how is compression check done
Old Feb 15, 2009 | 12:15 PM
andyisphat2004's Avatar
andyisphat2004
Default how is compression check done
I am selling my car and the buyer has a buddy who will do a compression check. How is this done? I want to make sure that I am getting legit results.
Thanks
Old Feb 15, 2009 | 12:16 PM
Spork's Avatar
Spork
1. Disable ignition.
2. Remove spark plugs.
3. Thread in compression gauge.
4. Turn engine over 5 times.
5. Check gauge and record results.
6. Repeat for other cylinders.
Old Feb 15, 2009 | 12:18 PM
andyisphat2004
I havent changed my plugs since i installed the TN kit. It is a PIA with turbo isnt it?
Old Feb 15, 2009 | 12:23 PM
andyisphat2004
looks like you have to remove the charge pipe to get to the plugs.
Old Feb 15, 2009 | 01:43 PM
QuadCam's Avatar
QuadCam
you forgot a couple steps........
1) disable injectors (unplug injector harness) and pull the fuse on the fuel pump.
2) open throttle blade while cranking (i prefer to pull the intake manifold for this job. it makes getting quick access to the plugs a lot easier.)
Old Feb 15, 2009 | 01:47 PM
andyisphat2004
what is estimated time to complete?
Old Feb 15, 2009 | 02:05 PM
Glex25's Avatar
Glex25
You mean mash the gas pedal while cranking.
Touching the throttle blade will take the throttle body out of calibration.
Hmmm good to know that you an do a compression check
with the plenum off that is one of the things I was wondering
since I'm about to do a few things and figured I would do a
compression check while in there
Old Feb 15, 2009 | 02:36 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yup!
Old Feb 15, 2009 | 05:27 PM
JETPILOT's Avatar
JETPILOT
Compression check won't tell you much. I did a compression check on my motor and it came up normal. Then I did a leakdown test on it and it showed high leakdown on 2 cylinders. Just do a leakdown check.
P.S. Don't listen to Quadcam about taking off the intake manifold to get to the plugs for a compression check. You can get to them just fine without taking it off and the pain in the *** that goes with it like stripping intake plenum threads, and a possible manifold leak. He looks for every opportunity to take off his intake manifold. Why? Boredom is my guess I'm going to hear about this soon. Should be getting a phone call in 5 minutes!
Get the leakdown done!
Old Feb 16, 2009 | 06:07 AM
QuadCam's Avatar
QuadCam
WTF!!!! some of us have never stripped a manifold bolt!!! that...and I love to use my torque wrench......I have to feel like I am getting my money's worth out of that damn Snap-On wrench!! seriously though.....I still prefer to pull the manifold. using power tools, the manifold is off in a very short amount of time.......plus, it gives you easy access to all the bolts and no chance of dropping one. the nissan gaskets are reusable, the buying gaskets is not an issue either.
Old Feb 16, 2009 | 06:18 AM
chopperman's Avatar
chopperman
Here is a tread that I created a month or two ago.
https://my350z.com/forum/forced-indu...own-tests.html
Sleeper_Z
Sep 30, 2015 10:25 AM
