thinking of a turbo z with problems
Old May 17, 2009 | 06:53 PM
Currin's Avatar
Currin
Default thinking of a turbo z with problems
Hey,
I am looking at buying a turbo'd (ST Turbonetics) 06 track 350z with 35000 with nismo exhaust, tein springs updated stage 2 cluch, hks bov. buying as is, buying from dealer, not known how long the turbo has been installed(from info i am thinking 15000-25000). Turbo has no intake on it, has boost controller, and major thing is it has a Clanking sound from the engine, gets louder and faster at higher rpm's, dealer says its the valves. but car looks good on inside and outside. i know i have a problem with the engine, and have an uncle that owns a performance shop, so i can get it fixed with a resinable price.
so Q.'s
1. should i buy. at 14500<still negotiable (good deal or not)
2. how much do you think repair cost is on engine?
3. how long does the turbo last on the TN kit?
4. at worst case scenario on engine and turbo kit, cost of repairs?
Lmk if need more info or i am asking wrong/stupid questions.
thanks,
currin
Old May 17, 2009 | 06:55 PM
Nexx's Avatar
Nexx
if you want to spend another 10k+ go right ahead. then you would still have the worst turbo kit you can put on a Z. so yeah.. no.
Old May 17, 2009 | 06:58 PM
Currin's Avatar
Currin
pics
Car on left is the car i am trading for it
Old May 17, 2009 | 07:02 PM
Currin's Avatar
Currin
10K? beruild of a 350 would run me 4-5k of forged internals. but still wondering about valve cost and extent of problem
Old May 17, 2009 | 07:04 PM
Welcome. This 350Z is not for you.
Old May 17, 2009 | 07:08 PM
kyx4n's Avatar
kyx4n
lol @ no intake comment (unless im misunderstanding)
but yea.. imo dont get a turbo'd 350z car unless you know the previous owner and whatnot. Plus, the TN kit is def not the best out there
Currin's Avatar
Currin
thanks for teh reply, but can you explain?
Old May 17, 2009 | 07:10 PM
Cass007's Avatar
Cass007
Intake is missing???
Old May 17, 2009 | 07:11 PM
Currin's Avatar
Currin
when i said that, there is no af-1 on the kit. so its not filtering any air.
Old May 17, 2009 | 07:12 PM
sublimemoment's Avatar
sublimemoment
Check out the classifieds on this site. There are many turbo'd cars for sale in florida that are in better condition.
Old May 17, 2009 | 07:43 PM
alltel350z's Avatar
alltel350z
Is this car in al
Old May 17, 2009 | 07:44 PM
Currin's Avatar
Currin
I see other 350s are out there but i know i am looking at 4-6K in engine repairs but that all that is rong with the car, and for 10 under retail(23 being i bought it at 13. that a 4K in savings, unless some one can give me some answers about q 1-4 and what some one thinks the clanking sound it and how much i would have to put into the engine.
Thanks
Old May 17, 2009 | 07:45 PM
Currin's Avatar
Currin
Originally Posted by alltel350z
Is this car in al
yes Daphne, at a honda dealer. y
Old May 17, 2009 | 08:19 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
https://my350z.com/forum/search.php?searchid=9005690
Old May 17, 2009 | 08:42 PM
Currin's Avatar
Currin
not to be mean but i have been searching about turbonetics, and the only q i was asking that related to turbonetics was how long the turbo on the kit would last on average(i could never find that info).
Old May 17, 2009 | 08:44 PM
Nexx's Avatar
Nexx
OP, it sounds like you want us to tell you that "yeah its no big deal, just buy it, it wont cost much to fix it and it wont give you more problems down the road" but you're not gonna get that from us. we've been through this schit before, for me.. 3 times.
Old May 17, 2009 | 09:07 PM
rookie's Avatar
rookie
Clanking is probably a spun bearing, or there's a bent rod/rods.
Old May 17, 2009 | 09:35 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Not even have the airfilter...do they ever change oil? how long do you think it will last long?
Old May 17, 2009 | 09:48 PM
fstrnldr's Avatar
fstrnldr
I wouldn't, but the answer to the other 3 questions should make up your mind.
I won't even begin to guess what it would cost w/ out hearing it. I would guess if it was even close to what would be profitable, the dealer would fix it to sell it rather than trying to sell it broken. If your uncle owns a shop, and you are going to be using his shop, then ask him for a guess on what he is charging you on labor. If it is a spun bearing, you could have major damage to the crank, and rod, or to the block, if it is a broken rod or piston, you could have a block that is junk, call your local nissan dealer and price out some of these things. Other option is to call one of the aftermarket vendors on this site and ask about buying a short block, or long block depending on what "your" car might need after finding out exactly what you need.
If you have a damaged engine making noise, then there is metal in the engine, which means there is metal in the turbo bearings, i would guess it will be on its way out shortly. It could be okay, but would you want to risk it w/ a fresh motor? if the turbo bearings fail, they can send debris back into the engine after all.
again, you need to make some phone calls, start w/ the shop doing the work for you, and continue on to nissan, and some other after market shops to find out what your parts are going to cost. Don't forget to add extra money for things like gaskets, heat wrap, AC line replacement (pretty notorious on the Turbonetics kit), misc hoses etc that will probably need replaced etc.
The other thing to think about is make sure you have another car to drive while you are rebuilding this one, things like this take time in real life, and it seems like you are going to be trading in a running driving car, for a 1:1 scale model of a 350Z. Just make sure you can get to work for at least a few weeks (probably longer) while you are getting everything together for this new toy.
good luck w/ your decision.
Old May 18, 2009 | 02:30 AM
doug's Avatar
doug
have the dealer put in writing that the engine problem is bent valves and if otherwise they will pay for parts and labor of a new engine.. then the sales manager will give you the answer you need on if you're buying this car or not
