional
Mike, also, I have not heard much about Injector Dynamics. What have you heard about them?
They make 1000cc high impedance injectors, and they look to be quite a bit less expensive than the HKS 1000cc low impedance injectors, maybe a little over 1/2 the price.
Maybe I'll pick up the ID 1000cc injectors and sell the HKS's to eliminate the need for the injector driver.
Old Jun 12, 2010 | 10:45 AM
  #2599
XKR's Avatar
XKR
Yeah.... 2000cc is all they have in my range.... I have 1200cc now and don't want to go back to 1000cc
I was told that the ID is a great injector..... Plus i am told it's the best for the high impedance I am looking for. I am not sure what the price is ... But my guess is the ID cost more than the HKS 1000cc that I use to have.
E85 is not ony list.... We don't have it here in the south.
Old Jun 12, 2010 | 12:31 PM
  #2600
ttg35fort's Avatar
ttg35fort
Professional
I'm in the same boat. It looks like there are stations to the north of me in St. Lucie county and to the south of me in Broward and Dade counties, but nothing here in Palm Beach county...
Although 1000cc injectors are adequate for my hp goal, I'm tempted to get the 2000cc injectors so that I can move to E85 if it ever becomes available in my area. My major concern is idle/low rpm (under 2k rpm) characteristics of the 2000cc injectors using the F-CON for tuning on gas. Please let me know how well Shariff is able to dial in the idle/low rpm characteristics when you move to these. Unfortunately, I still seem to have time as I wait for Japtrix to get through their backlog of cars that got in there before my motor arrived (nearly 2 months ago).
