How to solve radiant heat issues on FI Z's?
Old Feb 19, 2009 | 11:33 AM
scotts300's Avatar
scotts300
Originally Posted by ttg35fort
I don't think we have a firm answer. On my build I am going to play it safe and forego the heat wrap and trust the ceramic coating to do its job.
I MAY use my turbo blankets, however, even though my turbine housings are ceramic coated inside and out. The outside layer of the turbo blankets appear to be water resistent. Even if they are not, my Greddy turbos sit up pretty high in the engine compartment and are somewhat protected by the front under tray.
I also think it's a better bet to not wrap it along with the ceramic coating. Some guys wrap the downpipes, which is where I would wrap it if anywhere, as keeping them hot helps exhaust scavenging which helps your powerband. Although never proven to my knowledge, I've always had a little worry about guys that coat/wrap headers and/or downpipes, as good insulation can hold in an intense amount of heat. What happens when you turn the car off, the coolant and air flow stop, and that heat is allowed to sit and soak back to the heads? That's the sole reason I decided not to wrap my custom manifolds (on my VG30DETT) with some of our aerospace insulation. It'd be so good that it could cause other engine problems.
Old Feb 20, 2009 | 11:37 PM
Havok_RLS2's Avatar
Havok_RLS2
Still no answer yet huh? Wow! I'd have thought someone would have tried this out before. So far what i'm reading is that no one really knows.
Could that really be the case?
Old Feb 21, 2009 | 06:00 AM
ttg35fort's Avatar
ttg35fort
Professional
Search other forums. As I indicated in an earlier post, a while ago I found a thread in a Corvette forum specifically pertaining to this subject.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
