Rough idle with haltech/ powerlab-HELP
Old Mar 7, 2009 | 08:09 AM
james12345pt's Avatar
james12345pt
Default Rough idle with haltech/ powerlab-HELP
I am having a difficult time with stabilizing my idle when my fans/ a/c kicks on. The a/f jump around from lean to rich and finally stabilizes at 14.5. At this point the fans or a/c is running and my a/f is stable but I still has an rough idle especially when my coolant temps get between 205 Fand 212 F. I have been working with Hal at IP but have not been able to come up with a fix. Any help would be greatly appreciated.
Old Mar 7, 2009 | 08:13 AM
wannabuy350z's Avatar
wannabuy350z
when you idle is rough, is your a/f messed up also?
Old Mar 7, 2009 | 08:14 AM
Glex25's Avatar
Glex25
Did you start with the basics?
Vacuum leaks is usually the common cause for varying A/F and rough idle issues
Old Mar 7, 2009 | 09:04 AM
track1z's Avatar
track1z
take it back to where it was tuned............
Old Mar 7, 2009 | 12:53 PM
rcdash's Avatar
rcdash
Your injector dead time calibration is probably a wee bit off - that would explain the transient AFR change when the fans kick in. Did you get those from your injector manufacturer? It allows you to compesate for variations in voltage (since voltage drives the injectors). Your CTS/ATS calibration tables also need to be dialed in. I would talk to your tuner or Hal if you are not comfortable mucking around with it. Once properly set up, esp. with dual widebands, the Haltech provides for a smooth engine and power delivery, always!
Old Apr 25, 2009 | 08:18 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
OP, Did you resolve the problem?
Old Apr 26, 2009 | 04:40 AM
Cass007's Avatar
Cass007
When in doubt, PM Hal@IP, he is the Haltech Zen Master. He can usually sort these things out over the phone or PM.
Old Apr 26, 2009 | 06:43 AM
TrackPack's Avatar
TrackPack
Quoted because its one of the most accurate things I have ever read on here..
Old Apr 26, 2009 | 06:52 AM
rcdash's Avatar
rcdash
Hal spent a lot of time teaching me, so he deserves the credit - just trying to help him out. Cass is right, Hal is a wizard with many things, Haltech included. I know many shops are slammed with cars before ZdayZ, so he's probably spread thin at the moment...
Old Apr 27, 2009 | 11:46 AM
tiguy99's Avatar
tiguy99
Wonder if the O.P got this sorted out or not
liqalu04
Jan 2, 2022 12:58 PM
ablaine
Nov 29, 2016 10:13 AM
bneumann
Oct 7, 2015 12:16 PM
Darkspy
Sep 7, 2015 09:09 PM
