How many lbs of boost on a stock motor?
Old Apr 28, 2009 | 08:42 AM
meth98's Avatar
meth98
Default How many lbs of boost on a stock motor?
i found a good deal a supercharged Z (vortech) and he says it's running around 10 or so on the boost. can this be done realiably without any engine modification?
Old Apr 28, 2009 | 08:45 AM
JZurita's Avatar
JZurita
I used to run the same psi before my motor build with no issues. It's all about the tune.
Old Apr 28, 2009 | 08:51 AM
meth98's Avatar
meth98
word, it's got an ecu flash i believe. also has the intercooler (will probably help alot here in FL).
Old Apr 28, 2009 | 09:02 AM
psychoballistic's Avatar
psychoballistic
^+1 on the tune for sure. I run 8lbs on twins on stock block without any issues.
Old Apr 28, 2009 | 09:48 AM
frankie945's Avatar
frankie945
10 psi on TN kit no problems here.Like said above its all in the tune.
Old Apr 28, 2009 | 09:52 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
10psi on Vortech sc when setup and tuned correctly is very safe.
Old Apr 28, 2009 | 10:07 AM
Blck350z's Avatar
Blck350z
It depends on what s/c and what internals its running ( i.e. stillen has different pulleys, but vortech has different pulley's and a few different units, S,T and Si Trim ) Ibs. of boost is determined by that and also by what breathing mods you have. With a freer flowing exhaust on a s/c it will lower the Ibs. but up the HP ?!?! Any more details will help!!!
Old Apr 28, 2009 | 10:28 AM
Laps's Avatar
Laps
I ran 13psi for a while on 110 race fuel and from experince nothing over 9lb is what you can call safe on a stock block
sales@czp
Sep 23, 2019 03:30 PM
