PE TT vs Vortech SC
Old Apr 23, 2009 | 03:31 PM
wizard's Avatar
wizard
Default PE TT vs Vortech SC
Hi All,
I'm new here and from the UK
There seems to be alot more info here the the UK equivilant forums so I thought i'd post something for comparisons.
I'm thinking of going FI soon probably starting with the stock motor... I've read that both the PE TT (small turbo's) and the Vortech are quite kind to the engine internals in comparison to APS, Greddy, HKS, etc...
I'm running a late 2002 JDM 350z with nitrous.
2 questions:
1) Anyone here run either or both of these setups? Which one is preferrable and why?
2) Used vortech kits seem to come up in a blue moon, but I've never seen a used PE TT kit. Has anyone ever seen a PE TT kit for sale?
Thanks guys.... will put up a current spec list of my car soon....
Old Apr 23, 2009 | 04:25 PM
str8dum1's Avatar
str8dum1
PE kits were very expensive and didnt make much power.
Your nitrous setup probably makes more power than either of those options though. The member Gurgen on here uses a PE setup for road racing and he really likes it.
I like my vortech but for someone that has the option between a turbo and belt driven SC, turbo hands down.
Old Apr 23, 2009 | 04:30 PM
Jason333's Avatar
Jason333
hi
Sheezhot runs the PE as well.
It was pretty exclusive at one time. I think it is equivalent to the smaller JWT kit as far as power.
Old Apr 23, 2009 | 05:21 PM
str8dum1's Avatar
str8dum1
ya it was one of the 1st kits and top balla back then. true JDM
Old Apr 23, 2009 | 07:11 PM
DanielW's Avatar
DanielW
pe tt's will spool super fast but wont be good for massive top end power but hey niether will the vortec. i say go TURBO
Old Apr 23, 2009 | 07:17 PM
eltness350's Avatar
eltness350
The Untouchable
do a search.....
Old Apr 23, 2009 | 07:49 PM
Blck350z's Avatar
Blck350z
I had a PE TT kit. I picked it up used...... https://my350z.com/forum/forced-indu...t-build-3.html .... I had a fun time installing it and it turned out great I think. If I had it to do over again I would go w/ the s/c ( for my type of driving etc. ) I do not like the "instant boost" the PE TT kit gives. Also when/ if you get a pett make sure it has the cast manifolds and also water cool it from the start. PM me if you have any questions.
Old Apr 24, 2009 | 03:13 AM
djtimodj's Avatar
djtimodj
Hi mate, I spoke to Zmanalex the other day about turbo and SC opinions as he has run both on his currect car.
It comes down to cash, Turbo is the best but most $$ route but SC is cheaper and safer on the stock block.
Ill have a chat with you tomorrow mate!
Old Apr 24, 2009 | 05:32 AM
Jason333's Avatar
Jason333
hi
I don't agree with this statement. I see it a lot on here, and I don't know where the idea came from. Any form of FI will destroy a motor as fast as another. I have seen people post blown motors with the Stillen super conservative setup.
Old Apr 24, 2009 | 07:12 AM
str8dum1's Avatar
str8dum1
ya a blower being safer is BS. i had my cog belt fray on me and shorted out some wires which in turn fried my UTEC and stock ECU. People feel that Vortech's are safer because you can use basically any pulley combo and not surpass the commonly accepted trq limit on the stock rods.
Turbo doesnt have belts spinning all over the engine bay, u can use springs or a boost controller to control your HP, and its not a constant parasitic load on the motor
Old Apr 24, 2009 | 08:06 AM
djtimodj's Avatar
djtimodj
My statement above was the SC is a safer bet as the way it build boost puts less strain on the rods and gives the engine a better chance of living with the boost.
I did not mean that the SC is any more reliable than the turbo as i no turbos require less maintinace when fitted.
Old Apr 24, 2009 | 09:01 AM
Clint@Altered's Avatar
Clint@Altered
I'd say the available turbo kits for the 350z are "safer" than the supercharger kits. Bigger intercoolers, lower AITs, no power-robbing pulley system, and NO BELTS!
The PE kit is not bad (minus the manifold issues). Very torque oriented power band. I've seen them produce 480whp/480wtq here.
Old Apr 24, 2009 | 10:10 AM
SmallTuner's Avatar
SmallTuner
why not GTM STG 1 ?
great price and one of the ebst kits on the market, Garrett water cold turbos, great power.
Old Apr 24, 2009 | 10:57 PM
350z-900whp's Avatar
350z-900whp
i would say go with gtm also since u can upgrade just the turbo's in the long run so, it would be cheaper for u if u want to upgrade.
i had PE-TT before u can't even feel the lag if theres any :P but realy it an nice kit if u don't want any thing past say 540whp since i made 503whp/534wtq with 16psi (built short block/stock heads cams) i think it was. drove the car realy hard never had a single problem with the kit water temp 90c and oil like 190F or so with just koyo thick one.
the only down side was the manifold tend to crack BUT that was with older kits SS manifold the new ones have cast manifold . if u looking to get a used it just make sure to get the newer manifold not the SS or u can buy a set for 1200 from pe
https://my350z.com/forum/shop-builds...1-500rwhp.html
Old Apr 25, 2009 | 06:52 AM
rx7/350z's Avatar
rx7/350z
LOL........ I had the same exact problem 2 years ago. took out the cam sensor and fried exerything.
Broken vortech belt = 2500 dollars!!!!!!!!!!!!!!!
Old Apr 26, 2009 | 08:23 AM
wizard's Avatar
wizard
It would be preferrable for me to go for the PE TT over the vortech... but the problem is mainly the cost.
PE TT is close to £7,000.00 or like $10,000. That's a lot of money for a mere 80bhp gain.
Do many used PE TT kits up on here?
I've never seen a single one in the UK for over a year and a half so I'm not holding my breath on that!
Old Apr 26, 2009 | 11:43 AM
Cass007's Avatar
Cass007
IMO, on a stock block, one TT kit is as good as another. I would expand your choices and go with a used kit from a reputable member/shop if you want to save some $$$. A new APS TT Tuner kit is cost effective as long as you don't have plans to build the block down the road - check with Z1motorsports or Forged.
Old Apr 27, 2009 | 09:09 AM
Blck350z's Avatar
Blck350z
The initial kit only adds "80 whp" ( thats what PE and other companies say with the exception of stillen which really DOES add only 50-100 hp haha ). But with all the add on's that you need to make it reasonably safe you can be at a safe 400 rwhp instead of 230-240ish for a stock DE.....thats a big jump and puts the car in to a completely different league.
Note hp figures vary significantly from car to car so don't get hung up on the number to much but look at a dyno sheet to see the power curve and decide which best fits your style of driving.
Old Apr 27, 2009 | 09:20 AM
doug's Avatar
doug
its a myth on running low power till prevent your motor blowing.. some blow on 320 whp.. some blow on 500whp.. no choice of kit is going to make it any safer.. i would go with the GTM kit instead of PE Kit
Old Jul 3, 2009 | 12:54 AM
tritanusmma's Avatar
tritanusmma
I love the power and torque from my PE kit and It's JDM which does give some bragging rights over a shop put-to-gether turbo kit. I have the cast manifolds and went with the PE over the APS because I had reasonable power goals and have a 5AT so I didn't want a power band that was more even. So far I've been pleased my car does the quarter at 12.8 at 9psi which is just as fast as some higher horse TTs that don't pull as strong on the lower end. I had to immidiately upgrade the injectors and fuel return system supplied with the kit because it won't supply enough fuel past 5psi, I'd also suggest a boost controller and bov so you control the boost instead of the internal waste gate setup. I did a UTEC instead of the technosquare but I hear good things about the square and most those guys are getting better numbers than me
