Issue with stalling ...
I can tell you for a fact that a light flywheel doesnt cause stalling. My FW is 11 pounds and never have that problem. If you think you have an exhaust leak, who knows what else might be wrong as well.
I know all to well how such huge excitement after your build can turn into frustration, as does most everyone in the FI forum. Not much you can do but dump more money into because it has to run.
good luck getting inspected!
I considered doing the TB hole mod ... I'm going to try and work on it this weekend. Need to pull the passenger side header off and check the gasket.
I'm thinking that it's pulling in air and tripping the O2 sensor, any thoughts on that concept?
ya a header leak could cause it to pull in in metered, which would cause problems.
But my beater has had a cracked manifold for years (cheap chinese cast BS), but that has never affected my idle though....
Pulling 1273 and 1283 codes ... most certainly related to the header leak issue. It's either cracked or the gasket is bad. I'll yank it off this weekend and see what the deal is.
Maybe one step closer ... lol
the dealer diagnosed it as a MAF sensor problem. we replaced the MAF and still stalling and still at times running on idle upwards of 17, 18, and even past to 20 and stuttering.
I have no idea what's wrong with the car at this point. I don't have any FI or upgrades right now aside from nismo low temp t-stat, nismo headers, nismo exhaust on the drivetrain as well as a k&n drop-in filter.
will be taking it back into the dealer on monday with hopes that they'll figure it out.
you're absolutely right. I have no idea why mine is running 17 and 18 at idle.
Your case is diff with fi cars.
well i have been looking at utec's and i beleive i will stop now, and i am loving my ss box right now if that makes sense lol, no codes and no drivability issues, but i have yet to drop the injectors in which is why i am looking at different ems's..i hear good things on osiris these days guys as far as drivability and not throwing codes and 3 big time shops today say its a great option for vortech with any size pulley and larger injectors
yeah i hear ya, but im just on 3.12 pulley and id like to make the jump to the 2.87 for the added torque and earlier boost curve in the rpm's but really i dont know if i want the hassle..what do u guys think about headers and cams? worth it or not worth it (for those who have them)..maybe ill leave the pulley and do them and retune and just do 440 cc injectors to avoid issues with large injectors..idk so many different things in my head right now and about 2k to drop somehow..
Tyler, don't think too much bro. Just do smaller pulley and save rest of money for build motor or upgrade blower for later. After i finish this tune I'm going to save up for block or blower.
Do smaller pulley/ems and injectors first. cams and headers are pretty expensive to do it, you are looking at about 3k+ (just a labor) even install them urself, it will cost you some money. (Also don't forget about fuel and ems $)
built shortblock will be next then some spray
heres a link i have to a turbonetics z from around where i live who had ballistic and holyroller do his car with the secondary injection for ny state inspection and for drivability to remain great...with my car it would remain with the stock injectors and add most likely 2 secondary 440's ..idk well see
http://www.holyrollerdyno.com/Holyro...ody_Brown.html (the 2 750cc injectors here are only running at 30% duty cycle he just went so big because he will be upgrading to tt in the future codes and trouble free even with those big injectors because the ecu is just running off the other stock injectors..)
Not yet, still working on the header issue. I tightened it all back down and still have a leak. THe gasket is probably blow, so I need to replace that and hopefully the leak and SES goes away so I can get the car tagged.
After that, I'll battle with the idle. Although, as I mentioned earlier, if I turn the AC on it never stalls
So that's my temporary work around.
So that's my temporary work around.Joined: Mar 2007
im just saying that if i did headers and cams right now instead of smaller pulley and ems, i could do them myself and get 440cc injectors instead of 600's and scale them with my ss box which wont scale the 600's properly and get retuned with that and know i am not gonna throw any codes or have issues like now.. or i may do 600's, a walbro 255, 2.87 pulley and osiris tune as of now, or possibly secondary injection with 2 added injectors, walbro 255 and a fuel return system and 2.87 pulley tuned with a emanage ultimate at holyroller.that is a setup they recommend and like to use and lets the car still run perfect and not throw any codes yet still be able to gain more fuel without huge injectors to cause cel's..ive been doing so much research on different setups the last few weeks
