Oil pressure at idle
Old Mar 31, 2009 | 02:21 AM
Super G35's Avatar
Super G35
Exclamation Oil pressure at idle
I have a rebuilt engine with nismo high capacity oil pump, AAM oil pan spacer with upgraded oil lines from AAM to the turbos (Greddy Setup) and my oil cooler is from stillen.
the oil pressure showing around 90 PSI on my defi gauge at idle is that normal?
what is the best oil pressure while the car is idling, and the best oil pressure when i am giving full throttle?
Old Mar 31, 2009 | 04:10 AM
djamps's Avatar
djamps
This isn't "best" it's just what I observe on my '04 with stock oil pump.
cold idle: ~90
warm idle: ~20
warm driving: ~50-90 depending on rpm.
Old Mar 31, 2009 | 06:45 AM
Cass007's Avatar
Cass007
All I know is that if its around 8-10psi at warm idle you are most definately F***ed
Old Mar 31, 2009 | 06:50 AM
djamps's Avatar
djamps
I'm sorry you and your mechanics learned that the expensive way Cass...hopefully things work out for you. Don't give up man.
Old Mar 31, 2009 | 06:53 AM
Eckoultd18's Avatar
Eckoultd18
Mine is always at 20psi on warm idle...
Old Mar 31, 2009 | 08:07 AM
Jay'Z's Avatar
Jay'Z
Warm idle 25-30
Cold idle 90-100 drops to 60 quick
Regular Driving 60-90
Old Mar 31, 2009 | 09:39 AM
Jeremy@Altered's Avatar
Jeremy@Altered
90 only on cold start up
Old Mar 31, 2009 | 09:41 PM
BrazenZ's Avatar
BrazenZ
I have a Nismo oil pump also, we plugged the piston oil squirters on the built motor & a GTM external oil cooler.
Cold idle pegs gauge @ 120psi
Hot idle 40psi
Cruising @ 3000 rpms 65
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
apex locator
Jul 23, 2021 02:27 AM
