Too many miles for this mod???
Old Feb 18, 2009 | 10:32 AM
Deedlebop's Avatar
Deedlebop
Default Too many miles for this mod???
So I have a 2003 350z touring, its entire life it has been stock except for i put a 5/16 motordyne plenum spacer and k&n panel intake on at 53k miles. I drive my car pretty soft- i'll take it to 6k rpm or so once-twice a week. I've been contemplating leaving it how it is, or throwing a k&n cold air intake on it and getting it tuned with a utec or something(would going from a k&n flat panel to a k&n CAI be worth the hp gains?) The big question is i've been contemplating on getting the turbonetics single turbo for my car...my car now has 59k miles on it. Is it getting too late to throw a turbo on my car? Would my car crap out in 20-30k miles? Some advice would be great! Thank you!
Old Feb 18, 2009 | 10:48 AM
jt14894's Avatar
jt14894
It shouldn't really matter how many miles you got your Z as long as you got the $$$$ to spend.
I have a 03 Touring too. The first thing I did was add a K&N drop in. Then, I got the NISMO Cat-back and LMGT4 Silver rims. The exhaust sounded a whole lot better, but I didn't notice much of a gain in performance.
A year later, I added the Motordyne plenum spacer and the NISMO CAI at the same time. After that, I noticed a difference in throttle response and acceleration. including an increase in MPG.
That's all I have done to it. I have no plans to add anything else. Well, maybe headers, but we'll see.
Old Feb 18, 2009 | 11:21 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Feb 18, 2009 | 11:28 AM
Cass007's Avatar
Cass007
Miles don't matter much, just do a compression test to make sure the motor is healthy. The TN single kit is fairly safe as long as you stay around 8.5psi, but if longevity is your concern.....stay away from F/I.
Old Feb 18, 2009 | 11:35 AM
Yes. The motor will last 80,000 miles so you only have 20,000 left.
Old Feb 18, 2009 | 12:02 PM
Concave's Avatar
Concave
he is wrong, don't listen to him. he is only around to laugh at others mishaps.
i hope he doesn't have kids... probably doesn't.
Old Feb 19, 2009 | 03:41 AM
Car vs. Driver's Avatar
Car vs. Driver
+1 ... do some leg work first, compression and leakdown tests. Send your oil out for analysis, etc. Spend that money now and know what condition your motor is in first.
But honestly, with < 60K on the clock, go for it. I put my SC on at 54K. Granted, I've only put 2K miles on it since it went in last November
Old Feb 20, 2009 | 10:32 AM
Deedlebop's Avatar
Deedlebop
Where would I take my car to get compressions tests and stuff done on my motor?
Old Feb 20, 2009 | 11:19 AM
d1mon3k's Avatar
d1mon3k
That ***** easy. It's in the DIY section
Old Feb 20, 2009 | 12:24 PM
Cass007's Avatar
Cass007
Easy Trigger.... you're out there on the thin ice now and there are flamethowers all around you.
Use some common sense, any local mechanic or trusted speed shop/tuner should be able to help you out here. If you are not familiar with the shop I advise that you make sure they let you watch so you can validate their results (plus then you can make fun of others since you will know how its done then).
Old Feb 20, 2009 | 09:10 PM
Deedlebop's Avatar
Deedlebop
Lol I don't care. I know I could have googled it or even found it on here. Buttttt I don't mind getting flamed; flamers are i'm sure failures at life with nothing else to do than rant on peoples' lack of expertise any certain area. Thx for the info Cass!
Stevo Z
Oct 3, 2015 09:14 PM
