Rebuilding 18G turbo question
Old May 5, 2009 | 05:12 AM
350 Rookie's Avatar
350 Rookie
Default Rebuilding 18G turbo question
One of my turbos has shaft play, back forth and side to side. Its not major but still not good. I wanna rebuild this. I wouldnt imagine the process being too hard, pretty straight forward however i have never built one before so can i get some opinions on wether it is a difficult task and where to get the rebuild kits.
Old May 5, 2009 | 05:16 AM
Jeremy@Altered's Avatar
Jeremy@Altered
Have it checked first. Mistubishi turbos have a lot of play (more than you would think) even when they are brand new.
Old May 5, 2009 | 06:31 AM
westpak's Avatar
westpak
SFZCC
it is not hard, main thing is to have a vice to hold it while trying to unbolt the nut that holds the shafts.
I did both of mine when I rebuilt the engine, mainly due to them having 20k miles and I had them out, Jeremy is right they have quite a bit of play in them to begin with.
You can get the rebuild kits on ebay, just check them out to make sure they have all of the parts needed
also make sure you notice how the housings are in relation to each other before you take them apart so you put them back the same way or the turbos wont point in the right direction when you reinstall them
Old May 5, 2009 | 06:47 AM
350 Rookie's Avatar
350 Rookie
well even if it does have alot of play from the factory, i can push the compressor side wheel all the way to the wall. I dont think thats good, HOWEVER there is no oil leak or anything. It just moves back forth and side to side.
ALso, what causes the shaft from moving. What in the cartridge is going bad that lets the shaft move?
Old May 5, 2009 | 06:48 AM
Jeremy@Altered
Honestly, you can push a lot of turbos into the wall if you push them. Are there any marks on the housing from it hitting while running?
Old May 5, 2009 | 07:17 AM
350 Rookie's Avatar
350 Rookie
no, there are no marks or scratches from the blades.
Ive owned 3 other turbokits in my life and none of them ever touched the wall. This one does but i guess you know better than i do.
Would you think its worth rebuilding anyways, it only has 7000 miles on it and a rebuild kits only like 60 bucks on ebay.
Old May 5, 2009 | 07:21 AM
Jeremy@Altered
Honestly, if it was mine, i would not rebuild it. BUT, i dont want to be held liable on here if it failed so you do what you feel like it should have done.
Old May 5, 2009 | 07:29 AM
350 Rookie's Avatar
350 Rookie
LOL. alright
Any good ways of testing a turbo prior to puttin it on. Cuz once this goes on, i dont wana have to take it back out. I just wanna make sure everything is good.
Old May 5, 2009 | 07:31 AM
Jeremy@Altered
Turbos are really hard to test out unless you have the facility to do so.
You could always send it out for a piece of mind.
Old May 5, 2009 | 07:32 AM
doug's Avatar
doug
you got a GreddyTT Kit now? or just using 1 18G? i've seen rebuild kits on ebay for $75 .. not sure if its everything you need.. even though they say so..
BTW Ed.. if you do go through with it and its succesful.. let me know.. i have over 20k on mine and it might be time for me to rebuild mine
Old May 5, 2009 | 07:38 AM
350 Rookie's Avatar
350 Rookie
no i got greddy twins but i got 3 18gs. one as a spare but i might just rebuild one for the hell of it. learning experience also. Ill order the rebuild kit this friday.
Old May 5, 2009 | 07:50 AM
doug's Avatar
doug
feg.. just couldn't let me be the only built GreddyTT in the area huh?
maybe i will as the gf to work some OT and buy me GTM Twins
Old May 5, 2009 | 09:37 AM
350 Rookie's Avatar
350 Rookie
Hey well you can be the only built greddytt with leather pants in the area.
Old May 5, 2009 | 09:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
OP-if it makes you feel any better I have 11K on my Greddy snails still going strong.
I thought about rebuilding at 9K when the motor let go but decided against it. Good luck!
Old May 5, 2009 | 10:59 AM
doug's Avatar
doug
well i wear leather pants because i ride a motorcycle, but since you don't ride.. why you wearing leather pants?
Old May 5, 2009 | 11:05 AM
Nexx's Avatar
Nexx
11k hard miles, hard hard miles.
Old May 5, 2009 | 11:08 AM
350 Rookie's Avatar
350 Rookie
Well, i see how cute your *** looked so i wanted my *** like that too.
Old May 5, 2009 | 11:18 AM
quiksilver38's Avatar
quiksilver38
turbos should last more than 20k miles even if you drive really hard, unless the turbo has a manufacture defect
Old May 5, 2009 | 12:44 PM
350 Rookie's Avatar
350 Rookie
ok. thanx
350Z_Al
Oct 29, 2020 07:44 PM
