Who says vortechs can't make power...
Old May 30, 2009 | 10:56 AM
OldManZ350's Avatar
OldManZ350
Originally Posted by thom000001
Begin SP nutswing:
pharm,
SP built a new idler setup for the vortec's that is Much better than the basic vortec idler setup and allows virtually no slip. It obviously isn't as good as a cog setup for slip, but cog setups put other inherit stress on the drive system as well....
just another option especially if you go to a smaller pulley.
again, great power.
tom
/sp nutswing
Have any pic, specs or drawings?
Old May 30, 2009 | 08:23 PM
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by OldManZ350
Very Nice,
With your built motor why not rev it a little higher, like to 7000 or 7200
Wow, I was wondering if anyone would notice that. The dyno tach reading was off bc we couldnt get a good connection source (use the whp to wheel ration instead) but on the VPRO it was tuned to 7000 rpm. Good eye
Old May 30, 2009 | 08:47 PM
Nexx's Avatar
Nexx
wow! sick sick sick! i wanna see trap speeds!
Old May 31, 2009 | 10:39 AM
str8dum1's Avatar
str8dum1
ok, so thats really a 7000 rpm pull?
nice.
Originally Posted by Mr_pharmD
Wow, I was wondering if anyone would notice that. The dyno tach reading was off bc we couldnt get a good connection source but on the VPRO it was tuned to 7000 rpm. Good eye
Old May 31, 2009 | 12:09 PM
Mr_pharmD's Avatar
Mr_pharmD
nice.
ya, the scaling is off by 600 so 6400 on that dyno is actually suppose to read 7000. That is why my max tq/hp is at the wrong rpms on that dyno sheet but if u add 600rpm to each interval it's right around 52XXrpm where they should cross.
Old Jun 1, 2009 | 06:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Insane numbers, very nice.
Do you know if these are zero correction DD numbers or are they compensated to read like a DJ?
My 490whp on a DD uncorrected yielded the 1/4 time in my sig FYI.
Old Jun 1, 2009 | 07:10 AM
rcdash's Avatar
rcdash
Congrats on the numbers - outstanding power curve.
So I learned recently that Dyno Dynamics is known for it's accurate atmospheric corrections, unlike DJ which has a tendency to be a bit exaggerated (reportedly). That's the reason all the IP DD dynos up in the mountains didn't fall flat as there was the default DD correction built in. DD does have "shootout" mode that bypasses all the compensations. This is what Sharif generally uses down in Atlanta. That said, in Atlanta, not too much correction would be needed, except for during the summer heat. I surmise then that dynos down at Forged during the summer will read lower than the winter time with the cooler weather numbers more on par to DD readings elsewhere (which include compensation).
EDIT: So Alberto, do you recall the date (or even better temp) when the dyno was performed? (sorry to hear about your trans )
Old Jun 1, 2009 | 12:56 PM
ADMAN's Avatar
ADMAN
Congrats...
Old Jun 1, 2009 | 02:34 PM
bbs350z's Avatar
bbs350z
damn, nice numbers especially for 91
Old Jun 1, 2009 | 02:43 PM
iStan's Avatar
iStan
ZR
AT to MT??
I knew I should have gone to Pharmacy school
Old Jun 1, 2009 | 07:36 PM
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by iStan
AT to MT??
u still can
Old Jun 1, 2009 | 08:08 PM
Barzten1's Avatar
Barzten1
Sweet Vortech power. Must lay that power down pretty good
Old Jun 2, 2009 | 08:46 AM
jouvert00's Avatar
jouvert00
Awesome!! glad to see everthing came together, when you get tired of the T-trim research the YSI-Trim!
Old Jun 2, 2009 | 08:47 AM
jouvert00's Avatar
jouvert00
Are you running the Mondo bypass?
Old Jun 2, 2009 | 01:08 PM
tgunsg35's Avatar
tgunsg35
+1. Why did you go with the DW 800 that seems a little big for your power level. By the way nice numbers.
Old Jun 2, 2009 | 04:55 PM
str8dum1's Avatar
str8dum1
bc 600cc are at 99% IDC at 460 hp.
Old Jun 2, 2009 | 05:23 PM
tgunsg35's Avatar
tgunsg35
Your right I thought he had a fuel return system in his mod list. Thanks for the info.
Old Jun 2, 2009 | 07:26 PM
  #38
Mr_pharmD's Avatar
Mr_pharmD
I do have a return line and I believe my duty cycle was around 70%.
I was going to run E85 but it required 30% bigger injectors to do so but the tuner says it won't net any extra whp (cant use with meth kit) and there aren't many stations around and may never will.
U got to love the VPRO... it idles like stock even with 800cc
Also, I'm using the regular vortech bypass valve. I was going to use the HKS but that one was even louder. I might switch back and forth.
Old Jun 2, 2009 | 07:42 PM
  #39
tgunsg35's Avatar
tgunsg35
I have a friend that is running the same power level with the 600cc DW and fuel return system. I was asking because he has a TT setup and I was comparing FI applications. I want it to know if I upgrade my built would I need the 800cc injectors.
Old Jun 2, 2009 | 07:49 PM
  #40
Mr_pharmD's Avatar
Mr_pharmD
It really depends on the EMS. I have the VPRO and it's capable of idling larger injectors but if u run the utec then your best bet is to run 750cc max. Therotically, if u want 500whp u can run 650cc injectors but u will be close to or over 80% duty.
