smalltuners |DevilŽ| is back !!!!
Old May 31, 2009 | 03:31 AM
  #161
SmallTuner's Avatar
SmallTuner
Originally Posted by Kuwait350z
Congratulation man
502whp is a good start; thought i believe that your babies (Turbos) will remain sleepy for anything below 600whp
With your setup, the sky is your limits (MASHALAH)
Have fun and play safe
thanks my friend.
its realy hard to tune in kuwait with this high Temp.
still working on it
Old May 31, 2009 | 03:47 AM
  #162
Kuwait350z's Avatar
Kuwait350z
Originally Posted by SmallTuner
thanks my friend.
still working on it
A temperature difference rang from -4C(winter) to 55C(summer) won’t be a problem for a good tuner like you!
I have trust on you; keep up the good work and update us once possible
Old May 31, 2009 | 03:48 PM
  #163
SmallTuner's Avatar
SmallTuner
Operating Conditions - air temperature, pressure and humidity affect the amount of power an engine produces on the Dyno,allso, the reading will be lower than normal conditions , this is the problem, nothing to do with the tuner my friend
Old Jun 1, 2009 | 07:13 AM
  #164
midz350's Avatar
midz350
I think you need to change your signature because Smalltuner is here now
Old Jun 1, 2009 | 05:21 PM
  #165
SmallTuner's Avatar
SmallTuner
ok guys,
today,the car had 570whp @ 15psi, we are really getting to hit 600whp.
still having some issues, the power is droping after 5500RPM.
if i fix this problem, ill see around 650whp with the same boost level
wish for me good luck plz
ill post all the dynos in the next week.
Old Jun 3, 2009 | 01:15 AM
  #166
NETSHARK's Avatar
NETSHARK
Hey Small Dude sup Congrats on the DevilZ (Mashallah wa7sh) and good luck with ur master degree after you tune the monster unleash the dragon man don`t park it like the other turbo Z`s plz
MidZ350: yo man have you ever heard of McPerformance its in Jeddah ? Hussam Al-Tayeb is a HKS Pro Dealer he can tune your car with Haltech or F-Con V Pro i just don`t understand why u wanna come over to Kuwait to tune ur car if u wanna race its ok you`re more than welcome hehe but to tune i don`t see a reason here.
Old Jun 3, 2009 | 02:03 AM
  #167
Kuwait350z's Avatar
Kuwait350z
yes i should
Old Jun 3, 2009 | 11:51 AM
  #168
BaZooKa's Avatar
BaZooKa
570 whp ! good work keep going ,, and hope you will see the 7xx Whp
Old Jun 3, 2009 | 03:02 PM
  #169
SmallTuner's Avatar
SmallTuner
Originally Posted by NETSHARK
Hey Small Dude sup Congrats on the DevilZ (Mashallah wa7sh) and good luck with ur master degree after you tune the monster unleash the dragon man don`t park it like the other turbo Z`s plz .
thanks man
Old Jun 3, 2009 | 03:10 PM
  #170
SmallTuner's Avatar
SmallTuner
im haveing a problem.
the power is droping after 6000RPM i think its the cams.
still not sure, but tomrrow ill get the answer.
700 is just easy with those turbos, for now ill stay in the 600whp range.
if the drop that i have is from the cams, ill not going to change them befor hitting 700whp
Old Jun 3, 2009 | 11:14 PM
  #171
midz350's Avatar
midz350
Actually Hussam doesn't tune the Haltech (he already tried it on my friend Z) and I don't like the V PRO and beside I always wanted to come to Kuwait
Old Jun 4, 2009 | 12:27 AM
  #172
wannabuy350z's Avatar
wannabuy350z
ana 7akoon 3endak gareeb inshalla. 3eyar al haltech fahimo kather.
Old Jun 4, 2009 | 01:17 AM
  #173
SmallTuner's Avatar
SmallTuner
ehehe i realy like hussam
his numbers are
23 - 24 psi on the TD05-18Gs, with C16 and just 600whp !!!
i dont trust his way of tuning VQ engines, ooh i forgot he is an HKS pro dealer
Old Jun 5, 2009 | 05:58 AM
  #174
rcdash's Avatar
rcdash
Have you already tuned the intake cams for full retard at 6k rpms small tuner? I would be surprised if you are losing power up top because of the C2 cam selection. 6k rpms should still be in the sweet spot. Also, I noted in the first post that you are using RC 750cc injectors. That might be a little small. How is your AFR?
Old Jun 5, 2009 | 08:12 AM
  #175
SoundPerformance's Avatar
SoundPerformance
Sound Performance
What size cams?? We only have BC 264s in our car and the power never drops off until 9000 RPM.
Old Jun 5, 2009 | 09:56 AM
  #176
SmallTuner's Avatar
SmallTuner
its JWT C2 261 i dunno why , the car is giving me better HP and torque numbers in the low midrange when u compare them to GTM dyno numbers, but after 6000RPM its dropping
with my old setup, my power never go down, that was with small turbos.
im still checking befor going big cams
Old Jun 5, 2009 | 09:59 AM
  #177
SmallTuner's Avatar
SmallTuner
my AFR is 11.5 - 11.3 redline.
allso my IDC is 70% in redline
its giving me the same graph as rockys (need4boostz) car when he did the 773 whp
Old Jun 6, 2009 | 03:56 PM
  #178
rcdash's Avatar
rcdash
Hmmm. Not fuel, so air or spark: heat soak, exhaust back pressure Using a Haltech? Tuned intake cams? Got some dyno curves?
Old Jun 7, 2009 | 07:50 AM
  #179
SmallTuner's Avatar
SmallTuner
yep
ill post them, but not now.
im in egypt right now, i have exams its gonna take 2 weeks.
still i have feelings its the cams rcdash.
like i said befor, the car is making more power than GTM Dynos in the low midrange.
maybe thats becuse of the Big A/R im runing, the turbain is a 86 A/R.
those will make power in the top end, but the cams wont.
n e way, the car is making big power, reaching 700 whp is easy with those turbos.
u just have to put C16 and run more boost
Old Jun 7, 2009 | 11:00 AM
  #180
SoundPerformance
Sound Performance
yep
I really doubt it is the cams running out at 6000 RPM. If we have 264s that will never drop off until over 9000, 261s shoud be good for well over 8000. Unless of course your variable valve timing is not working??
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
